lhcvg
What Concourse Setup Works Best?
Sat Apr 10, 2010 3:42 am
Assuming land is not an issue, is the best option to do one long mega-concourse like DTW's big one, KIX, etc., or an ATL-type arrangement with many small concourses in a line out from the terminal? I'm assuming that a single terminal leading to all concourses instead of a JFK setup. I ask because on the one hand the DTW model seems very efficient and best for minimizing connection times for pax, but then again, it increases the probably of granny walking past the DL gates to the UA gates by mistake and missing her flight. The ATL-type arrangement might mitigate this by ideally making it so DL is A, UA is B, AA is C, etc., but I'm not the expert.
pgh234
RE: What Concourse Setup Works Best?
Sat Apr 10, 2010 3:54 am
PIT!
The X-shape and moving walkways are widely recognized as one of the most efficient layouts for a hub. There is never a need to change terminals and walking distances are no where near what you would find in ATL or DTW.
Alas...PIT currently sits almost empty...
SurfandSnow
Sat Apr 10, 2010 4:37 am
Quoting LHCVG (Thread starter):
This seems to be a very popular design for modern-day connecting hubs - UA at DEN, NW/DL at DTW, AA's new MIA terminal, EK at DXB, etc. For local pax, the walks to gates can be a nightmare, but connecting pax usually love these layouts - very hard to get lost!
Actually, I have a feeling the airlines just love the LAX/JFK/LHR layout - they maintain so much control over their departure areas and can keep competition out. This is also great because everyone is more spread out, and terminals are much smaller and friendlier. Imagine what a mess JFK would be if it was one centralized terminal! Of course, such a terminal would be inter-airline transfers a lot easier, but again, the airlines would much rather have you keep flying them than transfer to somebody else!
RSW is the classic example of a modern terminal built with granny in mind. Everything in one terminal, but you have several smaller concourses (instead of one really long one) to keep the walking to a minimum.
Yes, ATL and DEN have to have multiple linear concourses - one big one would be totally impractical.
Quoting pgh234 (Reply 1):
PIT!
I've never been, but I've heard PIT is fantastic. Too bad you can't fly there now unless you are actually going to Pittsburgh!
lhcvg
Sat Apr 10, 2010 4:41 am
Quoting surfandsnow (Reply 2):
All true. The reason I excluded that is because I wanted to avoid the debates over whether multiple terminals are better, because that would make the concourse discussion moot. But yes I'm sure the airlines do love it. I guess too I should have mentioned the obvious that a place like MCO (even though it has one terminal, the concourses are arranged such that it basically is like going between terminals) is great for an O&D airport, but horrible for connecting, but that each model can have it's place.
airfrnt
Sat Apr 10, 2010 4:54 am
Midfield concourses work the best for large connecting hubs. Walk to gate scenarios ala San Diego and even worse KCI are convenient for passengers, but horrific as a hub. Everything else falls between the two extremes.
EnviroTO
Sat Apr 10, 2010 5:02 am
I agree that PIT was a great hub layout and I loved flying through there except for the fact that it seemed everyone had status at that airport. ATL style concourses are likely more efficient from an aircraft perspective though. A single terminal is more efficient and unlike multi-terminal layouts handle airline growth and declines better since facilities are shared. With a multiple terminal layout like JFK airlines do have more control but are more likely to have more or less terminal than they actually need.
DCA-ROCguy
Sat Apr 10, 2010 5:41 am
A favorite A.net chestnut, always fun to discuss.
It depends on the kind of traffic the airport has. Generally concourses extending from terminals, a la LAX, are better for airports that are mostly O & D. At those airports you want to minimize walking for people arriving and departing that airport. Long mega-concourses in rows, a la ATL and DEN, are better for hub airports. At those airports, quickly and efficiently getting people between planes is most important.
A really interesting book on airport terminal design is "The Airport Passenger Terminal" by Walter Hart (New York: Wiley Interscience, 1985). It's dated, from the mid 80's, but has lots of diagrams and information. By then the science of terminal design had developed, but it was somewhat boring--then all about efficiency and tight use of space. The 90's sense of grand space hadn't come along yet.
Jim
[Edited 2010-04-09 22:43:53]
Need a new airline paint scheme? Better call Saul! (Bass that is)
antoniemey
Sat Apr 10, 2010 5:44 am
All I know is that from the standpoint of the guy working the ramp, the layout at BNA SUCKS. If you have a plane at A-1 you can't use B-3... B-3 is the hardest gate to push a plane from, so naturally DL schedules the 757s into there... And prior to it being closed, D had the worst... the doors to the ramp were all facing C, but the ramp traffic roadway ran right past D AND it faced C-4... so all the planes had to park at the end of the concourse, which meant that no matter what gate you used, you were walking along the side of the building outside to get to your plane...
I think the place was designed by drunken monkeys.
Personally, from the same perspective (guy working the ramp) I like the DEN/ATL set up... as a passenger I like the A section of DEN, but prefer IAH's C, D, & E... big so you can have lots of flights, but unless you have to go catch COEx, you don't generally have to walk too far.
Make something Idiot-proof, and the Universe will make a more inept idiot.
billreid
Sat Apr 10, 2010 5:52 am
Get serious RSW is about 99.95% short of being a hub?
If you want to go small then forget RSW and go real real small, use a box or a trailer like at William's Gateway.
DTW is terrible for pax, it goes on and on and on.
ATL, DEN and others force you to use a rail system.
SFO would be ok because its a single terminal concept, except of having to re-clear the TSA bozos when changing concourses is a pain. Same goes for BOS.
If you want a nice concept, look at CPH, MUC or AMS.
Both MUC and AMS are great as a real hubs.
CPH is very very nice as a medium sized airport.
In north america YVR is probably the smartest concept, when designing the new terminal they visited many airports and reviewed what works and what doesn't. Then they built, pretty smart if you ask me.
Some people don't get it. Business is about making MONEY!
TSS
Sat Apr 10, 2010 6:56 am
Quoting billreid (Reply 8):
Agreed.
Which is a huge drag! Also, the parking area at DEN is only convenient to one terminal.
Maybe the image I found of YVR is out of date, but in an aerial view YVR appears to have started off as a widened "X" terminal layout that was randomly and meanderingly expanded several times toward the North. While I can understand having to work with what you've got due to money and space constraints, I wouldn't have called YVR's layout a shining example of good terminal design. In fact, the way the concourses seem to sprout off in random directions reminds me very much of LHR.
Quoting Antoniemey (Reply 7):
(I) prefer IAH's C, D, & E... big so you can have lots of flights, but unless you have to go catch COEx, you don't generally have to walk too far.
As do I. The easternmost terminal at PHX is basically the same design as IAH, with parking in the middle of the terminals, the terminals in between and parallel to the runways, and concourses perpendicular to the terminals so the walk from one concourse to another when connecting isn't too long. Also, this simple, straightforward terminal design is easy to expand: Just extend the terminal(s) at either end and add concourses and additional parking structures as needed
Osubuckeyes
Sat Apr 10, 2010 7:07 am
While ATL, DEN, and DTW are really easy due to the midfield terminal layout, I think that PHX works really well in combining O and D passengers with connecting passengers. Its not too far to walk curb to gate especially when in terminals 2 or 3, and connecting in 4 is not as bad compared to some other aiports such as MSP, ORD, DFW where it seems like you just walk for ever. Having said that PIT is definitely the best layout but unfortunately it is no longer a hub.
wilsonleiser
Sat Apr 10, 2010 8:22 am
Agreed. Those are exactly the airports that came to mind. AMS is extremely efficient and predictable as far as connecting times. These are by far the top 3 airports I've been to.
airbazar
Sat Apr 10, 2010 12:59 pm
I don't disagree entirely however, DTW goes on and on as much as AMS or MUC if you're unlucky to have to connect between 2 flights at opposite ends of the airport   Sometimes I wish AMS had a rail system to connect from concourse B or C all the way to E or F. I've walked that a few times and it's a looooooong walk. At MUC, once I arrived at one of the gates at one end to connect to a US bound flight at the complete opposite end of the terminal.
Although I love MUC and AMS alike I think the mid field concourse design like DEN and ATL and IAD is best suited for a large hub. In fact that's exactly where MUC is headed. Although it gives the appearance of 2 seperate terminals it functions very much like ATL or DEN or IAD except connecting from T1 to T2 is not as convenient. In the future I wouldn't be surprised to see them add another parallel concourse/terminal.
Lufthansa411
Sat Apr 10, 2010 1:28 pm
My vote is for TXL. It is designed purely for O&D, although that makes it perfect for the city. Most of the time, I can go from sitting on the a/c to sitting on the TXL express bus in about 3 minutes. It's really a dream. Plus, with the individual gates, you can clear security just before boarding time, which you can see through the glass windows. Absolutely amazing design.
To bad it will soon close.
I would agree. It is not a coincidence that these airports usually win all sorts of awards for their design. They are simply laid out, which makes for a simple way of figuring out where you need to go, even when you are pressed for time.
Nothing in life is to be feared; it is only to be understood.
Web500sjc
Sun Apr 11, 2010 3:39 am
I am about to light off a firestorm but, I thInk T5 at LHR ( just T5) is a good lay out, you don't have to move far everything is all in one place- up untill you are about to board, which by that time you have everything done.
Another good airport would be IND, or DEN: I wouldn't put ATL in that catagory, it is just too crowded cramped and hard a place to get around (although it might be just my luck that my flight always gets in at the end of one concourse and then I connect to a flight that is at the end of another concourse.
PHL I would say is not one of the best airport configs, it seams chaotic and dingey. At CDG, although I do like T1, it is a complete mess, as opposed to Tye other 6 or 7 terminals collectively called T2, which I despise but is very practical for their job.
Boiler Up!
Faro
Mon Apr 12, 2010 7:06 am
On the technical side, what concourse layout gives the maximum number of gates (or pax capacity) per unit of paved apron area? Some layouts seem very wasteful of concrete like DFW.
Faro
The chalice not my son
cloudboy
Thu May 13, 2010 2:28 am
I am not convinced that DEN is as great as it is often made out to be. It might be space efficient, but there is a problem with the multi-linear concourse design - it takes forever to get to your gate. For those people who aren't frequent flies, have tight connections, or just plain get easily confused it is a royal pain. There is nothing to differentiate one gate from the other, or even one concourse from another. And while it is all nice and open and airy, it's rather, well, dull. DTW is even worse in this - I often end up three fourths of the way down one end of the terminal and my connection is three fourths the way at the other end. And you dont know whether it is more efficient to take the tram or just hoof it. Den doesn't have too many tie-ups from planes having to wait to leave the gate while another is towed out, but this happens all the time in ATL.
I know it is less efficient, but I like the pier-style terminals better.
"Six becoming three doesn't create more Americans that want to fly." -Adam Pilarski
Mir
Fri May 14, 2010 12:15 am
Quoting cloudboy (Reply 16):
This is just because of more ramp space between concourses. At DEN, you can push a plane back from the gate and not have it interfere with aircraft taxiing behind. That's not the case at ATL, so you might have to wait.
That's going to be true regardless of what setup you use - the more space between concourses (or piers, or whatever), the less time you'll have to spend waiting for other aircraft to clear so that you can get to or from your gate.
-Mir
Web500sjc
Fri May 14, 2010 4:52 am
if you want a pier system that is a mess Try LAX, that was an airport where the piers are to close
together. I once arrived on the ground 15min early but was 40 min late due to aircraft having to be pushed back and then us having to get in.
Boiler Up!
88Wayz
Fri May 14, 2010 6:13 pm
As an outsider looking in, I guess it would really depend on the size of the operation as to what setup works the best. I reckon that the main source of ire for ATL is that it is so busy. Having said that, I loved the setup at DTW's WorldGateway (McNamara Terminal?)...it had a tram inside the building, which I suppose is needed when the terminal's a mile or so long. Seemed very efficient to me, for those who needed to catch flights out of that terminal. Never did have to go over to (what I believe is) the B terminal, so I can't speak for connections from there to either the McNamara or the NW regional terminal.
The one that never made sense to me was CVG...having to go outside and get on buses to drive you to other parts of the airport (PHL is like this too)...soon as the bus gets held up by a taxiing/pushing aircraft, the passengers get held up from making their connections. On the one hand, I suppose it'd be cool for the passengers to see all that stuff out on the apron up close and personal, but I can't imagine running all those buses all over the tarmac would be all that efficient, cost-wise.
Which brings me to PIT...former workplace of mine. Probably the most efficient set-up I've seen stateside. One tram, from the landside terminal to the airside X. (Many people tend to forget the USAir regional terminal that sits up there on the B/C side of the X.) From the ramper's perspective, it was also quite efficient, as the tunnel that ran from the bag room out to airside ran right up under that regional terminal...which now probably has a bunch of rats running around inside of it. Such a shame that airport is close to a ghost town now.
usscvr
Tue May 25, 2010 11:18 am
One of the most practical rules of any business, widgets or airlines, is that it is less expensive to keep a customer than it is to conquest, or recapture, a customer. Having said that, I feel that it has more to do with exclusivity and branding than pax conveniences - although I am sure pax convenience certainly plays a part in the design.
Using UA at ORD for example, when pax depart a UA flight into the terminal, unless they leave the terminal they remain in a UA branded area. Exclusivity and branding pays dividends for future customer pay opportunities.
A:319/320/321/332/333||B:717/721/722/735/737/738/739/742/744/753/762/763/772/773/787||DC8/9/MD80/GF14/C5/C130/C141
