kimon
Any Commercial Airliners With A Steep AOA?
Wed Jan 20, 2010 8:00 am
The C-17 and C-130 have steep AOA.
Can any commerical liner do the same?
Dum Romae consulitur, Saguntum expugnatur
swiftski
Wed Jan 20, 2010 9:43 am
Quoting Kimon (Thread starter):
Angle of Attack (AoA) is controlled by pitch up/pitch down.
I presume you mean the wing design?
Wed Jan 20, 2010 10:53 am
I think Kimon means the ground angle, meaning they climb steeply.
Definitions:
- Angle of attack is the angle of the wing relative to airflow.
- Ground angle (or whatever it is called) is the angle of the wing relative to the ground.
While they may climb steeply, this doesn't mean they have exceptional angles of attack. The angle of the airflow may not be so great. Steep climbs mostly due to (lack of) weight, (excess of) thrust and lift.
High feasible angles of attack, on the other hand, depends mainly on the aerodynamics of the wing and also on whether thrust can be vectored. The intakes also need to be positioned so that they can still suck air at high AoA. This is apparent in the Eurofighter Typhoon, for example.
If you want to see some spectacular angles of attack, look no further than the X-31 program:
Photo © Thomas Merkl
Here's an in-flight pic. I believe that plane is flying horizontally at that point. The record AoA achieved was 70 degrees.
[Edited 2010-01-20 02:57:48]
[Edited 2010-01-20 02:59:30]
[Edited 2010-01-20 03:01:00]
swiftski
Wed Jan 20, 2010 10:59 am
Quoting Starlionblue (Reply 2):
Thrust really. There is more lift generated in straight and level flight than in a climb.
keta
Wed Jan 20, 2010 3:11 pm
Yes, sounds like he either misinterpreted the meaning or wasn't referring to the angle of attack. Maybe "Angle of Ascent" or "Angle of Approach"?
Where there's a will, there's a way
474218
Wed Jan 20, 2010 3:46 pm
Quoting Keta (Reply 4):
I think what he is is referring to is the "pitch angle on approach". For the average airliner is approximately 8 degrees nose up. However, the C-130 and C-17 being high wing cargo aircraft their "pitch angle on approach" is approximately 4 degrees nose down.
kimon
Wed Jan 20, 2010 5:08 pm
47218:Yes,you are right.
That is what I had in mind.
Newbie's error!
Many thanks
vikkyvik
Wed Jan 20, 2010 6:02 pm
Quoting Swiftski (Reply 3):
If I remember correctly, lift is defined as being perpendicular to the relative wind. So if you're at the same speed and AOA in a climb, then you're producing the same lift.
But yes, rate of climb is dependent on excess thrust.
Quoting 474218 (Reply 5):
Worth pointing out that that would be the opposite of what he said in the opening post. The airliners with their nose-up approaches have a higher AOA than the C-130 and C-17 with their nose-down approaches.
474218
Wed Jan 20, 2010 7:52 pm
Quoting Vikkyvik (Reply 7):
The secret was the word "steep". Even when landing most commercial look like they are trying to climb. However, when the C-130, ans C-17 appear to be in a steep dive when landing.
swiftski
Wed Jan 20, 2010 7:53 pm
Relative airflow, not wind. Sounds picky of me, I know, but it's true.
I have drawn a diagram to explain how lift is less in a climb that S&L and will upload as soon as I get to a scanner.
A346Dude
Wed Jan 20, 2010 8:15 pm
Quoting Swiftski (Reply 9):
Relative wind is a commonly used, if not entirely technical term.
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
FredT
Wed Jan 20, 2010 8:52 pm
Go to the extreme. It's often a useful exercise. In a straight vertical climb, how much lift is produced by the wing?
Then draw the vector diagram. Or find it on the net, along with an explanation.
/Fred
FredT
Wed Jan 20, 2010 8:54 pm
Quoting A346Dude (Reply 10):
But... relative to what? The wing? The fuselage? "Perpendicular to the freestream velocity vector" would cover all bases... Big grin
swiftski
Thu Jan 21, 2010 5:38 am
Not by anyone I know or fly with - it's not at all correct. In fact, when I was taught basic aerodynamics it was tripple underlined not to use the term.
The air can be completely still but if you fly through it, you still have relative airflow. No relative wind. Same, if you apply a 100kt tailwind.. the wind is actually coming from up your arse.
tdscanuck
Thu Jan 21, 2010 5:49 am
Quoting Swiftski (Reply 13):
This may be a regional thing...I've heard (and used) the term often, from two different aero engineering schools here in the US.
Quoting FredT (Reply 12):
Relative to the undisturbed flow...if you run in circles that use "relative wind" as a normal term, nobody's ambiguous about what you're talking about.
Tom.
swiftski
Thu Jan 21, 2010 5:53 am
Quoting Tdscanuck (Reply 14):
Fair enough. In this case I guess I would just respectfully disagree.
vikkyvik
Thu Jan 21, 2010 6:00 am
Quoting FredT (Reply 11):
Understood and thanks for the correction.
However, would this actually be in contradiction to what I said - that with the same AOA and speed in a climb, you're producing the same lift? I would think that, in a typical climb, you'd produce less and less lift as the climb angle increased by the AOA being reduced.
Just trying to figure this out - it's been awhile.
FredT
Thu Jan 21, 2010 6:34 pm
Quoting Vikkyvik (Reply 16):
Spot on. Either AoA or airspeed would have to be reduced, and when vertical, i e no lift generated, airspeed would have to be zero or the AoA reduced to the zero-lift AoA. It's hard to determine whether you were in fact right or wrong...  Smile
vikkyvik
Thu Jan 21, 2010 10:24 pm
Quoting FredT (Reply 17):
Haha, no worries - I readily admit I was wrong when it comes to most practical flying situations.
Theory is fun, though. Sort of like how no one is probably going to attempt taking off on a treadmill anytime soon....
Quoting Swiftski (Reply 15):
As others have stated, it seems to be a relatively common term in the US, at least. It's certainly been drilled into my head, apparently, as I used it without even thinking about it  Smile
swiftski
Thu Jan 21, 2010 11:03 pm
Quoting Vikkyvik (Reply 18):
That's fine. Like I said, I just respectfully disagree with the use of the term.
Users browsing this forum: CrimsonNL, Osiris and 3 guests
