PPVRA
Canards And Airliners
Tue Apr 13, 2010 2:38 am
We've seen pretty much all major commercial aircraft manufacturers crunch engineering formulas to stretch out some of their products, at times to what look like extremes. And sometimes, with brand new wings. But why not simply add canards? Stretch the fuselage in front of the wings, add a pair of canards like the Sonic Cruiser, and end of story. Sure you probably need some structural re-enforcements for the canard, but are they that difficult? I feel like I am missing something. Will flight control software need to be changed significantly from standard, non-canard aircraft, thus making it uneconomical?
"If goods do not cross borders, soldiers will" - Frederic Bastiat
GolfOscarDelta
RE: Canards And Airliners
Tue Apr 13, 2010 3:42 am
You mean like this:
Photo © Oleg V. Belyakov
From what i've read, Canards seem to have the following drawbacks
1. No Clean stall break (=> FAA won't certify) (Starship)
2. Very limited CG range (Starship and Avanti)
3. Complex flaps on the canard (Avanti) / movable canards (Starship) required to match moment/lift from deploying flaps on wings
4. From an operational perspective it may interfere with gate operation.
The main reason to use a canard would be to
1. Stall Proof the aircraft: i.e. prevent unintentional stalling by large AoA's, i think most of the new FBW aircraft have enough flight envelope protection that having a canard to do that is unnecessary, also, a canard by stall proofing the aircraft doesn't allow the wing to reach its maximum Cl.
2. Eliminate down force and make wing smaller by creating a lift based trimming forces: Nowadays in most cases airliners are pretty well trimmed with load and fuel and the tail produces little down force in cruise and i'm not sure that the advantages offered by a canard outweigh the drawbacks they impose.
I'm sure the more experienced folks around here will add a whole buncha more reasons to this and correct any fallacies i may have made.
[Edited 2010-04-12 20:43:25]
tdscanuck
Tue Apr 13, 2010 5:12 am
Quoting PPVRA (Thread starter):
As a retrofit option, you're talking about running primary lift structure though one of the most densely packed portions of the airplane...you're going to have to do massive modification to the flight deck, EE bay, crew rest, or the premium cabin. None of those are particularly appealing options.
It would need changing, but the change wouldn't be that much worse than what you have to do with a big stretch anyway, so I can't see that being the major obstacle.
Quoting GolfOscarDelta (Reply 1):
As a retrofit, you'd avoid a lot of these issues because you'd still have the tail (fixes the stall and CG issues). The problem, I suspect, is that the extra work of a whole new lifting surface doesn't come close to passing up a simple tweak to the existing stuff.
Tom.
rwessel
Tue Apr 13, 2010 5:48 am
I think you're talking about a three-surface arrangement like on the Piaggio Avanti. In that case the forward wing isn't really a canard, rather it's actually a forward wing. Call it a biplane with a ridiculous amount of stagger.
In the case of the Avanti, you also get all three surfaces lifting, and the forward wing has no control surfaces, which keeps it simple. Conceptually, this might make a decent airliner design (it certainly works well for Piaggo!), but as a retrofit it would be fairly radical.
For a stretch, if you can find a place to mount the forward wing that doesn't generate a host of secondary problems (how's this thing going to fit into a typical gate?), it wouldn't be impossible. You would end up redoing the horizontal stabilizer and elevators, and the exact places you'd stretch to fuselage is an interesting question. You'd probably have to increase the size of the vertical stab as well, particularly if you now grew the forward fueselage more than you would in a more convention stretch.
The question is how much less work this would be than a wing extension.
But the Avanti had somewhat different goals and problems to solve - most notably the normal position for a wing on a bizjet is in a darn inconvenient spot - just look at the massive fuselage fairings around most bizjet wings. By going to a three surface arrangement Piaggo was able to mount the wing in a fairly ideal "mid" position while doing a good job area-ruling the interface, and still provide a larger than normal cabin. An airliner stretch is not going to be able to make use of any of those (and in fact, the forward wing will almost certainly get in the way of something).
swiftski
Tue Apr 13, 2010 3:10 pm
Stall proof in a way, yes. But consider pulling out of a dive - high speed stalling. Canard will stall first, forcing nose down again.
PPVRA
Tue Apr 13, 2010 3:36 pm
Thanks for the responses everyone!
I guess if (and that's a big if) one wants to go in this direction, it's best to plan it out starting at the clean sheet stage. As for the gate space problem, could a moving system be implemented to resolve this without adding much weight? Folding, contracting, spinning (in case it is located above the fuselage). . ?
Quoting rwessel (Reply 3):
Either one, really. Just thinking of simplifying stretches or possibly taking stretches even further than what is done today.
tdscanuck
Tue Apr 13, 2010 4:01 pm
Quoting PPVRA (Reply 5):
Agreed.
Technically, yes. This is exactly the situation that initially came up with the 777 regarding the wing tips. The fact that nobody took the folding option and elected to deal with it at the airport infrastructure end is probably very telling for the canard situation as well.
I think the problem is that, if it's a simple stretch, it's a lot easier to just tweak the existing surfaces than add a new one. And, if you're going for an even farther stretch (beyond what you can do today), you're committed to redesigning the fuselage structure anyway, so there's nothing really driving you towards a canard.
Tom.
rwessel
Tue Apr 13, 2010 8:20 pm
Quoting swiftski (Reply 4):
That's only a matter of degree - yes, the canard design will likely stall the front wing with the main wing at a slightly lower alpha than a conventional design. That just means you have a bit less alpha to pull at any time, not just when pulling out of a dive. Conversely, the increased lift from the canard design will help you pull out of the dive, so frankly, it could probably go either way, depending on the exact design.
Nor is the net effect any different than stalling a conventional design in the pullout from a dive - in either case, once you exceed the alpha limit, you're going to stall, and the nose will drop.
And this is only really an issue for fairly low speed dive recoveries - once you actually get to high speeds, you're going to hit your G limits long before you hit your alpha limits.
And just for the record, I detest the whole "accelerated stall" concept. IMO there are many pilots (and passengers) who have ended up dead because we teach this idiotic notion that stalling is principally related to airspeed (unless it’s, *gasp*, an *accelerated* stall!). Of course we do that because the vast majority of airplanes don't have AoA indicators (and frankly those should be an equal, or maybe even higher, priority than airspeed indicators). But that's a personal hobbyhorse, and not really relevant to the thread...
PPVRA
Tue Apr 13, 2010 10:39 pm
I just noticed that the Tu-144 pictured above does have a folding canard. Didn't realize that at first.
Quoting tdscanuck (Reply 6):
Good point. On the other hand, the new A/B short/medium haul products appear to be growing in size, which could pose a bigger challenge to airport gate space than the 777 did just based on the number of 737 movements they see everyday, and into smaller gate spaces. Also, the 777's wingspan seems to be just slightly longer than the 747, which would make the airlines' choice of not going with the folding wingtips make a lot of sense. Move things around a bit and you can squeeze in an extra 40cm of wing.
With that said, folding wingtips sounds more complicated than shorter wings + a folding canard (or small forward wing as stated above) near the fuselage. I'm thinking of fitting all that heavy mechanic stuff all the way down the wing. . .eek.
[Edited 2010-04-13 15:44:16]
PPVRA
Tue Apr 13, 2010 11:56 pm
Quoting PPVRA (Reply 8):
With that, of course, I assume so will wingspans. There have even been hints at twin-aisles, so space is tightening up
PPVRA
Wed Apr 14, 2010 6:24 pm
This is probably even more far fetched, but is there any chance of we seeing morphing materials in civil aircraft any time soon? i.e., less than 20 years? I'd imagine that applying it for things like winglets and such would be fairly conservative and safe?
avt007
Wed Apr 14, 2010 7:28 pm
As mentioned above, you'd have to enlarge the vertical stab, or add strakes, and pretty soon, you're flying a Beech 1900D.
tdscanuck
Thu Apr 15, 2010 6:55 am
Quoting PPVRA (Reply 10):
I'm pretty sure that the temperature sensitive nacelle chevrons are close to production...so yes.
Tom.
cobra27
Thu Apr 15, 2010 11:06 pm
Avanti doesn't have a reasuring look for me. It seems it to be harder to fly, but am sure its not true.
But is the most economical bussines plane out there, with 700 km/h speed and about half of fuel consumption of kingair.
rwessel
Fri Apr 16, 2010 2:42 am
Quoting cobra27 (Reply 13):
FWIW, I've never heard a negative comment about the Avanti's handling...
Users browsing this forum: flyDTW1992, sadiqutp and 1 guest
