Glom
So What Exactly Are The IFRs?
Wed Dec 30, 2009 8:26 am
I've been reading my books and the AIP material on the matter and I think I have it down, but maybe some experts can help me on this.
Naturally, I'm referring to the IFRs in the UK. So the IFRs are:
  • The pilot must be suitably qualified to fly IFR.
  • The aircraft must be suitably equipped for the route being flown. (The AIP had a list of requirements for avionics, which generally included VOR (just the one), ADF and DME and that was about it).
  • Adherence to minimum height rule although this doesn't seem to apply to IFR in VMC.
  • Adherence to quadrantal rule and semi-circular rule when above transition altitude.
  • Flight plan when flying in controlled airspace (though apparently, sometimes this can be passed over the radio).
    So is that it?
    The VFRs are pretty simple. In fact, near as I can tell there this is only one: Maintain VMC. I suppose having a flight plan when flying in classes B-D airspace and no flying in class A airspace may be considered VFRs too.
    9VSIO
    RE: So What Exactly Are The IFRs?
    Wed Dec 30, 2009 1:46 pm
    Quoting Glom (Thread starter):
    And in uncontrolled airspace, IIRC.
    Are you sure about this? I thought IFR flights must be X number of feet above the tallest possible obstacle within Y number of miles of track.
    Then again, i'm only an IMC rated pilot... y'all pros and ATPL students should know better :P
    Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
    Glom
    Wed Dec 30, 2009 2:54 pm
    Quoting 9VSIO (Reply 1):
    Of course. Thanks for pointing that out.
    It says in my book and in AIP that there are exception to the minimum height rule.
    Quoting AIP ENR1.3:
    1.2 Minimum Levels
    1.2.1 Except when necessary for take-off or landing, or except when specifically authorized by the appropriate authority, an IFR flight
    shall be flown at a level which is at least 1000 ft (300 m) above the highest obstacle located within 5 nm (9.25 km) of the estimated position
    of the aircraft; except that the United Kingdom regulations do not apply to an aircraft operating under IFR and flying at an altitude not
    exceeding 3000 ft (900 m) if that aircraft is clear of cloud with the surface in sight and in a flight visibility of at least 800 m.
    Note 1: The estimated position of the aircraft will take account of the navigational accuracy which can be achieved on the relevant
    route segment, having regard to the navigational facilities available on the ground and in the aircraft.
    Note 2: See also ICAO Annex 2, paragraph 3.1.2 and GEN 1.7 Differences.
    Note 3: The United Kingdom has no statutory requirements relating specifically to minimum IFR altitude when operating over high
    terrain or mountainous territory.
    bri2k1
    Wed Dec 30, 2009 4:10 pm
    The R in IFR/VFR stands for Rules, but I don't think it's intended the way you're trying to use it here. It's not a rule as in a regulation, but a rule as in a definition of the procedures. For example, speed limits are a regulatory rule, but the area rule for wing design means the technique or method for producing a design within provided limitations.
    Flying under Instrument Flight Rules means the flight is procedurally conducted by reference to instruments. That's it. In order to operate a flight under IFR, most parts of the world have implemented regulations that govern who, when, and how this may be done. In the USA, that includes being in constant 2-way radio communication with ATC, for obvious reasons. One of the Rules about IFR operations is that ATC will make it the highest priority to provide separation services to aircraft operating under IFR, but the pilot is still ultimately responsible to see and avoid other aircraft, whether they are operating under IFR or VFR.
    Flying under Visual Flight Rules means the flight is conducted primarily by visual reference to the ground. In Class G airspace, the minimum flight visibility is 1 Statute Mile, and the requirement is just to remain clear of clouds. Most people would not consider those to be prevailing Visual Meteorological Conditions, and that probably falls under the "legal but stupid" category of minimum regulations. Other airspace classifications have different requirements for flight visibility and distance from clouds in order to operate under VFR. Failure to adhere to any of them, or to the equipment, certification, communication, or other requirements defined in the regulation, is a violation of those rules -- but not a violation of Visual Flight Rules.
    Position and hold
    KELPkid
    Wed Dec 30, 2009 4:24 pm
    So is that it?
    In most places, there's also the issue of the aicraft itself, which must be not only equipped properly for IFR flight, but also up-to-date on maintenance and service inspections (in the US, some inspections, like the 30-day dual VOR receiver error check, are actually conducted by the pilots before flight  Smile ).
    These inspections usually pertain to the aircraft's flight instrumentation systems...
    9VSIO
    Wed Dec 30, 2009 5:06 pm
    Quoting Bri2k1 (Reply 3):
    Yea, the OP's wording caught me out a bit, but I took it to mean "to be IFR, what do you have to do".
    Aren't two altimeters also a req for IFR?
    You don't need to file a formal flight plan for that. Imagine trying to cross a zone, and needed to file tons of paperwork just to do it. Just ask for a zone transit and give them the position report and estimates when they ask.
    bri2k1
    Wed Dec 30, 2009 5:38 pm
    Quoting 9VSIO (Reply 5):
    Not for flight under the regulations in Part 91 of the FARs. The pitot (airspeed indicator) and static (altimeter, VSI, and airspeed indicator) systems must be inspected every 24 months though (91.411). A transponder with Mode S capabilities, meaning an altitude encoding capability, is a requirement for flight in Class A, B, and within 30 miles of the primary airport in Class C airspace, but the transponder can use the same altitude input as the primary altimeter, or have its own "blind" (not visible to the pilot) encoding altimeter.
    The club I rent planes from performs all their maintenance by the book, and I typically have no issues finding a properly equipped and maintained aircraft to fly IFR. The one I run into more commonly is the VOR Operational Test, which must be done no less often than every 30 days in order to fly under IFR (91.171).
    Position and hold
    Mir
    Wed Dec 30, 2009 6:20 pm
    Quoting Bri2k1 (Reply 6):
    Actually, the requirement is for Mode C, not Mode S.
    The requirement for Class C is only within and above the airspace, not 30 miles around it. You're thinking of the Mode C veil around Class B airspaces.
    -Mir
    9VSIO
    Wed Dec 30, 2009 7:21 pm
    What on earth is Part 91? Is that private? Commercial? etc?
    Quoting Mir (Reply 7):
    Mind you, there was a push by EASA/CAA (I think) to make Mode S transponders mandatory. Lots of GA owners were unhappy as a result due to the costs involved.
    We do that before each IFR flight at my place, but it's not a legal requirement to make a note of it and log it as such. It's just part of our standard instrument checks.
    Mir
    Wed Dec 30, 2009 7:33 pm
    Quoting 9VSIO (Reply 8):
    Part 91 is private travel not for compensation or hire. This covers most general aviation, including aircraft owned by a corporation used in furthering that corporation's business (it doesn't cover charter operators).
    The way the rule is written, even if you have a Mode S transponder, it still has to have Mode C capability.
    -Mir
    KELPkid
    Wed Dec 30, 2009 7:50 pm
    In the US, no (as noted by Bri2K1 above, under US FAR part 91). Maybe other places...
    aviopic
    Wed Dec 30, 2009 8:31 pm
    Altitude is still(and always was) reported by the mode-c capability of the transponder.
    The mode-s capability supplies additional information like Type of A/C, Speed bracket, A/C reg etc to ATC but is also used for Tcas communication.
    Not sure whether or not it is already mandatory in the US for GA A/C, probably not.
    The truth lives in one’s mind, it doesn’t really exist
    Mir
    Wed Dec 30, 2009 8:47 pm
    Quoting Aviopic (Reply 11):
    It's not. Mode C isn't even required if you can avoid the airspace where you need it. And in the western part of the country, there's plenty of room to do that.
    -Mir
    KELPkid
    Wed Dec 30, 2009 9:04 pm
    Quoting Mir (Reply 12):
    -Mir
    And, ironically, TCAS will work just fine off of a Mode C return...  Wink Which makes one wonder why Mode S would be required for GA aircraft in the first place?
    aviopic
    Wed Dec 30, 2009 11:18 pm
    Quoting KELPkid (Reply 13):
    Ask the EU authorities  Big grin
    After some 2 weeks from the mandatory date AMS ctr started to cry cause all they saw was just one big blob on their radar screens because everything is flying with mode-s including ultra lights and even gliders.
    For the time being all GA and other light traffic had to switch back to mode-c in the AMS ctr, not sure what the current status is though.
    According this document http://www.ivw.nl/onderwerpen/luchtv...twikkelingen/modestransponder.aspx
    mode-s is required as of March 2008 with the exception of SPL tma-1.
    Yes and no.
    The altitude reporting of a mode-s transponder is more accurate, 25ft instead of 100ft.
    And a mode-c transponder can't be interrogated by ground radar and/or acas as both systems require the 24bit ICAO code.
    9VSIO
    Thu Dec 31, 2009 10:23 am
    Quoting Glom (Reply 2):
    Hmm, I guess so, but surely you can't plan an IFR trip on that basis, thus minimum heights will apply at the planning phase, but one you're airborne, whether you adhere or not is ur call if the conditions permit. At least thats how I interpret it.
    Also, would you still have to follow semi-circular and quadrantal rules if in receipt of a deconfliction service or a procedural service? I've never asked for one en-route as I've tended to be on-top or below the transition level.
    Also, afaik, the Dutch Aviation Authorities aren't making themselves very popular with GA at the moment, with charges for ATC services and what not.
    Glom
    Thu Dec 31, 2009 11:07 am
    Quoting 9VSIO (Reply 15):
    True. It's probably more applicable to flight outside controlled airspace when you're not on a flight plan. Though, if you're outside controlled, not flying on a flight plan and in VMC, are your flying IFR or VFR? At that point, doesn't it just become a case of mentality?
    The rule does specifically state the exception is for below transition altitude. What difference that makes I have no idea other than the fact that above transition altitude, obstacle clearance shouldn't be an issue or else someone hasn't set transition altitude correctly.
    9VSIO
    Thu Dec 31, 2009 11:37 am
    Quoting Glom (Reply 16):
    What I meant was, outside controlled airspace, under a deconfliction service, above the transition level, the controller goes "G-ABCD, pop up traffic, left 10 o'clock, 1 mile. Tun right heading 090." Would he have to change my FL as well (assuming I was in a different quadrant)?
    Glom
    Thu Dec 31, 2009 11:44 am
    Quoting 9VSIO (Reply 17):
    I don't know but I would presume not because that heading is only for traffic avoidance and will shortly be changed back to the original.
    Users browsing this forum: mmo and 2 guests
