747400sp
My Dream Ultra Super Jumbo Jet Design
Sun Feb 07, 2010 11:47 pm
I just haveing more fun with jetliners design.
I looked at how jetliner size went from DC-8 60s to 747s, and it has me thinking about, what type of jetliner would out size the A380. Seeing that it not that likely we would see a bigger airliner than the A380, I tought I just design one. Here we go, the a/c is the WW4070, she is a triple decker with the main area double deck and a 747 like hump for the triple deck area. She would be 339 ft long, with a wing span of 310 ft and a hieght of 98ft at the top of the tail. The WW4070 would have a cabin width of 30 ft on the main, deck 28ft on the second deck and 21 on the third deck. It would be powered by four engines with and 150 inch fans, let's say RR Trent 1800 or GP 92120 with thrust vectoring. It would have a wing swept of 39 degrees, and a cruising speed of mach 0.88. Now I know the WW4070 is a little over the top, but it would be cool if an airliner like this was built.
PS: My spelling check is not working.
tdscanuck
RE: My Dream Ultra Super Jumbo Jet Design
Mon Feb 08, 2010 3:23 am
Quoting 747400sp (Thread starter):
Supposing there was a market for such an aircraft, why would any engine company build such an engine, and why would you have thrust vectoring on it?
Tom.
Faro
Mon Feb 08, 2010 1:21 pm
Quoting tdscanuck (Reply 1):
Arguably, the same can be of the A380's engines. I wonder whether either engine manufacturer can count on making break-even before another 5-10 years, if ever...
Faro
The chalice not my son
Mon Feb 08, 2010 2:29 pm
Quoting Faro (Reply 2):
Well, no. The 777-300ER engines are way bigger than the 380 engines. From memory 115k lb of thrust compared to about 80k.
Faro
Mon Feb 08, 2010 2:42 pm
[quote=Starlionblue,reply=3]Quoting Faro (Reply 2):
My bad, I had the impression we were talking about new engines other than the -115B.
Faro
liedetectors
Mon Feb 08, 2010 5:31 pm
Thrust vectoring eh? Why did you not choose to make the aircraft have stealth characteristics and maybe even ejection seats?
Did I really just find this is in Tech / Ops???
If it was said by us, then it must be true.
2H4
Mon Feb 08, 2010 5:40 pm
Quoting liedetectors (Reply 5):
Some of the most creative and enjoyable threads in Tech/Ops have originated from light-hearted and over-the-top brainstorming.
Intentionally Left Blank
redflyer
Mon Feb 08, 2010 8:09 pm
Quoting 2H4 (Reply 6):
Like the infamous thread on the conveyor belt take-offs?
My other home is in the sky inside my Piper Cherokee 180.
pmk
Mon Feb 08, 2010 9:13 pm
Quoting RedFlyer (Reply 7):
Now, now...let's not get Adam and Jamie working on this one...
pmk
PMK
qslinger
Mon Feb 08, 2010 11:27 pm
Come on give him a break! In 30 years from now when someone does build a plane like that, you will be eating your words
747400Sp: How many people will your plane accommodate? my guess roughly 700 + in 3 class configuration.
Also, would thrust vectoring make do away with the rudder?
Raj Koona
747400sp
Tue Feb 09, 2010 12:17 am
747400Sp: How many people will your plane accommodate? my guess roughly 700 in 3 class configuration.
Also, would thrust vectoring make do away with the rudder? Going along the same lines, is it possible to make do without the stabilizer and rather use the bypass air from the engines to stabilize the aircraft...kinda like on the shuttle.
Quoting Qslinger (Reply 10):
Thank you Qsliinger
It will accomodate 800 + in an 3 class configuration. I did not think about the rudder, but having both trust verctoring and rudder. could not hurt to much.
tdscanuck
Tue Feb 09, 2010 2:26 am
Quoting 747400sp (Reply 11):
You'd have to rewrite the FAR's to handle it...being uncontrollable in the event of an engine failure will not please the FAA.
Tom.
metroliner
Tue Feb 09, 2010 11:15 am
Thrust vectoring?! Bonkers! But how about only having it on the outboards to maximise weight savings and to use the largest moment? I'd definitely keep the rudder... I'd be scared not having one...
Set the controls for the heart of the Sun
Marcus
Tue Feb 09, 2010 11:45 pm
If it's going to be triple deck plane I would put the flight deck between the first and second main decks like in the A380, and would turn the front section of the third deck in to a forward looking bar/lounge....either that or those would be the absolute best seats in the house....err plane.
Kids!....we are going to the happiest place on earth...TIJUANA! signed: Krusty the Clown
tdscanuck
Wed Feb 10, 2010 1:00 am
Quoting Metroliner (Reply 13):
Somebody please explain to me how having thrust vectored nozzles is lighter than a vertical fin, to say nothing of cost and/or complexity.
Tom.
2H4
Wed Feb 10, 2010 7:58 pm
....for example!
metroliner
Thu Feb 11, 2010 9:21 am
Quoting tdscanuck (Reply 15):
Well, I was just going with the spirit of the thread... I'm not in for a super-jumbo or thrust vectoring, personally.
I'm always up for bigger windows. I flew on a DC-9 recently and it was phenomenal compared to newer things...
wn700driver
Fri Feb 12, 2010 4:29 am
Quoting Marcus (Reply 14):
Not on early morning/pre-dawn eastbounds it wouldn't, lol...
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
bhill
Fri Feb 12, 2010 8:01 pm
It will need thrust vectoring to take off and land...or a really, really long runway....or...catapults...yeah...thats the ticket...
Carpe Pices
NoWorries
Sat Feb 13, 2010 1:54 pm
Well, lets take it in smaller steps; the follow on to the A388 is the A389. Putting aside economic viability, what would be the next step after that. Another stretch? A new model slightly bigger all around? Or would the next step require some really new technology -- BWB for example.
DAL7e7
Sun Feb 14, 2010 5:29 am
Quoting WN700Driver (Reply 18):
If you use the tinting system that's on the 787, it'd be just fine at all times.
Quoting Metroliner (Reply 17):
What about bus style windows? Would those have any problems on an airliner?
Would they be 360 degree vectoring or only up/down or left/right?
War Eagle!
DAL7e7
DAL7e7 is wondering... Do pilots take crash courses?
Users browsing this forum: BoeingGuy and 2 guests
