yodobashi
Raked Wingtips ....
Sun Jan 03, 2010 1:24 pm
Hi folks,
As far as I understand, winglets and raked wingtips help to reduce drag, stopping the airflow from the top and bottom of the wings colliding at the wingtip and causing drag.
I shot the following picture from a Singapore B777-300ER wing whilst in the climb out of Singapore. The condensation on the upper wing seems to stop short of the wingtip about where the raked wing starts.
Does anyone know is this just coincidence, or does this show how the raked wing stops the airflow on the top of the wing from reaching the wingtip itself?
http://www.pbase.com/image/120774328.jpg
Any info would be greatly appreciated.
"The World is a book, and those who do not travel read only a page"
tdscanuck
RE: Raked Wingtips ....
Sun Jan 03, 2010 5:28 pm
Quoting Yodobashi (Thread starter):
Yes.
Not really. The reduce, but do not eliminate, the airflow around the end of the wing. Most of their effect (in terms of drag) actually happens fairly far from the tip itself.
It's not a coincidence, but it's not a because the tip is stopping the airflow either. The condensation is caused by the pressure drop over the wing's upper surface...the amount of condensation is, roughly, a measure of the lift being generated at that wing station. The lift on all wings (regardless of winglet/raked tip/normal tip) goes to zero at the tip, so the upper surface condensation will also disappear at the tip. How close it gets to the tip depends, a lot, on how much lift the wing is generating, the atmospheric conditions at the time, and the wing shape.
Tom.
vikkyvik
Mon Jan 04, 2010 12:19 am
Couple photos to illustrate Tom's point:
Photo © Ronald J Stella
Notice in the next two photos, the condensation basically spans the flap span. The portion of the wing that has flaps is generating far more lift than the tip, when the flaps are extended. You also get a powerful vortex off of the end of the flaps. These effects are generally best noticed on landing, as you're at a high flap setting.
Photo © Tim De Groot - AirTeamImages
BMI727
Mon Jan 04, 2010 1:40 am
I don't have a lot to add here, the other two mostly covered it.
Quoting Tdscanuck (Reply 1):
The condensation forms in lower pressure areas and on a wing, the areas with the lowest pressure (above the wing) create the most lift. This effect also appears as the shock collars in transonic flight and in some engines, if the conditions are right.
yodobashi
Mon Jan 04, 2010 11:30 am
Gentlemen,
Many thanks for your replies, I think I am now a little wiser as the reasons for the effects pictured.
Thanks again!
 Smile
Users browsing this forum: SheikhDjibouti, Yahoo [Bot] and 19 guests
