c5load
What Are These Openings On The Belly Of The 757
Wed Mar 10, 2010 5:27 pm
What are the two small doors on each side of the red beacon strobe on the belly of this a/c? If these were APU inlet doors, wouldn't they be closed prior to taking off?
Photo © Adam Wright
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
Maverick623
RE: What Are These Openings On The Belly Of The 757
Wed Mar 10, 2010 6:10 pm
Quoting c5load (Thread starter):
Bleed air pack exhausts. They're very nice to stand under on cold days.
The APU inlet door is just below the right side of the vertical stabilizer (facing forward), and if you look closely you can see that it too is open.
The door only closes when the APU is not running.
"PHX is Phoenix, PDX is the other city" -777Way
Jetlagged
Wed Mar 10, 2010 6:42 pm
Quoting Maverick623 (Reply 1):
The packs themselves "exhaust" into the cabin and so bleed air isn't dumped directly overboard. The ram air system which cools the packs has external exhausts though.
CanadianNorth
Wed Mar 10, 2010 7:10 pm
Looks like the air conditioning pack exhaust louvres to me as well (at least thats what they are called on the 737, I don't have any 757 experience but I would think it's reasonably similar.)
As said on pretty much every modern jetliner I can think of the APU inlet door can be found up near the empenage.
CanadianNorth
What could possibly go wrong?
Mir
Wed Mar 10, 2010 7:12 pm
Only if the APU wasn't running. If the APU is running, it needs to get air somehow, and that means an open inlet door.
But, as has already been mentioned, they are related to the bleed air system and the packs, not the APU.
-Mir
DL_Mech
Wed Mar 10, 2010 9:40 pm
Here's a good view of the APU inlet on this now scrapped aircraft....
Photo © Agustin Anaya
This plane is built to withstand anything... except a bad pilot.
c5load
Wed Mar 10, 2010 10:10 pm
Quoting Mir (Reply 4):
You guys don't turn the APU off once engines are started? Isn't that kind of a waste of fuel? Once the engines are going, they will provide all the bleed air and a/c systems.
flybaurlax
Wed Mar 10, 2010 11:17 pm
Quoting c5load (Reply 6):
Most of the time they will turn the APU off during taxi, but some flights, such as ETOPS flights require the APU to be on until the aircraft are within a certain distance of their destination, or suitable alternates.
Boilerup! Go Purdue!
PGNCS
Thu Mar 11, 2010 12:11 am
Quoting jetlagged (Reply 2):
Indeed, the photo shows the AC pack cooling exhausts open (or nearly so) quite clearly.
Normally yes, however some MEL items require it to remain running throughout the flight (engine driven generator inop, for instance). If the APU is running, it's running for a reason.
Quoting flybaurLAX (Reply 7):
There are indeed times when the APU is required in flight, but we do not have to have the APU running during an ETOPS flight; it must be operational and available on ETOPS flights on the 757/767 however, and there is a program for starting the APUs in flight to test their cold-soaked starting capability in most ETOPS programs I have seen. As a very minor caveat, I have been told that at least one carrier has ETOPS 120 with the APU inop on the 767, but I have never seen that in print. If someone knows about that I'd be interested. I can definitively say that we don't keep the APU running across the ocean on ETOPS segments, however.
c5load
Thu Mar 11, 2010 12:14 am
Quoting PGNCS (Reply 8):
So the APU inlet door I see in the photo above can withstand the air during flight? I would think it'd rip right off.
PGNCS
Thu Mar 11, 2010 12:23 am
Quoting c5load (Reply 9):
Yes it can.
Mender
Thu Mar 11, 2010 12:46 am
I can't tell from that picture if the aircraft is taking off or landing.
The flaps/slats appear to be configured for take off so maybe the aircraft has pushed back from the stand and is about to turn off the APU but it could have also just landed and the pilot has just turned on the APU and he is in the process of retracting the flaps and slat. I just can't tell.
stratosphere
Thu Mar 11, 2010 4:39 am
FX actually has a 180 ETOPS with an APU inop. They run their 777's ETOPS 207.
Max Q
Thu Mar 11, 2010 4:41 am
That is not the case. Unlike lesser Aircraft (737) the 757 has more than adequate redundancy to provide for ETOPS 180 without needing the APU to be running most of the flight !
PGNCS
Thu Mar 11, 2010 5:01 am
Quoting stratosphere (Reply 12):
On the 757? I'm not doubting you, I was just restricting my answers to 757/767 aircraft.
Mir
Thu Mar 11, 2010 5:04 am
Normal ops for most operators is to have the APU off once both engines are running. But there are a variety of situations where you'd want it on, so leaving it running for takeoff is hardly uncommon.
It can withstand it, yes. On some aircraft you may see an airspeed limitation when the door is open, but it's high enough that it doesn't really affect things too badly.
-Mir
stratosphere
Thu Mar 11, 2010 5:09 am
Quoting PGNCS (Reply 14):
The only ETOPS A/C at FX are 777's...Sorry if this was only a 757/767 comparision
[Edited 2010-03-10 21:10:38]
flybaurlax
Thu Mar 11, 2010 5:18 pm
Quoting Max Q (Reply 13):
I meant to specify for the 737. I only know about ETOPS requirements for AS 737s, as I sat in on an ETOPS class, but I know it varies from each carrier as to what the FAA requires.
Thu Mar 11, 2010 5:50 pm
Photo © Søren Geertsen
A Door on the RH Empennage side of the Vertical stablizer root.When closed its flush with the fuselage.
Ram air Exhaust Louvers.
Depending on company SOP.The APU is also a extra source of Pneumatics & Electricals.
It can.....Also APU Pneumatics have height restrictions.
regds
MEL.
[Edited 2010-03-11 09:54:24]
FX772LRF
Thu Mar 11, 2010 9:51 pm
There's also a takeoff method used by some pilots called the "bleeds off" method - they use the air from the APU for pressurization instead of engine bleed air, which lets the engines use their full power for takeoff. It's used in situations such as overloaded. Not completely sure if the 757 is capable of such a thing. I know that the A319 is capable of such a thing.
I actually learned this from one of HAL's trip reports when he was at American West. Good read from a trip report and a Tech/Ops standpoint.
America West Pilot Trip Report #5 (Pics) (by HAL Feb 11 2006 in Trip Reports)
Around the area of the departure from LAS to FLL.
-Noah  wave
[Edited 2010-03-11 13:52:33]
Cleared to IAH via CLL 076 radial/BAZBL/RIICE3, up to 3k, 7k in 10, departure on 134.3, squawk 4676, Colgan 9581.
PGNCS
Thu Mar 11, 2010 10:06 pm
Quoting stratosphere (Reply 16):
No don't apologize! I am glad for the info; I am pretty familiar with 757/767 ETOPS at several carriers, and did it a lot myself in the past. I was just wanting to clarify what airplane we were talking about. Thanks for the information!
PGNCS
Thu Mar 11, 2010 10:09 pm
Quoting Mir (Reply 15):
And on other aircraft the APU is not available in flight at all (e.g. B-744, B-727), but 757/767's all have APUs capable of inflight operation.
Fri Mar 12, 2010 6:40 am
Quoting jetlagged, reply=2] cotizando Maverick623 (contestaci
[quote=PGNCS
(Reply 21):
On the B757s.....Pneumatic usage height restrictions exist.
regds
MEL.
airportugal310
Fri Mar 12, 2010 5:25 pm
Quoting FX772LRF (Reply 19):
Not too be technical or anything, but I doubt anyone is taking off overloaded. At max weight perhaps?
I sell airplanes and airplane accessories
FX772LRF
Fri Mar 12, 2010 8:51 pm
Quoting AirPortugal310 (Reply 23):
Yes, that's what I meant. I was thinking along the lines of overloaded for typical takeoff thrust configurations.
Thanks for that.
-Noah
PGNCS
Sat Mar 13, 2010 4:20 am
Quoting HAWK21M (Reply 22):
[quote=PGNCS (Reply 21):
regds
MEL.
True.
XFSUgimpLB41X
Sat Mar 13, 2010 5:57 am
In most situations we use just a "packs off" takeoff if we need a bit of extra performance out of the engines with a wider temperature margin. The cabin is unpressurized until you reach acceleration height (9 times out of 10 that's 1000 AGL) and reduce to climb power. Then you select the packs back on one at a time.
In the 757 for very high altitude takeoffs, doing a packs off takeoff may cause the cabin to exceed warning altitude, thus dropping the "orange grove" in the cabin. In this case we do an APU-to-Pack takeoff. The APU is used to supply air to one pack, and the other is shut off. The engine bleeds are shut off. It has the same effect as the packs off takeoff for performance (there is a 500 pound climb gradient penalty for the APU door being open, however).
Once you reach accel height and reduce to climb power you transfer the bleeds to the engines , turn on the other pack and shut down the APU.
Chicks dig winglets.
FlyASAGuy2005
Sun Mar 14, 2010 1:01 am
I may be way off but is this sort of the reason why the CR2 takes off with the APU running (if it's even working   )
What gets measured gets done.
XFSUgimpLB41X
Sun Mar 14, 2010 7:23 pm
Quoting FlyASAGuy2005 (Reply 27):
The 14th stage bleeds (used for anti-ice and thrust reverse) are always open on the CRJ-200, but not necessarily drawn.
The 10th stage are used for air conditioning and pressurization packs which can be provided by the APU by transferring the bleed valves to do so.
When you have to use anti-ice for takeoff, you are required to take off with the APU running and supplying the air for the packs. If the APU is deffered, you have to do a packs off takeoff and unpressurized.
Many times guys took off with the APU supplying the packs anyways just because until you get the engines up to power, they really don't put out much airflow. APU deferrals in the summer can make for a very uncomfortable taxi-out.
DC8FriendShip
Mon Mar 15, 2010 5:00 pm
[quote=XFSUgimpLB41X
(Reply 28):
There are shutoff valves for 14th stage same as tenth stage. Remember, T/R's won't work on a 200 if 14th stage is turned off.
Come fly the Friendly Skies of United
787luvr
Tue Mar 16, 2010 6:33 pm
I don't mean to veer off topic or hijack the thread but.. If you take a look at the first photo of the 787 on the far right you can see what I assume to be an exhaust port that is open, right in front of an intake. On the second photo you can see that the exhaust port is closed. Does anyone know what either of these are for and why the one is closed in the second photo. Also, with it being placed so close to the intake I'm assuming that to some extent the intake is ingesting the exhaust?
Photo © Kenneth Low
Photo © Kevin Scott - Jetwash Images
787luvr
XFSUgimpLB41X
Tue Mar 16, 2010 7:07 pm
Quoting DC8FriendShip (Reply 29):
That's what I meant when I said the valves are always selected open but not necessarily utilized.
tdscanuck
Tue Mar 16, 2010 11:20 pm
Quoting 787luvr (Reply 30):
It's not an exhaust port, it's a FOD deflector. That's the cabin air compressor inlet; the door prevents FOD from getting sucked in when you're on the ground. In the second picture, the airplane isn't on the ground so the deflector is closed (flush).
Tom.
FlyASAGuy2005
Tue Mar 16, 2010 11:59 pm
Are there any non mock-up photos of the Dreamliner flightdeck?
787luvr
Wed Mar 17, 2010 12:59 am
Quoting tdscanuck (Reply 32):
Thanks Tom! That never even crossed my mind...
787luvr
tdscanuck
Wed Mar 17, 2010 1:28 am
Quoting FlyASAGuy2005 (Reply 33):
There were some non-mockup shots from a 777 customer that got a tour in Everett that got linked from a.net a few days ago, but they got taken down.
If you go to 1:23 in the video here, you can see footage of the real flight deck:
http://787flighttest.com/gauntlet-test/
Most of the mockup shots you see are from the fixed-base simulator, which is all real hardware anyway, so in a sense it's a "real" flight deck, just with a fake view out the windows.
Tom.
Users browsing this forum: LeCoqFrancais, zanl188 and 19 guests
