kimon
Question Regarding AN-225 Crew Size
Fri Jan 22, 2010 11:04 pm
Does anyone know why it needs a 6-crew?
Dum Romae consulitur, Saguntum expugnatur
tdscanuck
Fri Jan 22, 2010 11:37 pm
Quoting Kimon (Thread starter):
Pilot + copilot (self explanatory)
2 flight engineers (6 engines + complex systems)
Navigator (self explanatory)
That's 5...the 6th I've found listed various as "communications specialist", which doesn't make a whole lot of sense, or "loadmaster," which makes a lot of sense.
Tom.
kimon
Fri Jan 22, 2010 11:55 pm
Great,Tom!
Have you ever seen one?
Sat Jan 23, 2010 12:25 am
My guess is that the reason for the commo guy is that the pilots probably don't speak English well. He handles ATC comms.
To expand on the navigator, the An-225 often flies non "standard" routes and goes all over the place. Navigator is a good idea. I saw a show on Antonov flight services. The dispatchers typically start route planning with a globe and a piece of string. A lot of missions are "all new" and have to be figured out from scratch, as it were.
Fabo
Sat Jan 23, 2010 1:30 am
Starlionblue: I guess that at Antonov, guys flying the An-225 know English well enough. Still, this is just the way its done in the east. If there is not a specific comm guy, navigator often takes care of radios. It is simply a way how 4+ men cockpit works.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
KELPkid
Sat Jan 23, 2010 2:14 am
Don't forget that Soviet philosophy was to gainfully employ as many as possible, (and this even extended all the way down to flight crews) so systems automation wasn't very much in favor when the AN-225 and AN-124 were designed...  twocents
tdscanuck
Sat Jan 23, 2010 2:26 am
Quoting Kimon (Reply 2):
Sort of. One attended the Abbotsford Airshow back in 1989 when I was just youngster; I didn't go to the airshow that year, but I could see the approach route from my parents' house and I saw it flying in. It looked *big* even from many miles away.
Tom.
pmk
Sat Jan 23, 2010 4:18 am
Quoting Tdscanuck (Reply 6):
One attended the Abbotsford Airshow back in 1989 ...
If you have seen one, you have seen them all.
I saw it at LAS, watched it take off from my shop on the other side of Russell Road. Looked like it was standing still when it took off. It's so large the size hides the speed.
PMK
OV735
Sat Jan 23, 2010 2:59 pm
The radio officer is responsible for air-to-ground communication with ATC - it's a tradition of the Soviet/Russian air force. The position used to exist on some civilian types as well, like the Tu-104/114/124 and Il-18/62. Western operators usually bypassed that, leaving comms for the pilots or navigator to handle.
I have no doubt that the An-225 could in reality operate with 3 cockpit crew instead of 6 (2 pilots + 1 F/E). Still, the certification requirements are kept in place in Russia and satellites, so you'll see 3-crew even in the glass-cockpit Il-96 and the fly-by-wire Tu-204.
alwaysontherun
Sat Jan 23, 2010 3:28 pm
Quoting Pmk (Reply 7):
Although I am aware that this a common phrase, technically this is not correct: one is still "being build"..........supposedly. Although that project suffers from delays somewhat, and the A-350, Y3, Boeing 797, 7-10-7 and 7-11-7 will probably hit the skies before this baby will.
It does, strange that an F-16 seems to take off faster than an A-380 for instance, while they could be doing exactly the same speed!
That always gives away remote controlled planes in them Youtube videos.
Some look very realistic, especially from a distance on a runway nicely done.......
I have seen a great A-380, B-747 and some brilliant Antanovs etc.
But the moment it takes off the sudden movements gives it away............
### "I am always on the Run"###
"Failure is not an option, it comes standard in any Windows product" - an anonymous MAC owner.
Sat Jan 23, 2010 7:30 pm
Quoting Tdscanuck (Reply 1):
Are they both working simultaneously......why.With today technology its surprising.
I'm just thinking about the number of crew for the loading  Smile
regds
MEL.
kimon
Sat Jan 23, 2010 7:35 pm
tdscanuck
Sat Jan 23, 2010 9:01 pm
Quoting HAWK21M (Reply 10):
Two major reasons: the AN-225 is not running on today's technology, and it was never a design goal for them to automate the flight engineer out of the cockpit. The plane is 20 years old, and the Russians weren't holding even with the West on flight deck automation back then. However, even if they had the technology, they had no real motivation to do so; the AN-225 was never built for the commercial environment and the concurrent pressures on crew operating costs that that entails.
Tom.
kimon
Sat Jan 23, 2010 10:24 pm
Tom,
Do you know why the opted for an ugly high-wing and weird tails?
You are right that Soviet or FSU thinking about aviation is very different to ours.
Kimon
larshjort
Sat Jan 23, 2010 10:35 pm
Quoting Kimon (Reply 13):
Tom,
Kimon
High wing to limit damage to wings and engines when taking of from gravel strips and the twin tail is because it was sdesigned to carry the Buran space shuttleso they opted twin vertical stabilizer to clear them of the turbolence.
As for the general layout it was just a upgraded An-124 to keep the cost low.
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Fabo
Sat Jan 23, 2010 11:08 pm
Well, it can sit basically centimeters from ground as high-wing. Makes loading hell of a lot easier. This aint no container hauler, remember.
kimon
Sat Jan 23, 2010 11:22 pm
The AN-225 should have been converted to a pax version.
Maybe they could have competed against the A380?
Sat Jan 23, 2010 11:34 pm
Quoting Kimon (Reply 16):
Inefficient as a pax aircraft. The configuration makes it heavy compared to an A380. Also it exceeds the 80x80 meter box allowed by most airports for pax operations. You couldn't get it to most gates and it would have a hard time taxiing in many places. This is not a (big) problem for an outsize cargo hauler, but a pax aircraft needs to be agile.
larshjort
Sun Jan 24, 2010 12:15 am
Does anyone have any information about wheel loadings? A few years ago it was in Denmark with AAL / Transport Wing Aalborg as main airport but it was decided that the runway wasn't strong enough. They then wanted to use KRP / Helikopter Wing Karup which have several times had visits from C-5/An-124's but the runway wasn't strong enough there either so they ended up cutting down some tall trees so they could use Fighter Wing Skrydstrup.
/Lars
tdscanuck
Sun Jan 24, 2010 1:36 am
Very very unlikely. In addition to the size issue, and the fact that, at that time, the Russians were not competitive on technology or automation in the commercial field, they've got a severe configuration problem. There are good reasons that essentially all large passenger jets are low-wing and all large cargo jets are high-wing. Making one do the other's job is bound to be sub-optimal.
The AN-225 is very good for its specific mission...it's just a niche mission that doesn't have a huge amount of demand.
Tom.
Sun Jan 24, 2010 5:24 am
Looking at the craft.The tremendous load encountered by the Wing root is amazing,considering the Wheels are below the fuselage only.
Any idea how frequent are the area inspections at the Wing to body attachments on this type?
regds
MEL...
kimon
Sun Jan 24, 2010 2:59 pm
AN-225:Does anyone have a photo of the flight deck?
sovietjet
Sun Jan 24, 2010 6:50 pm
The twin tails were designed because the plane was supposed to carry Buran and other components in "piggyback" configuration. The tails were made this way to avoid the wake that would be left behind by the external cargo.
747classic
Sun Jan 24, 2010 7:06 pm
Six-crew cockpit of the An-225 :
Photo © Tim De Groot - AirTeamImages
Photo © Maciek Wolanski
[Edited 2010-01-24 11:07:38]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
Mastropiero
Sun Jan 24, 2010 7:29 pm
Ok, I am sure this is a silly question, but judging by the width of the thrust levers, can a single pilot advance all six throttles at the same time? I have rather large hands and, by the size of the picture, I would have some troubles.... unless I´d rest my thumb on #1 and my pinky on #6.... maybe they are smaller than it looks in the picture?
citationjet
RE: Question Regarding AN-225 Crew Size
Sun Jan 24, 2010 9:19 pm
Quoting Mastropiero (Reply 24):
The B-52 pilots do it with eight.
Photo © Kevin Jackson
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
kimon
Sun Jan 24, 2010 10:06 pm
So on the AN-225 and B-52 no flight engineer to push the throttles like on other 3-man crew flightdecks?
citationjet
Sun Jan 24, 2010 11:55 pm
Quoting Kimon (Reply 26):
The B-52 have a crew of six. Pilot, co-pilot, flight engineer, navigator, and two EWO's I believe they are called. Only the two pilots sit near the throttles. Two crew sit further back on the same deck facing rearwards, and the other two sit on a lower deck facing forward.
Mastropiero
Mon Jan 25, 2010 12:12 am
Quoting CitationJet (Reply 25):
I can´t find too many cockpit pictures of a B-52 to prove my point, but judging by the picture you posted, the PF has his hand on a much smaller set of levers, such as the ones you can see in these shots:
Photo © Gary Chambers
Photo © Martin Eadie
This is something I don´t see on the An-225, though it is probably a silly point, probably the levers are smaller sized than they look.....  Smile
OV735
Mon Jan 25, 2010 12:41 am
The F/E has his own set of throttles on the An-225, similar to the layout on Tu-154.
747classic
Mon Jan 25, 2010 7:51 am
Quoting OV735 (Reply 29):
I cannot locate an extra set of throttles on the F/E panel on all An-225 pictures on the A-net database. Can you provide a picture of this feature.
kimon
Mon Jan 25, 2010 8:49 am
Did all Soviet airliners have this system?
Any pictures of the TU-154 F/E throttles or other Tupolevs and Ilyushins?
Many thanks
vc10
Mon Jan 25, 2010 9:00 am
Quoting CitationJet (Reply 27):
Could be wrong but I always thought the B-52 operated without a F/E
OV735
Mon Jan 25, 2010 9:50 am
Quoting 747classic (Reply 30):
Oops... I was mistaken, the An-225 indeed doesn't have a second bank of throttles. So the throttles must indeed be controlled either by the pilots of an F/E sitting between them.
Here's a shot of the engineer's panel on Tu-154, with the throttle levers in the bottom left. The left levers are those of fuel cutoff, the right ones are the throttle.
Photo © Shary - Iranian Spotters
On most Soviet transports, there is either a single throttle set between the pilots (Ilyushins, Tu-134B, An-24), whereas those aircraft with the famous "glass nose" feature two sets, one for either pilot
Photo © Pedro Augusto Branco Batista
Photo © Alexander Belenkov - St.Petersburg Spotters
747classic
Mon Jan 25, 2010 11:22 am
Quoting Vc10 (Reply 32):
Correct.
There are 5 crew members, Pilot, Copilot, Radar Navigator (Bombardier), Navigator and Electronic Warfare Officer
They used to have six when they had a tail gunner, but that was removed when they made it remotely controlled, then they took the gun out all together
see also : B-52 Crew Compliment (by Blackbird Dec 23 2006 in Military Aviation & Space Flight)
rwessel
Mon Jan 25, 2010 11:31 pm
Quoting 747classic (Reply 34):
Didn't the tail gunner get moved to the forward cabin when they went remote on the G's and H's gun (so there were still six crew)? And that position got deleted when the gun was removed?
747classic
Wed Jan 27, 2010 10:15 am
Quoting Rwessel (Reply 35):
That's fully correct. So, at present we have 5 crew on the remaining B-52H's.
kimon
Wed Jan 27, 2010 11:29 am
AN-225:most interesting!
So the F/E does not control throttles and has none of his/her own then what is his role regarding power settings takeoff and landing?
For Classic747:I noticed those vertical tape indicators on the AN-225.
I wonder if all Soviet-built aircraft switched to vertical tape indicators?
In anycase,on avioncs they lag terribly.
Users browsing this forum: QB737 and 19 guests
