airbuske
Lateral Position Of A Wing Mounted Engine
Sun Mar 28, 2010 5:32 pm
Since the advent of commerical aviation, most commerical airliners have adopted wing mounted engines. What influences the spanwise placement of the engine?
My initial thoughts:
Moving the engines further outboard puts the engines more into the "clean" free stream air and further away from the "dirty" airflow due to fuselage interference giving a potentially more efficient engine which is significantly less susceptible to FOD. The longer moment arm will also provide greater bending relief yielding a lighter wing structure. The tradeoff would be requiring a larger rudder for adequate lateral control during an engine thrust imbalance situation (Vmcg), and this of course translates into a weight penalty.
However, looking at the A330/A340 for example, the rudder on the A340 isn't significantly larger (if at all) than on it's smaller sister. So why are the engines on the A330 not at the #1 and #4 positions? After all, the old generation A340's share the same wing as the A330.
Jinal
[Edited 2010-03-28 10:42:58]
tdscanuck
RE: Lateral Position Of A Wing Mounted Engine
Sun Mar 28, 2010 6:12 pm
Quoting airbuske (Thread starter):
Tending to drive engines outboard:
-Wing bending relief
-Flutter (mass on the ends lowers the resonant frequencies)
-Ground clearance (assuming some dihedral)
-Noise
Tending to drive engines inboard:
-Adverse yaw in an engine out
-Wing stiffness
The boundary layer isn't particularly thick abeam the engines...although there's certainly some flow distortion, it's fairly easily dealt with by aiming the nacelles. This is why you often see a little bit of "toe in" on the nacelle. Note that tail-mounted engines are *far* close to the fuselage and don't really have interference issues.
The is certainly a factor.
It's more of an influence on total fin size than rudder size but this is a significant factor. This is sometimes why you see double-hinged rudders.
Because the fin on an A330/A340 isn't big enough to counter the much larger adverse yaw of an engine-out A330 if the engines were at the outboard positions.
The amount of installed thrust is always what the aircraft needs with one engine out. As a result, quads like the A340 have 133% of required thrust when all engines are operating (they drop to 100% when an engine goes out) while a twin like the A330 has 200% of required thrust.
In an engine out, the A340 has 2/3 of the thrust on one wing and 1/3 on the other, while the A330 has all of it on one wing and none on the other...thus twins tend to need considerably larger vertical fins.
Tom.
airbuske
Sun Mar 28, 2010 10:00 pm
Tom, thanks for yet another insightful reply.
Quoting tdscanuck (Reply 1):
Sorry, but I'm having difficulty understanding why the entire fin would be affected. To my understanding, *control* is independent of the stabilizer portion of the lifting surface. Unless the thrust imbalance during an engine out affects the directional stability of the airplane, I don't see how the situation would influence the vertical stabilizer. So could you please explain this further? And what is a "double-hinged rudder"?
Are you implying that if a quad on it's takeoff roll at Vmcg lost both engines on one side of the airplane, the pilot would not have sufficient rudder authority to safely control the aircraft on the ground?
Jinal
(sorry mods if this is off-topic)
474218
Sun Mar 28, 2010 11:22 pm
Quoting airbuske (Reply 2):
The forward and aft portion of the rudder deflect at different angles.
Photo © David Morrell - Avid Creations
tdscanuck
Sun Mar 28, 2010 11:37 pm
Control is a function of both. At very low speeds, the rudder alone may not have nearly enough authority on its own to counter the adverse yaw. Put in technical terms, you don't have enough control power to achieve zero sideslip when you're close to Vmca with an engine out and the other at full thrust.
When you deflect the rudder, you're basically altering the chord line of the entire vertical fin. The torque is a function of the size of the rudder, the size of the rudder deflection, and the size of the fin.
When you enter a sideslip, the restoring torque is a function of the entire surface that's at an angle of attack (normally denoted beta for sideslip), not just the rudder.
It very much affects the directional stability of the airplane. The vertical fin and rudder, in a control sense, are actuators with a finite amount of control power. If the adverse yaw from the engines exceeds the yaw capability of the fin + rudder, you will be unstable in yaw (at least in one direction). Put another way, if you're making the fin and rudder work to counter yaw, that control power is not available to provide directional stability. With enough torque from the engines, you don't have anything left to provide stability.
On a quad I'm not quite sure how the math works out, but I suspect that would be the case. On a twin, it's definitely the case. That's why V1 can never be lower than Vmcg.
Tom.
Mon Mar 29, 2010 12:04 am
I would add that the length of the aircraft also affects the required fin/rudder size. The longer the plane, the smaller the required fin/rudder, all other things being equal, because the moment arm is longer (as Archimedes knew).
That's why the 747SP has a larger fin than the 747-100/200, and a double hinged rudder.
vikkyvik
Mon Mar 29, 2010 3:20 am
-Noise
-Wing stiffness
In my aircraft design class, I asked a question of one of the professors about engine placement as it related to wing design. The relevant part of my question:
The way it would make sense to me is if, in the spreadsheet at least, engine weight simply allows for a thinner skin thickness (i.e. keeping the same bending deflection with less material).
The relevant part of his answer:
Yes - in a carefully designed wing which is equally stressed along the span, the deflected shape is a function only of the wing depth.
Now airplane wings are probably not equally stressed along the span (or are they?), but since I have no real-world experience in wing design, I was wondering how applicable that is.
tdscanuck
Mon Mar 29, 2010 4:10 am
Quoting vikkyvik (Reply 6):
They're not. For structural efficiency reasons, you want to be close, but there are other factors driving gauge beyond just loading (impact resistance, manufacturability, etc.) that will cause you to have stress drop off at the ends.
Tom.
airbuske
Mon Mar 29, 2010 7:49 am
Quoting 474218 (Reply 3):
Thanks for the image. I have previously noticed the "double-hinge" rudder on several airplanes (most noticeably on the Concorde, B747 and the A380) but have always seen it referred to as a "split" rudder.
Quoting tdscanuck (Reply 4):
That makes simple sense now. Deflecting the flapped portion of a lifting surface changes the lift distribution over the entire surface, not just over the flapped surface - so both portions each have their effective control power. The same happens to the pitching moment coefficient of the entire lifting surface (or in the case of the vertical tail, torsional moment). D'oh!
Back to the issue of an adverse yaw situation affecting directional stability : suppose an airplane is in the condition you just described i.e. engine out + full rudder such that all the "control power " is used to counter adverse yaw (zero sideslip) and none of it remains to provide directional stability. Now the same airplane experiences a gust from one side. The fin will see a change in it's angle of attack and the resultant increase in side force will, just as always, turn the airplane turn into the wind until the slip is eliminated. Or....? So how is directional stability affected?
Quoting Starlionblue (Reply 5):
I'm unsure if the relationship is as plain as you have described it. While for longer fuselages, the moment arm to the cg certainly is longer, the fuselage's contribution to directional instability is also greater. It may very well be that the end effect is what you have described because perhaps the pro usually outweighs the con - I don't know.
On a side note, while it is true that the 747SP has a larger tail, if I'm not mistaken, the double hinged rudder isn't exclusive to the variant. The split rudder is featured on every model in the family including the -8F.
As a college student myself, from the very little that I know about structural design, the wing is not stressed equally across the span. This can very easily be illustrated using the age old example of a simple cantilevered beam with a point load acting on the free end. The shear force is constant across the span however the bending moment varies linearly with the maximum value at the fixed end of the beam. As a result, the stresses (more specifically axial stresses) change across the span.
Now ofcourse the true load distribution on a wing is much more complex than that - for one, the lift is distributed across the entire span and secondly, the shape of the distribution is determined primarily by the wing's planform. And then you have the prescence of heavy objects such as fuel tanks and main landing gears which have their own intertial loading.
Theoretically, only in the case of an elliptical wing planform will the wing loading be uniform across the span. And even in this case, the shear force and bending moment vary parabolically (quadratic and cubic functions respectively). For all other planforms, the lift distribution will not be linear with the root working much harder than the tip and this just aggravates the change in stresses across the span.
Onto your question/comment about wing skin thickness and engine placement, when the wing skin is designed to serve as a load bearing member a.ka. "stressed skin", it is unlikely that placing dead weight such as engines in the wing will have any appreciable effect on the thickness of the wing cover skin panels. This is because the skin acts as the loadpath for wing torsional stresses which are relatively unaffected by inertial loading since typically, the shear center of the wing section sits at the wing's center of gravity. *waits for a B.S. flag*
Placing the dead weight in the wing will however alleviate some of the shear and axial stresses due to vertical shear load and bending moment on the wing. Lower axial stresses means smaller and lighter spar caps and spanwise flanges. Lower shear stresses means a thinner and lighter web. But to maximize on these reliefs/benefits, the dead weight items must be placed as far outboard as possible; which is part of the reason why I asked my original question about spanwise engine placement.
Jinal
[Edited 2010-03-29 00:51:10]
Mon Mar 29, 2010 9:39 am
Quoting airbuske (Reply 8):
There's a difference. A split rudder is simply a rudder in two parts for redundancy. There is a horizontal split. A double hinged rudder has a vertical split to enable further deflection. You could have a split and double-hinged rudder with four surfaces.
So while the 747SP has a double-hinged rudder the rest of the 747s have a split rudder.
musang
Mon Mar 29, 2010 11:38 am
I don't think the Concorde rudders are double hinged. There are two, so they're horizontally split.
Regards - musang
airbuske
Mon Mar 29, 2010 8:41 pm
Now I see the difference. Thanks for clearing it up. A double hinged rudder is basically a double slotted flap?
Jinal
Mon Mar 29, 2010 11:02 pm
No. A double-slotted flap is a flap with two slots (gaps) in it. A double-hinged rudder consists of one rudder mounted on the fin and a second rudder section mounted on the first.
Anyone have a good picture?
474218
Mon Mar 29, 2010 11:38 pm
Quoting airbuske (Reply 11):
Except there is no "slot".
Quoting Starlionblue (Reply 12):
Reply 3?
Mon Mar 29, 2010 11:50 pm
Quoting 474218 (Reply 13):
Reply 3?
Good point.
tdscanuck
Tue Mar 30, 2010 12:03 am
If you're at zero sideslip in the static case, you've still got some stability left. The critical case is when you're flying with some permanent beta in order to get enough torque to counter the engine. At sufficiently high torque (or sufficiently low airspeed), the vertical fin will stall before it generates enough torque to counter and you have no more directional stability. This is where Vmca comes from.
I think you're confusing equal loading with equal stress. A wing is most definitely not equally loaded, for all the reasons you suggest. However, for efficient material usage, the gauges of the structural members should be constantly changing to keep the material stresses roughly even throughout the wing. However, you can't do that 100% and there will be some parts of the wing that are operating at higher stress than others.
Tom.
vikkyvik
Tue Mar 30, 2010 12:36 am
Quoting tdscanuck (Reply 7):
Gotcha. That's sort of what I figured, but didn't know for sure.
I'm no longer a college student, but I haven't gone into the aerospace field (yet?).
airbuske
Fri Apr 02, 2010 1:52 pm
Quoting tdscanuck (Reply 15):
Tom, thanks for correcting my statement. Your post made me realize a simple but fundamental distinction in my train of thought.
Subconsciously, I was thinking along the same lines. The applied loads vary greatly across the span but the structural designer tries his best to even the stresses out. Typical examples of this are tapering spar caps along the wing span and changing the diameter and spacing of lightening holes in the shear web.
OldAeroGuy
Sat Apr 03, 2010 1:05 am
For either Twin or Quad, Vmcg and the associated V1 is defined considering only one engine inoperative. If a Quad fails two engines on the same wing is probably uncontrollable at V1.
