canadiantree
Question About The Boeing 757 Fuselage
Thu Feb 25, 2010 6:17 pm
Hi all,
I'm a member of a diecast aircraft forum and I posted a thread asking about the 757 fuselage. The thread kind of got out of hand with people agreeing and disagreeing so I figured this would be the place to get my answer:
IS the 757 fuselage the same in front of the wings and behind the wings (past the wing/body fairing).
I'm not super technically inclined in aviation but every photo I've seen on A.net shows that the aft portion of the 757 has a thicker vertical cross section... such as this photo:
http://www.airliners.net/photo/Condo...d=de0d8a77758fd1fad0c9778276edb2e5
People have blamed it on photo distortion, plane angle and so on so forth, here is the link to the thread, I am not sure if it's allowed to share thread links on here, if it is not mods please feel free to remove it:
http://www.diecastaircraftforum.com/...atter-behind-wings.html#post776278
Thanks for any help and clarification any of you might bring
avroarrow
RE: Question About The Boeing 757 Fuselage
Thu Feb 25, 2010 7:06 pm
Check out the 7th page of this document from Boeing.
http://www.boeing.com/commercial/airports/acaps/753sec2.pdf
It lists the external width dimension as 12' 4" and the external height as 13' 2" it does not show a separate measurement at the rear which leads me to assume that it is the same for the entire length of the tube and the percieved extra girth behind the wings is an optical illusion.
Dimensions also here:
http://www.boeing.com/commercial/757family/pf/pf_200tech.html
Give me a mile of road and I can take you a mile. Give me a mile of runway and I can show you the world.
Laddie
Thu Feb 25, 2010 8:17 pm
Quoting avroarrow (Reply 1):
That is correct. The 757's fuselage is a constant cross-section. The drawing in Canadiantree's post must be in error.
canadiantree
Thu Feb 25, 2010 8:26 pm
Thanks guys for the response. Man that is one heck of an optical illusion though isn't it? I mean to me it was like black and white that the back was thicker.
I even have 9 1:200 scale die-cast models of the 757 and they all seem to be fatter in the back too. Now I realize a model is not like the real thing but dang, I'm baffled that the dimensions are not different.
keesje
Thu Feb 25, 2010 9:18 pm
I think the 757 inherited the lower aft fuselage from the 727.
zanl188
Thu Feb 25, 2010 10:24 pm
Quoting keesje (Reply 4):
The aft pit is deeper than the front, no optical illusion.
See page 16 of this document:
Thu Feb 25, 2010 11:22 pm
So the width is the same but the height is different?
Viscount724
Thu Feb 25, 2010 11:48 pm
Quoting Starlionblue (Reply 6):
I think both dimensions are the same, at least until the rear fuselaage begins to taper upwards towards the tail.
zanl188
Fri Feb 26, 2010 12:25 am
Exactly...
Also per the document in reply 5 the aft cargo door is taller then the forward cargo door.....
zanl188
Fri Feb 26, 2010 12:34 am
FWIW: The aft fuselage of the 727 is also deeper than the forward fuselage. See the cargo pit heights on page 13 of this document:
http://www.boeing.com/commercial/airports/acaps/727sec2.pdf
boeingfixer
Fri Feb 26, 2010 12:45 am
As with the 727 the aft fuselage on the 757 is 10" deeper aft of the wing.
John
Cheers, John YYC
canadiantree
Fri Feb 26, 2010 9:53 am
OK now that it has been confirmed that the aft pit behind the wings is closer to the ground, can anyone explain why? I mean most jetliners have the same vertical cross section all along the fuselage, why not in this case? Is it an aerodynamics or weight management issue?
Is there a reason why the fuselage section in front of the wings did not benefit from the same deeper fuselage? I mean if it were, I'm assuming the 757 would've been able to carry more cargo which is why I am wondering.
Fri Feb 26, 2010 10:51 am
The fact that airliners have the same cross section is mostly to do with manufacturing ease. Aerodymanics would dictate a Whitcombe body, meaning it has to taper at both ends, sort of like the Connie.
I'm going to guess that it has something to do with area ruling.
OldAeroGuy
Fri Feb 26, 2010 4:47 pm
Quoting ZANL188 (Reply 5):
Correct.
Yes
Quoting canadiantree (Reply 11):
Quoting Starlionblue (Reply 12):
The 757 entered design using the 727 fuselage as baseline as it was originally a 727 derivative, so it had the 727 dimensions for fore and aft lower lobes. It was later decided to evaluate a deeper forebody lower lobe, ala the 737. The forward fuselage cross section decision was made to meet a manufacturing commitment before all wind tunnel testing was complete. Early indications were that if the deeper lower lobe was used for the forebody, directional stability would have been reduced to an undesireable level. When all testing was finished, it was shown that a deeper forward lobe would have been OK. Unfortunately, it was too late to revise the manufacturing plans.
I was a member of the wind tunnel testing team at the time the 757 was being developed and was aware of the situation. After the 757 was certified, I asked the 757 Chief Engineer what design decisions he would like to change with the benefit of hindsight. The forward lower lobe decision was the first on his list.
lotsamiles
Fri Feb 26, 2010 7:19 pm
The bottom of the fuselage forward of the wings is at WL 148.50
The bottom of the fuselage aft of the wings is at WL 138.50, 10 inches lower (before the taper).
The fwd cargo floor is at WL 156.80
The aft cargo floor varies from WL 144.00 from STA 1200 to 1300 up to WL 145.4 at STA 1480
HaveBlue
Sat Feb 27, 2010 1:38 am
Quoting OldAeroGuy (Reply 13):
Very interesting OldAeroGuy, thank you for sharing! Another reason I love these forums... input from people that were actually there.
Here Here for Severe Clear!
Wed Sep 22, 2010 8:59 am
This type of Information is so Important & can never be found in any Technical Books available to us AME/AMTs.
regds
MEL.
Users browsing this forum: DFWflightpath, prebennorholm, Woodreau and 17 guests
