c5load
Why The Extra Door On This 767 And Not This 767?
Fri Apr 02, 2010 1:39 am
I noticed the extra boarding door on the 767 that's on the left that the 767 on the right doesn't have just forward of the wing. Why? They are the same model.
Photo © Gerry Stegmeier
Photo © Gábor Vilmányi
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
unattendedbag
RE: Why The Extra Door On This 767 And Not This 767?
Fri Apr 02, 2010 1:47 am
Quoting c5load (Thread starter):
They are not the same model. They are the same series. Note one is a -3P6 and the other is a -332. They had different original owners. Those different owners bought different plane configurations hence the difference.
Slower traffic, keep right
474218
Fri Apr 02, 2010 1:51 am
It's really simple: The 767 on the left can seat 295 passengers The 767 on the right can seat 275.
[Edited 2010-04-01 18:52:48]
c5load
Fri Apr 02, 2010 1:54 am
Quoting unattendedbag (Reply 1):
So those different letters and numbers actually mean something? I had always wondered that.
Viscount724
Fri Apr 02, 2010 2:24 am
There are several optional door and emergency exit configurations on 767s. The additional doors/exits increase seating capacity due to emergency evacuation requirements. Some carriers also have a galley at the 2nd door location while others do not. Some carriers also like the extra doors so both doors can be used to speed up boarding/deplaning, especially at airports where passengers board by stairs as at many airports served by charter/leisure carriers in Europe.
Other aircraft including the 757 and 60-series DC-8s have also had a few door/emergency exit options. Some A319s with high-density seating, like those operated by EasyJet, have 2 overwing emergency exits on each side like the A320, while most A319s only have one.
A330s are also available with different types of emergency exits that affect the total seating capacity. For example, LX and LH with low-density seating configurations have a small emergency exit just behind the wing, while carriers with high-density seating layouts have a full-size door in that location.to meet evacuation requirements. You can see the difference if you enlarge the A330-300 photos below. Air Transat has about 120 more seats on their 333s than LH.
Photo © Gilbert Hechema
Photo © Thomas Rosskopf
Viscount724
Fri Apr 02, 2010 2:32 am
Quoting c5load (Reply 3):
The last 2 numbers/letters only identy the original customer. The aircraft could be identical but the customer codes will be different if they wre ordered by two different airlines. In the photos above, the -3P6 is an ex-Gulf Air aircraft (P6 is GF's Boeing customer code) and the -332 is an original DL aircraft with their 32 customer code.
[Edited 2010-04-01 19:33:09]
bohica
Fri Apr 02, 2010 4:15 am
There are three different door configurations available for the 767-300.
4 doors plus 4 overwing exits:
Photo © Ilya Morozov - Russian AviaPhoto Team
6 doors plus 2 overwing exits:
Photo © Javier Rodriguez - Iberian Spotters
8 doors, no overwing exits:
Photo © Aurélien TRANCHET
Fri Apr 02, 2010 7:39 am
No, Boeing just adds them for kicks.
Boeing codes are based on the initial customer. Airbus codes are based on the engine. This should help: http://www.rosboch.net/aviation.htm#Codes
September11
Fri Apr 02, 2010 11:53 am
Quoting Viscount724 (Reply 4):
And some First Class travelers like the extra doors between first class and coach.
Airliners.net of the Future
c5load
Sun Apr 04, 2010 1:33 pm
I would assume then that this holds true for all airplanes, not just the 767?
tdscanuck
Sun Apr 04, 2010 7:12 pm
Quoting c5load (Reply 9):
It's true that more doors/exits increases allowable seating capacity, but not all airplanes have optional exit configurations. Some of them are just "what you see is what you'll get."
Tom.
Viscount724
Sun Apr 04, 2010 8:46 pm
Not all aircraft have those types of options. The 707 had no optional door/exit arrangements if memory correct. The only differences were linked to the specific model. For example, the 707-320C with main deck cargo door had extra emergency exits just behind the wing, but that wasn't a customer option.
The Boeing 720 had one overwing emergency exit on each side, but 2 exits per side (as on the 707) was an option. If memory correct the only carrier that ordered the extra exits on their 720s was Eastern as they had at one point planned to use them in a higher-density layout but I don't think they ever did.
DC-8s prior to the -60 series also had no such options as far as I recall. Neither did the 747, except for early 747-200s where some had only one upper-deck emergency exit and could thus only carry 16 passengers in that cabin (after carriers replaced the usual F class lounge with seats in the late '70s/early '80s). Later production 742s had 2 upper deck exits and could carry about 30 passengers in that cabin. Several carriers (KL was one) modified their early 742s to add the extra upper deck exit.
