c5load
What Happens When You Redline Jet Engines?
Sun Jan 10, 2010 11:59 pm
How much more (in terms of percentage) thrust do you get during emergency situations when you have to redline engines? When you land, are those engines still usable, or do they have to be replaced?
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
fr8mech
RE: What Happens When You Redline Jet Engines?
Mon Jan 11, 2010 12:10 am
IWhat are you redlineing? EGT? EPR? N1? N2? N3?
When you reach any single redline, you don't have to do anything. You've reached the safe limit, that's all. It is quite improbable that you will reach redline on all the parameters at any one time.
Now, you can exceed some limits, depending on engine, situation, and malfunction. The maintenance manual will dictate what checks need to be performed or, in some cases, whether the enigne needs to be pulled in some specified time frame or before further flight.
c5load
Mon Jan 11, 2010 12:29 am
Quoting Fr8Mech (Reply 1):
Sorry, I guess what I meant was something that my dad has told me was called "bending the throttles." Wouldn't this happen especially after a bird strike on a twin engine airplane on climbout when it's heavy? How many things redline when you bend the throttles?
EMBQA
Mon Jan 11, 2010 12:35 am
You do what the Engine Maintenance Manual tells you to do. Ever case is different, every engine is different. In most cases you boroscope the engine looking for heat stress and rubbing. You pull the DFDR and see what the engine was actually exposed too
Alias1024
Mon Jan 11, 2010 4:10 am
Quoting C5LOAD (Reply 2):
At my airline there are only two maneuvers where we push the thrust levers all the way to the stop, stall recovery and windshear escape.
tdscanuck
Mon Jan 11, 2010 4:43 am
Quoting C5LOAD (Thread starter):
Zero, on most modern engines. Most FADEC engine will go to max certified thrust and stick there. There are a couple of weird cases; a CFM56-7 will go to the maximum certified thrust for the model, regardless of the programming plug in the EEC. Airbus has something similar, although I don't think it's implemented the same way. I believe that P&W used to offer a temporary overboost for certain takeoff situations.
But, for the majority of modern engines, pushing the throttle full forward will just give you maximum certified thrust which, by definition, can't be a redline.
Generally, yes.
This may be a term from the days before FADEC, when pushing the throttle beyond the normal max thrust actually could push more fuel into the engine (at the cost of engine life).
Remaining engine goes to takeoff thrust; this should never result in a redline on a modern engine.
Nowadays, none. The engine should protect itself. Which component sets the limit usually depends on what altitude and speed you're at.
Tom.
MarkC
Mon Jan 11, 2010 9:56 am
As was said before, a rarity these days. The only time you usually see engine removals today due to too much power setting is with a cargo 727 with JT8's, and its usually because of windshear, and the critical parameter exceeded is EGT. Pilots do not seem to want to fool around with windshear. The engine manual has a graph. A certain # of seconds exceeded at high temperature. A certain number (more) exceeded at a lower temp, and so on.
747classic
Mon Jan 11, 2010 10:40 am
There are still a lot of analoque designed aircraft remaining with non-fadec engines.
All 747 series, before the -400, L1011, DC10, all remaining DC8 series, DC9 series, Early A300/310's.
Aircraft powered by PW JT3, JT8 (except final versions), JT9 series, GE CF6-6,-50 and some early -80 series, RR RB 211 series until and incl.serie -D. All early CFM 56 series as on DC8-seveny series and KC-135.
If a coventional (non fadec) fuel control with mechanically connected throttles is present, in most cases overboosting the engine is possible by pushing the throttles to the end stop.
How much you can overboost depends on the outside air temperature, air pressure and regulator setting in the fuel control, combined with the rigging of the engine control cables system.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
saab2000
Mon Jan 11, 2010 11:47 am
Quoting 747classic (Reply 7):
This is correct. I fly the CRJ-200 which has no FADEC and no real overspeed/overtemp protections. It would be very easy to push the throttles past the recommended limits as there is no physical detent or stop in the throttle movement/travel. Just a marking on the engine gauges where to stop for T/O for CLB or FLEX thrust.
We once had a failure of the speed control and had to shut off the speed control in flight. The checklist calls for the engine in question to be reduced to near idle thrust before turning off the speed control. This was not properly done for a number of reasons not worth getting into here and upon landing the engine did have to be inspected for stresses induced, as it did go 'red' on several parameters.
FADEC is a good thing. I wish we had it.
smrtrthnu
BMI727
Mon Jan 11, 2010 4:32 pm
There was a story about a MiG-25 being clocked at Mach 3.2 and supposedly it ruined the engines. I would guess that some of the problems would have to do with parts melting inside the engine.
But luckily few pilots ever find out. Take care of your engines, and they will take care of you.
2H4
Mon Jan 11, 2010 6:08 pm
Quoting MarkC (Reply 6):
I remember hearing of an exchange between a pilot who had escaped some rather severe windshear on final and his employer. Apparently, the engines were overtemped, and damage resulted. Upon being asked why in the world he ran the engines up to 110% N1 (or whatever the value was), he replied "Because they wouldn't go up to 115!"
Intentionally Left Blank
Tristarsteve
Mon Jan 11, 2010 6:31 pm
Quoting Saab2000 (Reply 8):
I know nothing about your engine, but this sounds a bit backward to me. I worked on old engines. The RR Spey from 1965 had a fuel limiting system that reduced the fuel flow if the EGT limit was exceeded. It was no where near efficient as a modern FADEC, but it saved the engine.
The original RB211-22 from 1972 had a similar fuel limiter. It also controlled on N3(if I remember correctly) as well as EGT. Again, it didn't look at all parameters, but meant that if the crew firewalled the throttles the engine continued to function. The VIGV controller also mechanically limited engine speed. If the N2 went over limits, it closed the VIGVs to limit airflow through the engine.
saab2000
Mon Jan 11, 2010 7:54 pm
Tristarsteve,
I should clarify what I am saying. There are actually overspeed protections, but no hard or fast stop for the throttle levers until it is simply all the way to the front of the movement, at which point you are probably overspeeding or overtemping the engine, or both.
But at 79.1% N2 it switches to an electro-mechanical speed control based on N1 and it does have some protections.
But no detents or stops like many of today's engines have.
smrtrthnu
stratosphere
Mon Jan 11, 2010 8:24 pm
I remember several years ago FedEx had 2 windshear events in the same week one in GJT and one in RNO both 727's one wound up being a 3 engine change and the other one was a two engine change. In most cases the FDR is pulled and boroscope inspections done to determine what action is taken.
Alias1024
Mon Jan 11, 2010 9:05 pm
The one nice thing about not having FADEC on the CRJ-200 is that you can get a couple percent more N1 if you desperately need it. I know someone that had a windshear event on very short final at ABQ. With the thrust levers at the stop they were still descending toward the ground. He reached down and turned off the engine speed switches and they escaped, but just barely.
Review of the FDR showed an RA of 50 feet before they could get climbing again. Makes you wonder if they'd have hit the ground with FADEC.
DocLightning
Tue Jan 12, 2010 1:25 am
Quoting 2H4 (Reply 10):
I think that those who are type-certified to fly desks sometimes forget that in an emergency, a maneuver that may shorten engine life may actually *extend* engine life by preventing the aircraft powered by those same engines from crashing into the ground. I'm no pilot or mechanic, but it strikes me as logical that crashes shorten engine life a lot more than 110% N1 does.
-Doc Lightning-
-Carl Sagan
dw747400
Tue Jan 12, 2010 4:31 am
Quoting DocLightning (Reply 15):
Not to mention extending the life of the airframe, passengers, and crew.
I've heard of some FADEC aircraft (biz-jets) have the ability to boost power beyond the normal redlines in abnormal situations, like an engine failure or windshear. All of this is automatic--the crew puts the throttle to the stops and the aircraft systems as a whole determine if emergency power is needed (for example, airspeed drops sharply or one engine is outside of normal parameters). I can't remember which jet(s) this was on.
CFI--Certfied Freakin Idiot
tdscanuck
Tue Jan 12, 2010 5:12 am
Quoting Dw747400 (Reply 16):
This is bending the definition of redline a little bit; redlining is taking an engine parameter (usually spool speed or EGT) past its limit. This is not the same thing as going beyond certified thrust. Due to the habit of engine makers to use one core (or one entire engine) for multiple thrust ratings, it's pretty common for an engine to be capable of more thrust than it's certified for. In fact, due to the way certified thrust is demonstrated, virtually all engines are capable of exceeding certified thrust without redlining.
For example, a CFM56-7B20 (~19,000 lbs thrust) can be run up to 27,000 lbs of thrust without busting any redlines, because it's physically exactly the same engine as a CFM56-7B27, just with a different programming plug in the EEC.
Tom.
DocLightning
Tue Jan 12, 2010 6:57 am
Now you're just being a bean counter.  Wink
Quoting Tdscanuck (Reply 17):
Why would you ever want such a bad bottleneck in an engine capable of so much more? Wouldn't it make more sense for an airline to ask for the full-power engine to be fitted to a given model, if it's going to weigh the same?
-Doc Lightning-
-Carl Sagan
Tue Jan 12, 2010 7:04 am
Brilliant statement. Darned right frameable.
Quoting DocLightning (Reply 18):
As I understand it the aircraft in question has weights that require only 19k thrust. The wear and tear on that particular engine, with a "max" of 19k, will be much less than on an equivalent engine set at 27k. So the airline has it restricted to 19k and can use the engine longer.
rwessel
Tue Jan 12, 2010 8:27 am
As Starlionblue mentioned, the maintenance costs on the lower rated engine may well be less.
A second (and in some case more important) reason is a bit of market segmentation by the engine vendor. Given the very high cost to develop and certify an engine, building *one* engine and offering it in several "models" allows considerably lower development expenses, while still allowing pricing to suit the application. And this basically benefits everyone, if done correctly (or just the vendor, if they’re greedy).
Consider the following hypothetical market for two engines, one 20,000lbs thrust, the other 25,000lbs. Let's say it would cost $500M to design, build and certify a "real" 20,000lb engine, with a unit production cost of $1M, and $625M to design the 25,000lb engine, with unit production costs of $1.25M.
Let's further assume that each engine will sell 1000 units over its design life. Amortizing the R&D expenses gets us $1.5M and $1.875M for costs for the two engines respectively. And then assuming a 50% margin on top of that leads to selling prices of $2.25M and $2.81M, which gives us total sales of $5.06B and a profit of $1.69B for the two programs.
Alternatively, the manufacture could just build the bigger engine, maybe toss in an extra $100M R&D to make it a bit better (a bit little lighter, a bit more fuel efficient, etc.), a bit cheaper to manufacture (let's say they can save $100K/unit), and then just make a different program ROM for the FADEC.
Now the manufacturing cost for each for the *2000* engines is $1.15M, and the amortized R&D ($725M) gets us a total cost of $1.513M/unit. Now the manufacturer plays with the margins a bit, and let's say sells the "small" engine for $2.15M and the large one for $2.7M (getting a slightly lower margin on the small engine and a slightly bigger one on the big engine), which yields total sales for the program of $4.85B, but total profits of $1.82B (an absolute higher profit, *and* a higher profit margin, with lower total costs).
The customer, OTOH, gets cheaper engines, that are better (since more R&D was spent). It's an absolute win for the big engine customer on all fronts, and the small engine customer gets higher reliability, lower costs, etc., in return for a small weight penalty. Everybody gets cheaper and more plentiful spare parts. In short, everybody does better.
The obvious question is why not sell all the engines at one price? Because that doesn't work - it's great for the big engine customer (who could now buy their engine at $2.43M), but you lose all your small engine sales because the engine is overpriced for its market. So basically the segmentation exists to distribute the costs (in this case for the higher thrust) to the customers who need that feature. But it does lead to the (apparent) unfairness of the manufacturer charging two different prices for the same bit of hardware.
It can even help the airframe manufacturer beyond the obvious advantage of having cheaper engines – this can make it much easier to offer a “hot-and-high” (or similar) package for your aircraft. Which, for example, is exactly what Boeing does with the 777-200LR, where, for a few extra dollars, you can get an extra 5000lbs thrust per side by swapping the plug to turn the GE90-110s in to -115s. And only the customers who need the bigger engine pay for it.
Note that the computer industry is well known for that particular tactic. Back in the late seventies there was a well known bit of documentation floating around the mainframe world about how to rewire a jumper block in a certain third-party-vendor's tape drive, to transforming the tape drive from the slow to the fast model, or to enable support for several (optional) tape densities. Needless to say the vendor was very unhappy about this, and you had to swap the “official” jumpers back in before placing a service call.
There have been many examples since then. A very common one being the microprocessors themselves – they’re often offered in a range of speeds, even for the same physical chip design. And while some amount of that range comes from testing – IOW some chips test faster than others due to small manufacturing variances – much of the binning is artificial, especially as the production line matures and most of the dies start testing out at, or near, the “maximum” speed. All the folks who like to “overclock” their CPUs depend on that.
And as the ratio of R&D to (program) manufacturing costs increases, the benefit to this sort of scheme increases. Of course the reverse is true as well - as program production costs increase relative to R&D costs, it becomes increasingly better to develop dedicated models of product optimized to each required feature set. Of course a complicating factor is that building two products may not take two full R&D efforts, rather one might be a derivative of the other - that doesn't change the principal, it just moves the crossover points around.
Pellegrine
Tue Jan 12, 2010 10:26 am
Quoting BMI727 (Reply 9):
I would defer to the metallurgists and engineers. But I am sure in this case and others of excess EGT, the limiting factor is the HP turbine and possibly IP/LP turbine. The high temperature metals (nickel or stainless steel most probably) will "creep" far before they melt. Meaning they won't just discombobulate and fly out the back end, but will stretch at the high RPMs a turbine operates at and become un-useful and potentially dangerous to engine operation by throwing the turbine disk out of shape.
Quoting Rwessel (Reply 20):
Been overclocking since the 80386.  Wink
oh boy, here we go!!!
Faro
Tue Jan 12, 2010 11:31 am
Using the full 27'000 lbs of thrust is a no-no if you are in an engine-out situation so the programming plug applies in this instance. Why not cater, however, for situations where that extra 8'000lbs of thrust is suddenly and direly needed? Surely that programming plug can be smart enough to discern if there is an engine out or not...
Faro
The chalice not my son
Tue Jan 12, 2010 12:00 pm
Well, the 19k are supposed to be enough for any emergency. Sure, you always want "more power" but note that the aircraft is certified to handle "any" emergency with 19k per engine. Also, wouldn't an extra 42% power result in some unplanned yaw effects with an engine out?
Faro
Tue Jan 12, 2010 1:15 pm
Quoting Starlionblue (Reply 23):
Yes indeed  Smile:
Quoting Faro (Reply 22):
Fabo
Tue Jan 12, 2010 2:34 pm
Doesnt that result in mandatory de-rating of one-engine-out on light 777 take-off or something like that?
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
Jetlagged
Tue Jan 12, 2010 5:22 pm
Quoting TristarSteve (Reply 11):
It was called TTC (Top Temperature Control). Only a limited authority though. The Spey also had an N2 governor, N1 limiter and a P3 limiter. Rolls Royce certainly knew how to make a hydro-mechanical fuel control unit idiot proof. There seems to be a different philosophy between RR and US engine makers PW and GE who tended to leave parameter limiting to the crew, apart from N2 governing and burner pressure limits.
tdscanuck
Wed Jan 13, 2010 12:10 am
It depends on Vmcg/Vmca for your particular airplane. I don't think a 737-600 is certified for the -7B27 (too much thrust), but it can certainly handle more than than a -7B20.
That's why, at least on a 737NG, if you push the throttle to the forward stop you get the maximum certified thrust for the *model*, rather than the maximum certified thrust for that engine. So a -7B20 on a 737-600 will go up to whatever the -600 is certified to handle (23,000 lbs, I think) if you ask it to. This will require some extra maintenance steps, I suspect, and if you're on power-by-the-hour you're going to pay for it, but the power's there if you need it.
If you didn't take it properly into account when planning V1 and V2, you could drop below Vmcg or Vmca and lose directional control. If you stick to proper takeoff calculations, you should be protected from this.
Quoting Fabo (Reply 25):
That's one way to handle it. The Vmca/Vmcg check should be part of the V1/V2 calculation. V1 can't be lower than Vmcg and V2 can't be lower than Vmca or you're going to get in trouble on an engine failure.
Tom.
BEG2IAH
Wed Jan 13, 2010 2:24 am
This is how it looks. I was amazed how small the plug is, but does so much for thrust limitation. This was shot at OSL in SAS hangar.
Big version: Width: 600 Height: 450 File size: 94kb
BEG2IAH
Aviation is not so much a profession as it is a disease.
ThirtyEcho
Wed Jan 13, 2010 6:51 am
Quoting Tdscanuck (Reply 5):
I am very familiar with this term. I have quite a bit of piston time, going back to 1959, and my uncle was a B-24 command pilot during WWII. It simply means to disregard engine limits and "firewall" the throttles in an emergency situation. It was regarded as bad practice in 1944 and is so, today. After all, why are you in that situation in the first place?
The term has no meaning in modern jet operation. Maybe some Korean War F-86 jock could expand on this.
brons2
Wed Jan 13, 2010 7:31 am
Quoting ThirtyEcho (Reply 29):
In 1944, maybe a Fw-190 was closing on your tail?
Although in a B-24, I don't think any amount of throttle bending could make the plane outrun any of the better fighters of the era.
Firings, if well done, are good for employee morale.
tdscanuck
Thu Jan 14, 2010 4:57 am
Just so nobody gets weird ideas about my father, that's actually C5LOAD's quote from Reply 2, not me.
Tom.
c5load
Thu Jan 14, 2010 3:59 pm
Quoting Tdscanuck (Reply 31):
Thanks, so you think my father's weird do you?  Silly
jcs17
Thu Jan 14, 2010 9:42 pm
Actually, one of the criticisms leveled after the Air Florida crash at DCA was that the throttles were never firewalled, and remained at a reduced thrust T/O setting.
America's chickens are coming home to rooooost!
tdscanuck
Fri Jan 15, 2010 12:47 am
Quoting C5LOAD (Reply 32):
Nope. Just that any suggestion that *my* father flew an airplane or knew what "bending the thottles" meant would be very weird.
Tom.
Flighty
Fri Jan 15, 2010 6:20 am
It seems that jet engines have an exponential reduction in service life as they increase thrust. For example, reducing the thrust % by a certain percentage could double the time between intervals
It sounds like emergency thrust consumes a lot of engine life. It is very expensive maneuver, right?
Fri Jan 15, 2010 7:42 am
Quoting Flighty (Reply 35):
Yes it is. It is worth noting, however, that it is less costly than a crashed aircraft.
747classic
Fri Jan 15, 2010 11:54 am
We all agree that passing the red line (operating limits) of an engine can be very expensive.
But there are some situations that you want to have all the extra thrust, that you can get out of your engine(s) and you don't care if you exceed the limits, because this extra thust may safe the day (and your aircraft and all passengers +crew).
In the nineties of the last century we had some extra type recurrent simulator training on the 747-200/300 with non FADEC engines (GE CF6-50E2), to explore the limits of this aircraft in emergency situations.
This training was part of a seminar made by American Airlines and was called :
Advanced Maneuvering Training (AMT) and a presentation on video by Captain Warren VanderBurgh was included. Our company (KL) had adapted it for the 747.
In this learning and training session the following was trained :
1) Unusual attitude recoveries.
2) Windshear & Microburst review
3) Controlled flight into terrain (CFIT) & Mountain waves.
4) Control malfunctions (multiple)
5) Automation Dependency.
It was a very good learning experience (I can still remember it very well) and you also discovered your own limits, and also the limits of the flight envelope of the 747.
In two (2) out of 5 situations (Windshear and CFIT)) the last resort was to over-boost the engines (they called it "fire walling the engines" ) to keep some space between your aircraft and the very solid ground and to avoiding a hull loss.
I cannot understand why no (guarded) red knob is available in all FADEC equipped aircraft to allow an over-boost of the engine(s), if the Pilot in command (PIC) needs it in a real emergency situation. (the final thing he can do to save his aircraft). It must be possible to design the over-boost in such a way that the engine can operate safely 5 minutes at this emergency rating, before removing it after the first landing (safety first-economy last).
I prefer to change all the engines after a safe landing than touching the ground with all engines below or at the red line.
[Edited 2010-01-15 03:56:45]
tdscanuck
Sat Jan 16, 2010 1:13 am
Quoting 747classic (Reply 37):
There are limits to how far you can extend this logic...at some point, the engine becomes a danger to you (rotor burst), possibly a larger danger than the lower thrust. If you blow the engine, you go to zero thrust (definitely worse than full rated thrust) and may potentially do serious damage to the airframe and passengers at a time you least want it.
The function is there on many airplanes, it's just not a guarded red knob. This is exactly what happens when you ram the throttle all the way forward...you get as much thrust as you can reliably and safely get from the engine.
There are other considerations with overboosting...you're (by far) most likely to lose an engine when you're stressing it, and losing an engine while at max thrust can be very dangerous. If you overboost, you run a very real possibility of losing control of the airplane, and that is *going* to kill you.
The only way to do this with adequate reliability would be to design the engine to a higher rating and then derate it...which happens all the time today.
Tom.
747classic
Sat Jan 16, 2010 10:06 am
Tom, I have to disagree with you on this subject.
I know the blessings of a FADEC or ECU controlled engine. In 99,9% of all engine failures it will help you to save (parts of) the engine and hopefully your aircraft.
But in a few (very remote) emergency circumstances, I still want to have the possibility to have full control over the engines myself and I don't want to be limited by a "computer" who does the thinking for me.
The two remote circumstances are :
- All engines are 100% functional and at full TO/GA thrust, but I am at a very low altitude in a downdraft or low speed situation. The ground is coming towards me at an alarming rate and EGPWS keeps alerting me.
- Low altitude, all engines damaged, but still delivering (reduced) thrust. Fuel flow (Thrust) limited by programmed limits in FADEC.
So, from a operational point of view I prefer all FADEC engines to have a possibility to revert to basic fuel metering (avoiding stall conditions), without any limits valid. Some thermal overstressed HPT blades are the least of my concerns at that moment and this manual overboosting for a very short time MAY solve the situation.
Peter.
tdscanuck
Sat Jan 16, 2010 6:58 pm
Quoting 747classic (Reply 39):
But the computer is trying to do the same thing you are...maximum thrust without having the engine come apart. I hope you'd agree that having the engine totally fail, when it was producing some thrust, is worse than just getting some thrust.
This position is based on the idea that you know how much thrust the engine can provide more than the FADEC does, and I don't understand that idea. What are you looking at that makes you think the engine can put out more than it's putting out?
This is exactly why at least some FADEC engines (e.g. 737NG) go above their certified thrust when firewalled and provide the maximum that the *aircraft* can take. You've already got this capability, without dropping the FADEC out of the loop.
If the FADEC is limiting thrust, it's doing it for a reason. Since you can't tell, at a glance, what that reason is, how do you know you're not going to get in more trouble by overboosting the engine?
Thermal overstress of the HPT, I would agree, it the least of your problems in that sort of situation. But a rotor burst, or a complete shell out, would be far worse than getting some fraction of rated thrust. And you don't know which one you're going to run into.
Tom.
