kimon
Vertical Tapes Vs Round Dials 747-200
Fri Jan 01, 2010 9:51 pm
How did vertical tapes come to be?
Was it an initiative by pilots from KSS?
What was the thinking behind it?
Dum Romae consulitur, Saguntum expugnatur
ex52tech
RE: Vertical Tapes Vs Round Dials 747-200
Fri Jan 01, 2010 10:55 pm
You can tell at a glance if something is a miss, especially with the engine instruments, they do save space, and to a lesser degree they even seem to be something of a fad that the industry went through.
"Saddest thing I ever witnessed....an airplane being scrapped"
N747PA
Sat Jan 02, 2010 7:20 am
I would venture to say that this was the first 747 with vertical tape instruments:
Photo © S. M. Reeves
TWA had them on the 747 and the L-1011.
747classic
Sat Jan 02, 2010 1:26 pm
IMO also TWA was the first with vertical tapes on the first built 747-131.
see below :
Photo © AirNikon Collection-Pima Air and Space Museum
Advantages vertical tapes against round dials :
Quoting Ex52tech (Reply 1):
Fully agree, you can see in a split second if someting is wrong with an engine parameter.
Because it saves space you can have more info in the FWD eye reference position, important during critical flight fases (starting,T/O and landing).
The only drawback was the low MTBF (4 dials in one instrument), so we always carried a few spares (expensive) in the TBO (technical board outfit), located in the belly (hold 4).
Operating a twin over the ocean, you're always one engine failure from a total emergency.
kimon
Sat Jan 02, 2010 2:50 pm
kimon
Sat Jan 02, 2010 2:59 pm
Jetlagged
Sat Jan 02, 2010 4:08 pm
Round dials are much easier to read and give better rate indications.
The tape flap position indicator is much a better presentation than the two dual round dials which go with the round dial engine instruments.
ex52tech
Sat Jan 02, 2010 4:31 pm
As far as who was first to use tapes, I know that the F-105 and the XB-70, just to name two, used tapes at least for ASI, and MACH readouts, but not for engine instrumentation.
Getting back to tapes for engine instrumentation, the tapes were easier to read engine operations such as tandem bleed closure on the JT9-7A,-7F,-7J than the later used EIDS flat screen readouts. EIDS was somewhat laggy and not as precise as the old "steam" tapes.
The only drawback, personally, with the tapes over the round gages with digital readouts was when performing a high power engine run-up. They could be difficult to read with any precision while bouncing around at high power with the brakes set. With EIDS we could take a snap shot and recall it when back at idle.
tf39
Sun Jan 03, 2010 2:08 am
Quoting Ex52tech (Reply 7):
I'm wondering then if the C-141 was the first (or among the very first) to use the vertical tapes for engine instrumentation since it's first flight was in 1963? I couldn't find any pictures showing round gages in any of my books so I'm assuming it had them from the start.
ex52tech
Sun Jan 03, 2010 5:07 am
Quoting TF39 (Reply 8):
That could very well be. I can't think of anything older that I have seen tapes for engine instruments.
PGNCS
Sun Jan 03, 2010 11:19 pm
Quoting Jetlagged (Reply 6):
I agree from a user's point of view. The tapes are in all ways inferior to round dials for engine indications. I have flown the L-1011 with tapes and round dials, and vastly prefer the round dials; a quick look at a column of instruments in a problem engine is much more intuitively revealing than looking through several rows of tightly-packed tapes. I have also flown the tape engine instruments on the 744, and found them to be my least favorite part of the glass in the aircraft.
I am a huge advocate of the PFD/ND format EFIS with tapes for primary flight instruments, however.
Interesting point, Ex52tech. B-model F-105's had round dials, but with F-105D and subsequent, the integrated flight instrument package with tapes was installed; there well may be something with earlier use of tapes in an application, but this is the first one I am personally familiar with. Of course the 105 had round dials for engine instruments...with only one engine it's not difficult to diagnose which one is having the problem!
Jetlagged
Mon Jan 04, 2010 11:46 am
Quoting PGNCS (Reply 10):
Agree 100%. On a PFD the tapes usually have trend arrows added to help assess rate and are not tightly packed.
Francoflier
Mon Jan 04, 2010 1:17 pm
I agree with that. Tape gauges, whether analog or digital, just don't give you the precise 'at a glance' indication of the value they're indicating. Trend monitoring is also a bit more difficult as there is no scale on the side of the gauge. They make it hard to accurately set your engines manually.
That being said, on modern aircrafts with FADEC, those indications aren't really important.
747classic
Mon Jan 04, 2010 2:10 pm
I have flown with pleasure for almost 30 years with the analoque vertical tape instruments on the 747's.
The thrust is roughly set with the N1 (GE) or EPR (P&W, RR) tapes, a little below the bugsetting (target N1 or EPR), calculated by the thrustsetting computer. Above the thust setting vertical tape parameter is always a numberical read out, to fine tune the thrust of the engines manually, if no FFRATS installed.
For very accurate monitoring of a limit exceeding or trending of the engines we always used the AIDS (aircraft integrated data system) as installed from our first 747 and made a print out.
Especially on a three or four engined aircraft you can IMO see the faulty engine or not normal engine parameter(s) much earlier (in a glance) than with the round dials.
On most digital engine displays you can choose between round or vertical annunciation (pin option).
Jetlagged
Mon Jan 04, 2010 8:11 pm
Quoting 747classic (Reply 13):
Even with FFRATS, you need to fine adjust the power setting as there is only one auto-throttle motor for all four engines (it sets the highest reading EPR/N1).
With round dials you have a digital readout for each primary parameter (and a linear pointer scale). Tape scales are non-linear, which doesn't help quick reading.
Just as quick and easy to scan all pointers parallel as all tapes lined up. Still, to each their own preference.  Smile
Users browsing this forum: Natflyer and 3 guests
