Faro
Engine Start-up In Extreme Cold
Sun Feb 28, 2010 12:55 pm
When starting an engine in conditions of extreme cold, say below -30C, do you have to do it gradually to avoid something akin to heat shock in the combustion chamber and turbines? I had read somewhere that C-130's landing on the Antarctic ice sheet would keep their engines running on the ground for prolonged periods to avoid this kind of thing.
Faro
The chalice not my son
tdscanuck
RE: Engine Start-up In Extreme Cold
Sun Feb 28, 2010 3:27 pm
Quoting faro (Thread starter):
The details vary from aircraft to aircraft (it's in the AMM), but you basically have to warm the engine up some amount before starting it. -30C should be OK. At -35C, you're supposed to idle a CFM56-7 for 2 minutes. If you cold soak for more than an hour at -40C or lower, you're supposed to heat up the engine using a diesel heater (aka Coldbuster) or equivalent prior to starting.
Tom.
Western727
Sun Feb 28, 2010 3:39 pm
Quoting tdscanuck (Reply 1):
Good to know. Looking up the Coldbuster here:
http://www.spencer-manufacturing.com/products-coldbuster-mark4900.html
...the website does not detail how it works in terms of warming up the engines so would you mind enlightening us? I'm guessing that the famous yellow air duct that is normally channeled to the cabin for cabin heating is then bypassed within the airframe to air ducts leading to and enveloping the engine casings...?
Jack @ AUS
ex52tech
Sun Feb 28, 2010 3:50 pm
Don't know about the 130, but with any other JET ENGINE I worked with they all had their individual cold starting quirks.
The J57 on the KC135-A, or the B-52-G would sometime hang start, and this usually required heating the PS-4 bellows (burner pressure) on the fuel control, or just let it hang if you were above the starter cutout RPM.
The little I worked with the RB211-22 on the L1011 they had a bad habit of hanging during startup in the cold, accompanied by copious amounts of white smoke.
JT-8, JT-9, 2037, 4056, they all cranked up without much trouble. With the CF6 in extreme cold you usually saw extremely high oil pressure, due to the engine not having a regulated oil pressure system, and the thick oil would cause this high pressure. Nothing really came out of that high pressure, but it happened.
As far as actual maintenance manual procedures that dictated that maintenance accomplish anything other than the usual procedures for start up in extreme cold, I do not recall any on the airplanes and engines I worked on.
"Saddest thing I ever witnessed....an airplane being scrapped"
tdscanuck
Sun Feb 28, 2010 5:16 pm
Quoting western727 (Reply 2):
Nothing so exotic...you just aim the hot air duct at the offending components like a giant hair dryer. If you're trying to free the fan, just blow it in the inlet. If you're trying to warm the core, it's easier to blow it up the exhaust pipe (that way nothing bypasses the core as it would if you went in the inlet). If you need to warm up the oil tank or HMU, open up the cowls and "fire away."
Tom.
Sun Feb 28, 2010 5:28 pm
On the B757s one has to ensure the rotors are not iced up to avoid rotation.Preheating the areas with warm air is a procedure adapted.
regds
MEL.
Western727
Sun Feb 28, 2010 5:36 pm
Quoting tdscanuck (Reply 4):
This would have been awesome to see. I'm bummed I never saw this happen while living for several years at MSP and being a frequent business traveler.
Jack @ AUS
DashTrash
I think hard light offs, copious amounts of white smoke and hung starts are all side effects of having Rolls build your engines. The AE3007s do it.
I think it's 15 seconds from fuel introduction to light off max. At higher altitudes and colder temps, it's common to have the light right before you're ready to abort the start. They generally do it with a pretty loud bang, along with IMC behind the airplane. I had a line guy shut us off once thinking we had a tailpipe fire during the start.
tdscanuck
Sun Feb 28, 2010 6:55 pm
Quoting western727 (Reply 6):
The engine OEM's know that airlines hate having to do this, so they make sure the engines will play nice for the majority of the time. If you keep the engines ice-free and don't go below -40C for long periods of time, you generally don't have to deal with it.
Tom.
Western727
Sun Feb 28, 2010 10:03 pm
Quoting tdscanuck (Reply 8):
Figures. Thanks, Tom. Now, I know you're watching the USA/Canada hockey game at the moment, no? Thanks to Canuck Kane for that assist, BTW.
Jack @ AUS
pilotpip
Sun Feb 28, 2010 10:16 pm
There is no such thing as a gradual start. The starter valve is either open or closed. The FADEC might wait a moment longer when adding fuel and you will likely see things like higher than normal oil pressure for a few moments and lower than normal ITT.
While there are some special procedures as mentioned when it gets really cold, most of the time nothing is really that different. Modern airliners are made to operate within a huge range of temperature so they can service the areas of the world that are inhabited.
Remember that even with no fuel and the starter turning the engine over it will warm up due to the compression of the air going through the engine.
DMI
boeing767mech
Sun Feb 28, 2010 11:20 pm
777 with the RR Trents states in AMM NOT to advance throttle until oil temp reached 50 degrees. Have sat for 10 minutes to wait for oil to warm up, makes ATC a little upset.
David
Never under-estimate the predictably of stupidty
Tristarsteve
Mon Mar 01, 2010 4:46 am
Quoting ex52tech (Reply 3):
Yes, once had a TWA L1011 starting up that completely filled the cul-de-sac at ARN with white smoke, I had to keep the fire brigade at bay.
At M20deg, after a few days cold soak, the RB211-22B was a very slow starter. You must let the engine accelerate to max motoring speed, by then the oil pressure was off the clock high, and the oil quantity was showing zero, then turn on fuel/ign and wait 30-40 secs before the rumble started as light off was achieved. Then careful use of the enrich switch to accelerate the engine without getting overtemp.
TWA managed to get smoke on every start, but they insisted on putting fuel/ign on much too early
CanadianNorth
Mon Mar 01, 2010 7:17 am
The JT8Ds on our 732s never seem to have too much trouble starting in the cold, but if you did want to warm them I'd imagine it's much the same as tdscanuck described, fire up the old coldbuster and aim the yellow hose at the parts you want to warm...
On the 748s we have four heaters installed per side (three for the engine and one for the gearbox) and wired to a special plug on the side of the nacelle, and any time its parked out in the cold for a length of time you simply throw the engine covers on to keep the snow out and provide some form of insulation, and grab some extention cords and plug it same as you would a car. The simple system seems to keep them happy enough to start fine, and then once they're going simply idle them untill the oil temp reaches the recommended point and off you go...
CanadianNorth
HS-748, just like a 747 but better!
boeingfixer
Mon Mar 01, 2010 2:45 pm
There are only a couple things regarding cold ops on our 727's with the JT8D-15.
The start itself is just as routine as a normal start but we'll get an 'Engine Oil Filter Bypass' light on in colder temps which usually goes out within a minute or two depending on the OAT. We also let the oil temp rise to at least 0 C before moving the thrust levers.
Ah, Coldbusters.... a mechanics third hand in extreme cold conditions. Last winter I had a cold plane after a weekend layover at -36 C OAT with a windchill of -54 C. Our company policy is to start the engines and check all systems before the aircrew arrives. Well, the #3 engine oil pressure indication was stuck at 5 psi when started. The oil temps were good and the bypass light went out after 45 seconds so the oil pressure was good pointing toward a pressure transmitter problem. Dig the cold buster out, crawl on the maintenance truck, open the lower cowl and aim copious amounts of hot air onto the oil pressure transmitter. After about 15 minutes of the hot air treatment the transmitter started working. We avoided a departure delay with the use of the coldbuster.
John
Cheers, John YYC
Faro
Mon Mar 01, 2010 3:02 pm
Do FADEC-equipped engines have a special extreme cold start setting?
How much does a Coldbuster cost?
Faro
tdscanuck
Tue Mar 02, 2010 12:27 am
Quoting faro (Reply 15):
FADEC and autostart are not necessarily connected functions. As part of normal operation, the FADEC needs to know outside air temperature, so there should be start schedules programmed in there across the entire range of engine operation. Keep in mind that the FADEC can handle in-flight restarts just fine at temperatures far colder than anything you'd ever see on the ground.
Used ones online seem to be a few thousand dollars.
Tom.
KELPkid
Tue Mar 02, 2010 1:18 am
So, one must wonder what exactly the Ford 4.2L V6 in the coldbuster does...a large automotive V6 engine isn't exactly going to generate a lot of heat all by itself. I'm guessing it's more for moving the air which is heated by other means?
I know the Ford 3.8L V6 is a popular engine for ground start carts, baggage tugs, and other ground equipment usages...
I know that the Ford 3.8L V6 in my first car, a Ford Thunderbird, on a cold winter morning, didn't even produce enough excess heat to warm the inside of the car until she had been running about 10 min.    Of course, that was old school, where the thermostat had to open before hot coolant was allowed through the heater core.
stevenjehly
Tue Mar 02, 2010 5:23 pm
There are numerous and interesting stories of the old-timer Alaskan bush pilots and cold weather flying. They would often times drain the oil from the engine(s) and take the oil into their cabin or tent for the night. They would also have to keep firepots burning throughout the night under the engine(s). With great care I might add. They would also put on motor and wing covers. At times they would dilute the engines - injecting small amounts of gas into the engine oil to thin it and faciliate cold weather start. See Winging It! by Jack Jefford, pioneer Alaskan aviator for a great first-person account of early bush flying. A good read.
Sounds like a Beaver on floats to me!
boeingfixer
Tue Mar 02, 2010 6:30 pm
Quoting KELPkid (Reply 17):
Tha ColdBuster uses a water jacket over the exhaust manifold to transfer the exhaust heat to a separate water circulation system to use for heating. It heats up quite quickly as it's also driving the blower and can get 160 C air into the aircraft air distribution manifold within 5 to 10 minutes.
John
Cheers, John YYC
boeingfixer
Tue Mar 02, 2010 8:36 pm
Quoting boeingfixer (Reply 19):
The ColdBuster uses a water jacket over the exhaust manifold to transfer the exhaust heat to a separate water circulation system to use for heating. It heats up quite quickly as it's also driving the blower and can get 160 F air into the aircraft air distribution manifold within 5 to 10 minutes.
John
Just corrected my temps from Celcius to Fehrinheight.
Cheers, John YYC
KELPkid
Tue Mar 02, 2010 10:14 pm
Ah, thanks.
Always cool to learn how stuff actually works
ex52tech
Wed Mar 03, 2010 7:44 am
Even in the OLD OLD school 1966 LTD that I owned, the hot water for the heater was taken out of the intake manifold before the thermostat, so that you got heat as soon as possible. And my 93 Taurus, and my 96 F250 power stroke. I wasn't aware that it was taken from the engine anywhere else, other than before the thermostat.
I worked in MSP for years and never have seen this equipment that you guys are talking about. We just cranked them up and went to the gate, or hangar, they will warm up on the way.
MD11Engineer
Wed Mar 03, 2010 9:50 am
Quoting pilotpip (Reply 10):
Depends on what engine you are talking about. For "modern" engines (designed after the 1950s) you are correct, but with the J-33, designed in the 1940s, you have an option to use manual start, in which the pilot takes over the functions of the FCU and regulates the fuel flow from shut off to the grd idle detent by using the throttle, watching RPM and EGT like a hawk. We´ve done it when we first started my friend´s T-33. You´ll have to be careful though, since, with too much fuel, you´ll produce nice flames from the tailpipe. Once you have reached the ground idle detent, the throttle will operate just like with any other engine.
Jan
Users browsing this forum: No registered users and 22 guests
