N49WA
UAL 727 Friendship - Unpainted Rudder
Sun Feb 21, 2010 4:48 pm
I've been watching some old airline/airport films on youtube and looking at photos here. I noticed that United's 727 Friendship paint scheme did not include a painted rudder. All other airlines look like they did paint the entire vertical stab and rudder (except bare metal schemes, as AA). Any particular reason?
Did a search, no joy.
If it's new and quiet, I don't want to fly it.
AirframeAS
RE: UAL 727 Friendship - Unpainted Rudder
Sun Feb 21, 2010 7:45 pm
Quoting n49wa (Thread starter):
Yeah, on the Boeings, all rudders have to be balanced when painting them. They have a ballast in them. So the weight of the paint has to be distributed across the entire rudder. The Boeing rudders, when painting them, require a RII.
The Airbuses, on the other hand, do not need to be balanced when paint is applied.
N49WA
Sun Feb 21, 2010 8:23 pm
I think I get what you describe, but what would allow for example National or Delta to paint their 727 rudders but not United? Thanks.
DL_Mech
Sun Feb 21, 2010 11:53 pm
Quoting AirframeAS (Reply 1):
I don't think the 727 has a balanced rudder. In 1991, I recall there were no restrictions in using a roller to paint out the Blue Ball on the PA 727's. I don't think this is possible with 737's, 757's and 767's unless you remove the rudder.
Photo © Bill Hough
Photo © George W. Hamlin
Here is a pic of the 727 production line:
http://www.boeing.com/companyoffices...lery/images/commercial/727-11.html
Note that none of the rudders are painted.
[Edited 2010-02-21 16:00:11]
This plane is built to withstand anything... except a bad pilot.
EMBQA
Mon Feb 22, 2010 4:21 am
I think it was just the livery style back then. I've seen a few airlines back in the early 1960's that did that.
I've been on site to see a: 767, 747-400, 747SP, 757, 737 and 727... at no time were the rudders balanced.
Making it RII is the airlines choice.. it's not a requirement...
AirframeAS
Tue Feb 23, 2010 6:06 am
Well, my understanding during my time at AS, when we remove the rudder for re-paint, I was told that the rudder had to be balanced while it was being painted (the rudder was always sitting on scales) and that it was a RII.
I am not saying anyone here is incorrect. I am saying that is what I learned when I was working on the 737's at AS. Keep in mind the rudders were composites.
[Edited 2010-02-22 22:07:27]
474218
Tue Feb 23, 2010 3:18 pm
Quoting EMBQA (Reply 4):
Rudders are balanced. Balancing is required to prevent flutter if hydraulic power or cable tension to the rudder is lost. The SRM provides details on how to ballance and re-balance the rudder.
There are provisions in the SRM for calculating the amount of added weight required after a repaint. Only when the maximum amount of allowable weight would be exceeded must the rudder be removed, striped, repainted and re-balanced.
boeing767mech
Tue Feb 23, 2010 6:40 pm
If I remember right, the 727's have a weight you can add to the forward part of the spar for a repaint. The SRM gave you the weight part number for different amounts of paint applied up to a certain amount, then you have to balance the flight control. But this is all going from memory 15 years ago working in a aviation sweat shop.
David
Never under-estimate the predictably of stupidty
AirframeAS
Tue Feb 23, 2010 8:46 pm
Quoting boeing767mech (Reply 7):
That is exactly what I meant. Thank you.
I have not touched a 737 in nearly 8-10 years now. Yes, I know...that's sad...really.
Users browsing this forum: 77west, ASMD11, Horstroad and 3 guests
