enilria
Class 3 Aircraft And Class 4 Aircraft
Tue Jan 12, 2010 4:14 pm
Does anybody know the width requirements for each of these classes? Also, are any aircraft in danger of moving from Class 3 to 4 with the addition of modern winglets? I know a 757-200 is Class 4 and a 737-700 is Class 3. I don't know much else...anybody have a link?
arffdude
RE: Class 3 Aircraft And Class 4 Aircraft
Tue Jan 12, 2010 4:40 pm
Aircraft wingspans fall into six different design groups, which are as follows:
Group I - < 49'
Group 2 - 49'-78'
Group 3 - 79'-117'
Group 4 - 118'-170'
Group 5 - 171'-213'
Group 6 - 214'-262'
Aircraft can also be arranged in order of approach speeds, which are labeled as A through E, with E being the highest. Every airport has an Airport Reference Code, which is the design group plus the approach speed category of the most demanding aircraft it is expected to handle. Most small/medium size airports for example fall into Airport Reference Code CIII.
While design groups measure aircraft wingspans, aircraft lengths also fall into five categories that determine the ARFF index of an airport, which specifies minimum firefighting equipment and agent that an airport must have on hand.
enilria
Tue Jan 12, 2010 4:47 pm
Quoting ARFFdude (Reply 1):
Just what I needed! I added you to my resp list. Happen to know if any are so close to Type 4 that winglet mods are putting them over the line?
[Edited 2010-01-12 08:48:42 by enilria]
BMI727
Tue Jan 12, 2010 4:59 pm
Quoting Enilria (Reply 2):
If the winglets on the 737 were any larger it would be Class 4, since it measures in at 117' 5" with the winglets and 112' 7" without. The A32x baseline wingspan is about 112' as well. I would guess that the sharklets have been sized so as not to put them into Class 4.
enilria
Tue Jan 12, 2010 5:03 pm
Quoting BMI727 (Reply 3):
I assume the fuel savings grows with the length? Any truth to that? Over time with high fuel there might be more pressure to extend them. Just wondering the impact it will have on gates at tight airports like LGA/DCA.
BMI727
Tue Jan 12, 2010 5:07 pm
Quoting Enilria (Reply 4):
Essentially, adding winglets (or raked wingtips) is in many ways like increasing the span.
I'm sure that Tdscanuck can give a better answer than I, but my guess would be that there is a point of diminishing returns on the size of winglets. But the potential gains from bigger winglets may be cancelled out by the need for bigger gates.
enilria
Tue Jan 12, 2010 5:16 pm
Quoting BMI727 (Reply 5):
I found a document from Boeing:
http://www.boeing.com/commercial/airports/faqs/wingletspans.pdf
They show the 757 got a much larger winglet (8% wingspan increase instead of 4% increase). The Group 4 wingspan limits are wide enough to handle that. That makes me think there is additional savings from a bigger winglet.
arffdude
Tue Jan 12, 2010 6:11 pm
I'm not aware of any off the top of my head, but along the same lines, the 737-800 is an ARFF index C airplane, whereas the previous 737 versions have fallen under ARFF index B. Index B covers aircraft up to 126', and then index C picks up from 126' - 159'. The 737-800 is 129' 6", so airports that previously only served smaller 737s had to step up their firefighting capabilities.
enilria
Tue Jan 12, 2010 6:29 pm
Quoting ARFFdude (Reply 7):
The linked document shows the 737-800 is 117'5" with winglets. Any idea why the difference?
bassbonebobo
Tue Jan 12, 2010 8:48 pm
Quoting Enilria (Reply 8):
The B738 is 129' 6" long. Aircraft length is used to determine the minimum emergency handling (firefighting, etc.) capabilities of an airport. The B731 through B73G all fall into Index B (90'-126') while the B738 and B739 fall into Index C (126'-159').
Rule #176. Any device that can crawl across the table on medium, does not need to be brought into the office.
packcheer
Tue Jan 12, 2010 11:55 pm
Some of you all seem to have a great deal of knowledge so question this..
Do the 757 and 767 (and their variants) fall into the same catagories for airports?
I ask because with a similar type rating, how easy is it for an airline to switch up from a 757 to a 767 at a whim if they need it? Going down in size surely isn't a problem (if a gate/firefigting equip can handle a 767 I'm sure it could handle a 757)
Things that fly, Girls and Planes...
vikkyvik
Wed Jan 13, 2010 12:04 am
There will be a point at which longer winglets will start increasing fuel burn. At some point, the added structure (weight) to support the extra-long winglet will outweigh (no pun intended) the reduced drag.
It's similar to wing design, where you're considering wingflex, wingspan, sweep, etc. You want to arrive at the design that will end up costing you and your customers the least in the long run.
Quoting Enilria (Reply 6):
At least for 737NGs, there is an additional consideration - the maximum wingspan accomodated at gates. Many gate spacings are sized to a 117.5 foot wingspan max. If you increase your wingspan beyond that, then you've suddenly made your 737 unable to fit at a hell of a lot of gates.
arffdude
Wed Jan 13, 2010 2:37 pm
Quoting Packcheer (Reply 10):
I just checked on Boeing website and apparently the 767 is 201' 4" in length, which just barely puts it into an ARFF Index E. Index E is the most demanding index and covers aircraft greater than 200' in length.
The important thing to remember though is that the regulation states that an airport's ARFF Index is determined by the longest air carrier which it is scheduled to receive five times a day or more. This means that an airline could swap a 757 for a 767 from time to time for whatever reason, but if they want to permanently upgrade the route to a 767, the airport must upgrade its ARFF facilities.
vikkyvik
Wed Jan 13, 2010 6:30 pm
Quoting ARFFdude (Reply 12):
The 767-400 is just over 200 feet. The -300 is around 180 feet, and the 200 is around 160.
The -400 also has a greater wingspan, with the addition of raked wingtips which the -300 and -200 do not have.
Thu Jan 14, 2010 2:28 am
Out here AOCC prior to allotting the gates ensures the very aspect of Gate clearences depending on the Type Aircraft scheduled.
regds
MEL.
Users browsing this forum: 113312, LDRA, rjsampson and 3 guests
