September11
767 Nose Cone On 777?
Tue Mar 30, 2010 4:27 pm
Photo © Ken Iwelumo - Global Aviation Images
Please take a look at the picture -- is that a 767 nose cone?
Airliners.net of the Future
Braniff747SP
RE: 767 Nose Cone On 777?
Tue Mar 30, 2010 4:31 pm
Does not look that diffrent from this pic, I think it's just badly painted, but someone with more expertise can help you more.
The 747 will always be the TRUE queen of the skies!
musang
Tue Mar 30, 2010 4:34 pm
I don't think they're interchangeable.
Its just painted inaccurately. Boeing probably painted them all with precision accuracy, but when an airline repaints, it isn't done as well and differences happen. This will be a nose transplanted off another, repainted machine. Its not just American. You see this with numerous airlines.
Regards - musang
EMBQA
Tue Mar 30, 2010 5:05 pm
The White and Red stripes on the radome are not the same width as the fuselage stripes... the blue looks to be pretty close.
Painting stripes on a radome takes a keen eye by the painter and a lot of lay-out as you are dealing with several factors and curved surfaces. It also helps to have the radome installed on the aircraft. You can lay one out in a back shop by a drawing.. most likely the case here.. and it will look like @** on the plane.
[Edited 2010-03-30 10:07:25]
timz
Tue Mar 30, 2010 5:14 pm
Quoting musang (Reply 2):
Anybody find a pic of an AA 777 with no red showing below the doors?
Looks like... 40-50 cm difference in the bottom of the red stripe? Painters do better than that, don't they?
airportugal310
Quoting EMBQA (Reply 3):
thats an understatement. FAIL job
I sell airplanes and airplane accessories
Fly2HMO
Tue Mar 30, 2010 5:29 pm
Quoting September11 (Thread starter):
Seeing that the whole nose/cockpit section in the 777 is taken directly from the 767 I would not be surprised if that is indeed from a 767.
musang
Tue Mar 30, 2010 5:38 pm
And I stand corrected, having just called maintenance. Its a different part number but some paperwork allows interchangeability.
Yours humbly - musang
boeing767mech
Tue Mar 30, 2010 6:01 pm
Quoting musang (Reply 7):
We have a note in the computer that states the radomes are interchangable if you use a certain CPN but the stripes will be approx 1 inch off depending on the airframe it is fitted on.
David
Never under-estimate the predictably of stupidty
Wed Mar 31, 2010 12:38 pm
Looks like a Radome replacement that had the painted stripes not matching....Normally the case if the Aircraft is repainted not taking into exact dimensioning of the livery.I'm sure this can be attended by a quick paint job time permitting or The original radome eturning back post repairs.
Very common with liveries that extend on to the radome.
regds
MEL.
474218
Wed Mar 31, 2010 5:23 pm
Quoting boeing767mech (Reply 8):
What do the 767 and 777 IPC say about radome interchangeability? The IPC provides the part number of the radomes and their aircraft effectivity.
UAL747
Wed Mar 31, 2010 5:57 pm
Forward sections of both the 777 and 767 are identical. Should be able to use the radomes interchangeably on both.
UAL
boeing767mech
Wed Mar 31, 2010 7:24 pm
Quoting 474218 (Reply 10):
The IPC for the 767 and the 777 both have 284T0052-39 which is the part number for a radome that fits both airframes.
Quoting HAWK21M (Reply 9):
This radome came off a 767 before being refitted to this 777
yes
David
474218
Thu Apr 01, 2010 1:48 am
Quoting boeing767mech (Reply 12):
Thanks, boeing767nmech.
This is how all of these type questions should be answered, with the facts.
Users browsing this forum: CrackInspector, seanpmassey, UltimateDelta, woodcutting and 3 guests
