kimon
Some Questions About Full Autoland
Sat Jan 16, 2010 7:35 am
Anyone know which aircraft have this capability?
Why is it not standard?
Dum Romae consulitur, Saguntum expugnatur
swiftski
Sat Jan 16, 2010 9:55 am
Quoting Kimon (Thread starter):
Example: Autoland is not available in Australia.
Sat Jan 16, 2010 11:10 am
My guess is that it is not standard since:
1. It costs quite a bit for an operator to maintain the ability. Pilots and aircraft need to be continually certified.
2. Weather conditions requiring full autoland are not common enough to warrant the expenditure.
David L
Sat Jan 16, 2010 11:56 am
Quoting Swiftski (Reply 1):
Doesn't it depend on the conditions? E.g. on a clear, still day, can't an autoland be conducted for currency?
cobra27
Sat Jan 16, 2010 12:23 pm
You don't have any cat 2,3 airports? What if you encounter really bad weather, altought in australia?
Sat Jan 16, 2010 12:37 pm
If they encounter really bad weather the plan is probably to wait until it clears. Strange as it may sounds, that option may be cheaper than the alternative.
mandala499
Sat Jan 16, 2010 1:34 pm
Quoting Cobra27 (Reply 4):
Same in Indonesia, we have no CAT 2/3 ILS at any airport in the country. and some still only have VORDMEs, or NDB only, and some has them but no published approach procedures.
When weather gets bad, we simply just wait. It's now monsoon season, a lot of the times, airports only get down to 2000m visibility, which means an ILS Cat 1 is enough (down to 1000m viz and/or 200ft ceiling). Some airports would be better off with Cat 2 ILS capability, but the costs aren't justified, there are simply barely any day where the airport has to close for more than 3hrs, even the worst here at the main airport (Jakarta) we've only had 1 day since it's opening where the airport is closed for more than 3-6hrs, it was an exceptional day... so why do we need Cat 3 ILS????
For Australia, again, I think it's only Cat 1 ILSes.
Quoting David L (Reply 3):
Correct me if I'm wrong (it's been a while since I read these up), but you are allowed to conduct autoland practice (on a revenue flight) on a Cat 1 ILS when:
- The weather minimas allow for standard cat 1 ILS approach.
- Approved ILS approaches only (with protected glideslope transmitter area, adequate threshold clearing height, etc)
- ATC must be notified (so that no one crosses the damn runway between you and the glide slope transmitters)...
- Deviations in the ILS approach conducted to Cat 3 limits.
- Crew must be Low Vis Ops trained and current.
- Aircraft must still be current on the Autoland.
If anyone has the details other than relying on my rusty braincells, do post it...  biggrin
longhauler
Sat Jan 16, 2010 3:20 pm
Quoting Mandala499 (Reply 6):
That's right, an autoland may be performed on any Cat1 ILS, to Cat 1 minima, with the caveat that one may have to disconnect and take over between 200' and landing.
All of our aircraft are autoland equipped except the EMJs, (which are capable, we just didn't "buy that option"). In all my years flying autoland, starting with the A300B4-203, I have never had to take over.
tdscanuck
Sat Jan 16, 2010 6:46 pm
1) It's expensive to design, build, and maintain.
2) You require specially trained and certified crews to use it.
3) Many many airports don't have the ground infrastructure to support it so, depending on your routes, it may have no value.
Tom.
voar
Sat Jan 16, 2010 7:16 pm
Quoting LongHauler (Reply 7):
Just an addition to that, The EMJs are certified for autoland (when equipped) under any weather conditions without restrictons, I believe they are the first if not only aircraft to do so (somebody correct me if I'm wrong).
411A
Sat Jan 16, 2010 8:58 pm
Countries do not specify autoland, aircraft do....in their specification.
Therefore, the statement that 'autoland is not available in Austraila'...is rubbish.
I've done many autolands in Australia, with L1011 equipment.
Fully approved.
swiftski
Sat Jan 16, 2010 9:32 pm
Refer to the SYD duststorm a couple of months ago. Diversions were required.
CAT I ILS is not Autoland approved. You can fly an autocoupled approach - a/c will capture the ILS but has to be disengaged for a manual landing. Per my manuals, CAT I is 550m and 200ft. CAT II is 300m and 100ft. In Australia there are only CAT I and CAT II ILS. Example; SYD is CAT I MEL is RWY 27 and RWY 26 are CAT II. A full (blind) Autoland (0m, 0ft) requires a CAT IIIc ILS with rollout guidance and ground radar.
There is nothing higher than a CAT II ILS in Australia.
Quoting 411A (Reply 10):
Fully approved.
Where?
411A
Sat Jan 16, 2010 11:22 pm
Quoting Swiftski (Reply 11):
Where?
MEL, PER.
The regulatory authority of the country of registration and our ops specs says we can, so we do.
Australia has no say in the matter.
There is a distinct difference between 'autoland' and a low visibility approach....IE, CATII/III.
Pros know the difference, amateurs likely don't.
donniecs
Sun Jan 17, 2010 5:53 am
I think a lot of the misunderstanding is that most people associate auto land with CAT III approaches. If the aircraft can do CAT I ILS auto land and meets the weather minima for that approach, the way I understand it is it's an option if the crew would choose to do so. Why would a regulatory body care how the plane was landed. If auto land is usually used with 0/0 weather, why wouldn't you be aloud to use it with better weather.
Especially with development and deployment of GPS/WAAS (at least here in the U.S, and in business aviation and GA right now), I don't think that GPS auto land ability is to far off. It's the future, WAAS transmitters at every airport with precession approaches to every runway, which would lead to the ability to auto land just about any runway.
Charlie - Gulfstream flight mechanic
swiftski
Sun Jan 17, 2010 7:24 am
Quoting 411A (Reply 12):
Reference: Australian AIP ENR 1.5-33
9.1
PUBLISHED ILS CAT II/III MINIMA MAY ONLY BE USED BY AIRCRAFT OPERATORS APPROVED BY (AUSTRALIAN) CIVIL AVIATION SAFETY AUTHORITY
Also, out of interest, reference: CASA CAR 179A Instrument 06/09 (12JAN09)
A380 Autoland
"An Autoland is not permitted for revenue flights"
Good discussion about Autoland is Australia can be found on this archived post.
A380 To Be Autoland Only (by Tito Feb 25 2007 in Tech Ops)
Quoting DonnieCS (Reply 13):
Maybe the 'problem' here is that my interpretation of "Full" Autoland was 0/0 - perhaps that is not what the poster was asking about.
CosmicCruiser
Sun Jan 17, 2010 9:41 am
not true
true
not true. I have charts for CATIII mins to runway 16 at MEL. ILS X 16. This would be an autoland.
Quoting Swiftski (Reply 14):
Not sure you quite understand then. Autoland is autoland. The definition may vary some from operator to operator but for us CATIII w/o rollout is a "must see to land" app; a CATIII w/ rollout does not require a see to land. I can let the jet autoland on a clear CAVOK day if I wish. As far as autoland not authorized in Australia I could find nothing to sustainuate this in the CRAR. I did find this that seems fairly standard: CAT II / III minima
Published ILS CAT II/III minima may only be used by aircraft operators approved by CASA.
Operators of Australian registered ACFT wishing to operate to CAT II/III minima outside Australia must
also make application to CASA.
swiftski
Sun Jan 17, 2010 10:28 am
Quoting CosmicCruiser (Reply 15):
not true
Here is a link to the current Information for MEL from the AIP/ERSA. Valid till 11 March 2010
http://www.airservicesaustralia.com/...rent/ersa/FAC_YMML_19-Nov-2009.pdf
Here is a link to AirServices Australia page on Melbourne Tower
http://www.airservicesaustralia.com/...cilities/towers/melbournetower.asp
I would call that a CAT IIIb
And this a CAT IIIc
Same quote as mine from above in Australian AIP ENR 1.5-33
I understand - I just assumed, for whatever reason, that the poster wanted to know about zero visibility autoland, even though he didn't specifically state so. Apologies to the OP for hijacking and taking the thread away from his question.
swiftski
Sun Jan 17, 2010 11:22 am
I stand corrected. I'm off at the moment but checked with a friend who is at work.
I don't know why the current ERSA lists as CAT II only but as you say, Jepps confirm CATIIIB ILS is available. I didn't think this had gone in yet, from memory, but it seems it has.
Sorry for that bit of misinformation.
CosmicCruiser
Sun Jan 17, 2010 11:54 am
Quoting Swiftski (Reply 16):
I may have missed something but I couldn't see any reference to CATIII notams there. Forgive me if I missed it, I'm still a little bleary eyed from 10 days on the road.
That's CATIIIa We actually refer to both designations CATIIIa = w/o rollout, CATIIIb = w/ rollout
And this a CAT IIIc
That's CATIIIb
here's a quote from our manual:
CAT III operations are normally conducted using an Alert Height (AH). Fail-operational systems have been shown to have the capability to safely deliver the aircraft to the touchdown zone if the system is still fail-operational when the aircraft passes 100 FT AGL, even if failures occur in the system after passing this height. Therefore, there is no requirement to establish external visual reference at alert height.
Notes:
Some instrument approach procedures list a visual reference required altitude of 50 for CAT III approaches, e.g. HKG. In this situation, AH procedures are used, however visual reference by 50 is required to land.
CAT III Approaches Using AH With Rollout
The Captain may continue the approach below AH provided cockpit instrumentation indicates that the aircraft will safely touch down in the touchdown zone and safely rollout. Visual reference not required prior to touchdown unless the IAP lists a visual reference altitude
CAT III Approaches Using AH Without Rollout
The Captain may continue the approach below AH provided cockpit instrumentation indicates that the aircraft will safely touch down in the touchdown zone. Visual reference required by 50 to land.
I've never seen a CATIIIC min published for any app I've ever flown
Users browsing this forum: DarkSnowyNight and 1 guest
