kimon
Question Regarding The Term FOHE
Sat Jan 23, 2010 12:46 pm
http://www.avherald.com/h?article=42607600&opt=0
Does anyone know what this stands for?
Why are low fuel temperatures when cruising a danger?
Ditto for high fuel temperatures when cruising or does this not occur.
Many thanks,
Kimon
Dum Romae consulitur, Saguntum expugnatur
Sat Jan 23, 2010 1:15 pm
As I understand it, low temperatures can lead to fuel reaching its freezing point, which is when wax crystals form. This is probably not something you want flying around in the fuel system. Ice is not as big a problem apparently.
High temps do not occur (at least I don't think so). The air is cold even at a moderate altitude, even in the tropics.
Here's a good article on the subject: http://www.boeing.com/commercial/aer...magazine/aero_16/polar_story.html. Section three covers cold fuel management.
David L
Sat Jan 23, 2010 1:22 pm
FOHE = Fuel-Oil Heat Exchanger. It allows heat to be transferred from the hot oil to the cold fuel, cooling the oil and heating the fuel.
kimon
Sat Jan 23, 2010 1:56 pm
Starlion:thanks for the tip on Aero mag!
http://www.boeing.com/commercial/aer...zine/articles/qtr_04_09/index.html
Lots of reading ahead!
DavidL:thanks for the acronym definition!
tdscanuck
Sat Jan 23, 2010 5:27 pm
Quoting Kimon (Thread starter):
I've never heard of this happening in cruise; even on a hot day in the tropics, cruise altitude temperatures are too low.
Hot fuel can be an issue on the ground since the vapour pressure goes up with temperature and, if it gets high enough, the fuel pumps will cavitate and the suction feed won't work. This is one of the reasons that you don't usually see new jets certified to use JP-4 anymore (JP-4 has a higher vapour pressure than Jet-A).
Tom.
kimon
Sat Jan 23, 2010 6:36 pm
High fuel temps as in TWA800!
tdscanuck
Sat Jan 23, 2010 7:14 pm
Quoting Kimon (Reply 5):
The major issues vis a vis fuel on TWA800 was that the center tank was empty, which provided a very large ullage space to accumulate vapour. A full tank has much less potentially flammable space. The issue with heating in that case isn't directly the fuel temperature, but the fuel vapour that forms in the ullage. Hot fuel will vapourize more, and more quickly. If you get enough vaporization you'll go above the rich limit and be safe again. Post TWA800, the primary defense is still minimizing ignition sources. Flammability reduction (nitrogen generation systems and the like) are something of a backstop.
Tom.
kimon
Sat Jan 23, 2010 7:18 pm
Why was the CWT empty?
BMI727
Sat Jan 23, 2010 7:47 pm
Quoting Kimon (Reply 7):
JFK-CDG is a pretty short flight for a 747 and the center tank is usually the last one to be filled and the first one burned off.
Quoting David L (Reply 2):
I've always been under the impression that cooling the oil is more important than heating the fuel, and the fuel is just the most convenient heat sink.
kimon
Sat Jan 23, 2010 7:51 pm
Thanks,BMI727.
So if the CWT were filled to the brim,the question of vapourization and related problems would not arise?
tdscanuck
Sat Jan 23, 2010 8:57 pm
Quoting BMI727 (Reply 8):
For the FOHE, it's generally both...you need to cool the oil and the fuel is a convenient heat sink, but you also want to heat the fuel to melt any ice crystals before they get into the hydraulic bits. Some engines cool the oil using fan air and heat the fuel using other mechanisms.
The hydraulic oil cooler is the one where this issue usually comes up; in that case, it's all about cooling the hydraulic oil. You do happen to heat the fuel in the process, but fuel heating is not why you do it. In fact, you'd generally rather not heat the fuel in the main tanks. The FOHE heating all happens at the engine, except in a few special circumstances.
Quoting Kimon (Reply 9):
It's still there, but it's much smaller. With a full tank it takes a lot longer to heat up the fuel, so you tend not to have as much vapourization. In addition, the ullage volume is so small that you go through the rich limit quickly and aren't in the flammable zone for very long.
Tom.
Users browsing this forum: B6JFKH81, Balerit, Starlionblue, Woodreau and 4 guests
