justloveplanes
Volcanic Ash And Newer GE, Trent's And Pratts
Fri Apr 16, 2010 11:39 am
Has any of the newer engine designs incorporated resistance to volcanic ash ingestion in any way? Appropriate topic these days........ Wondering if the larger engines like the GE-90's are more resistant
LMP737
RE: Volcanic Ash And Newer GE, Trent's And Pratts
Fri Apr 16, 2010 2:34 pm
Nope, any ash sucked into a Trent, GE-90 or PW 4000 will make a mess just like it would on an older engine.
litz
Fri Apr 16, 2010 5:06 pm
Had I to guess (and since I'm by no means a propulsion engineer, this IS a guess) ... I'd say the newer engines are manufactured with tighter tolerances, to allow then to achieve the efficiencies they do ... and with that in mind, congealed ash inside the "hot" parts of the engine are going to be more damaging to a newer engine.
That stuff melts and coats everything w/a layer of silica (glass) ...
Remember Cash 4 Clunkers and what that stuff did to the car engines the gov't mandated be destroyed?
Picture that inside a jet engine ...
- _litz
prebennorholm
Fri Apr 16, 2010 11:05 pm
There is no way to make any turbine engine resistant to volcanic ash.
The main problem is that the ash melts in the combustion chambres, but when it hit the turbines, then it has been mixed with cold air so it "freezes" as glass on the turbine blades.
In addition it works as sandblasting the fan and compressor blades, and the whole exterior of the plane, including the front office windows.
So even if the ash cloud may be so thin that it causes no immediate "danger" for flight, then it is so damaging to the planes that flight becomes economically crazy.
Yesterday I saw the only viably solution to the problem in an email from Germany: Iceland equips all their volcanoes with filters.
justloveplanes
Fri Apr 16, 2010 11:23 pm
I guess the question is not immunity, but damage tolerance and still keep flying. For example, one failure mode was the fuel nozzles clogging. The two 747's that survived did have all four engines shut down, and in both cases, all 4 were eventually restarted to land safely.
pilotpip
Sat Apr 17, 2010 4:00 am
Even if you did make "ash proof" engines you'd still have a windscreen and leading surfaces that end up being trashed so bad the aircraft wouldn't be safe.
Quoting prebennorholm (Reply 3):
Funny!
DMI
boeingfixer
Sat Apr 17, 2010 4:24 am
Quoting justloveplanes (Reply 4):
Where did you get this info from? Fuel nozzles don't clog from the volcanic ash. The problem is down stream from the nozzles where the combustion heat turns the ash into glass.
The main failure point in turbine engines from volcanic ash is the accretion of glass particles on the nozzle guide vanes and turbine blades. This results in greatly reduced turbine efficiency and corresponding increase of EGT.
Cheers, John YYC
Sampson777
Sat Apr 17, 2010 4:26 am
Hello there, found a link that you may find interesting
Flight Operations Briefing Notes --> Operating Environment -->Volcanic Ash Awareness
http://www.airbus.com/fileadmin/medi...fetyLib_-FLT_OPS-OPS_ENV-SEQ06.pdf
Figure 3 on Page 4 details the effects of ash on aircraft engines.
Making Mom proud since 1989
justloveplanes
Sat Apr 17, 2010 5:07 am
Quoting boeingfixer (Reply 6):
Found it in one of the recent threads on web. I"ll look for a link...
9VSIO
Sat Apr 17, 2010 5:33 am
Would it affect piston engines?
Me: (Lining up on final) I shall now select an aiming point. || Instructor: Well, I hope it's the runway...
Woosie
Sat Apr 17, 2010 6:21 am
"Would it affect piston engines?" I would think so, as the particle size is small enough to be normal aspirated into the combustion chamber. Not sure though.
justloveplanes
Sat Apr 17, 2010 9:47 am
Quoting justloveplanes (Reply 8):
http://www.cbsnews.com/stories/2010/...4/15/ap/national/main6400175.shtml
This link as well as several others mention clogging fuel nozzles. Googling "volcanic ash turbine fuel nozzle" gives several. They may be repeating each other, text looks similar....
MarkC
Sat Apr 17, 2010 2:06 pm
Clogging the feul nozzles puzzles me also. I am well aware of their design, and how they fit into the engine. Obviously, these are at a very low temp, and molten ash would solidify on them, but, I would think it would be on the exterior, not on the outflow of the nozzle itself. I also would not think that the high compressor would not be able to heat the ash to a high enough temperature so that deposits would form on the nozzles.
The Nozzle guide vanes, and the HPT blades, are more likely. I have seen fine sand damage, and its probably the same symptom. The newer the engine, the more air is bled to cool the turbine blades and vanes. This is where sand and ash create big problems leading to excessive temperatures.
I really wonder what the exact mechanism of engines failing when going though an ash could. Does anyone know. I have a hard time believing its clogged nozzles. Is it the computer shutting the engine down because of over temp. This meaning the cooling is not working. I would believe that. Not much other particualte matter is going to stop a jet engine from running.
jetlife2
Sat Apr 17, 2010 8:42 pm
The GE90 has design features that direct a high fraction of particulates away from the booster (spinner and splitter design), and away from the HPC (VBV design). Material is ejected into the fan stream. As a result of this design, the level of erosion (from sand etc.) experienced in the HPC is low compared to earlier generation engines.
This design would also be beneficial in reducing the fraction of ash particulates introduced into the core. Neverthless, it is not eliminated and some will still enter. From that point on the effects would be the same.
My views are not necessarily the views of the GE Company
Fly2HMO
Sat Apr 17, 2010 10:45 pm
Quoting Woosie (Reply 10):
I would think not, or to a lesser extent at least. Even relatively high flow filters are pretty good at controlling super fine talcum-like dusts. But the filter would surely clog up quick in more dense ash.
Nicoeddf
Sat Apr 17, 2010 10:49 pm
Quoting jetlife2 (Reply 13):
Actually, I cannot really see where spinner and splitter design differ significantly from other modern turbofans.
Any details you might share?
Also I fail to see, where the design of the VBVs can help in eject material into the fan system?
They way I see it, hard particles in the air stream are distributed equally across the crosssection (of course not in the case of single stones or other larger hard bodies). So in effect, bleeding off part of the core stream into the fan stream will reduce hard particles proportionally.
I can't see where this is any different to CF6-80s VBV design.
Where am I wrong?
rgrds,
Nicolas
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
MD-90
Sat Apr 17, 2010 11:16 pm
I think the proper question is how long would the air filter last before becoming clogged? Ash shouldn't be able to make it past the filter so getting it inside the engine shouldn't be an issue.
Woosie
Sun Apr 18, 2010 12:07 am
Quoting MD-90 (Reply 16):
Not knowing a ton about piston engines, I was unaware that they use air filters. Makes sense but don't recall air filter cannisters, etc... I've only worked on a Mallard seaplane, which uses large radial piston engines. Thanks for the correction.
jetlife2
Sun Apr 18, 2010 12:09 am
Quoting NicoEDDF (Reply 15):
The architecture is the same but the trajectories taken by particles are very different. Compare the two cross sections and imagine a particle... trace the angles from the front of the spinner, and between the booster and HPC, and you will see the differences in both areas. Also, particles are not evenly distributed across the cross section once they have entered the engine. The air flow imparts a radial outward velocity and particles thus favor the outer diameter. So by preferentially orientating the VBV door entrances and curve of the passage, heavier particles are removed in a way that does not occur on other engines.
Fly2HMO
Sun Apr 18, 2010 1:03 am
Quoting Woosie (Reply 17):
I may be wrong but I don't think I've ever seen a larger piston engine plane (radials or anything more than 6cyl) with a filter system. I'm assuming it's due to the much higher airflows required for those big engines.
Almost all light GA, twins, and high performance GA planes with 4 or 6 cylinder boxer engines have them however.
justloveplanes
Sun Apr 18, 2010 10:08 am
Quoting jetlife2 (Reply 18):
Tim Clark of EK said one of the things that was good about their 77W's was the lack of any performance degradation after 8 months, which he termed exceptional. Perhaps some of this due to the cleaner air flow to the core.
jetlife2
Sun Apr 18, 2010 2:16 pm
Quoting justloveplanes (Reply 20):
Yes that's right. Amongst other things designed to keep the engine the way it left the factory, as long as possible. Core degradation, including among other things compressor erosion, is a big player in fuel burn deterioration.
DocLightning
Tue Apr 20, 2010 7:45 am
Wait, if an engine has to pass a sand ingestion test, why is volcanic ash different?
-Doc Lightning-
-Carl Sagan
justloveplanes
Tue Apr 20, 2010 8:51 am
Quoting DocLightning (Reply 22):
Volcanic ash melts and forms glass (raw material = Silicon) and coats parts at high turbine temperatures. Obsidian FYI is sometimes termed volcanic glass.
Sand I am guessing stays more intact. Sand is mostly SiO2 (silicon dioxide), which is already reacted Silicon in a stable form, whereas volcanic ash is (apparently) a more volatile/reactive form.
DocLightning
Tue Apr 20, 2010 8:19 pm
Quoting justloveplanes (Reply 23):
that makes sense. Does sand have a higher melting temperature?
-Doc Lightning-
-Carl Sagan
KELPkid
Tue Apr 20, 2010 8:22 pm
Quoting 9VSIO (Reply 9):
Reply 9, posted Fri Apr 16 2010 22:33:03 your local time (3 days 14 hours 46 minutes ago) and read 1595 times:
Yes, mostly by clogging the air filter...and if you turned on carb heat or opened the alternate air intake, you would ruin the engine (just like dumping sand down the crankcase  Wow! ). In addition, the prop, windshield, and leading edges and antennas would all suffer severe abrasion damage if you flew through an ash cloud.
jetlife2
Wed Apr 21, 2010 1:38 am
DocLightning -- Certified Mad Doctor
There is no sand ingestion test.
akiss20
Wed Apr 21, 2010 5:18 am
El GE90 tiene caracter
Quoting DocLightning (Reply 24):
Standard SiO2 sand has a melting temp of about 1300-1500 degrees C. Volcanic ash is more around 1100
Quoting jetlife2 (Reply 26):
May not be required but http://www.youtube.com/watch?v=IMIkk-ZqUzM those guys sure did one...
Change will not come if we wait for some other person or some other time. We are the ones we've been waiting for. We are
777wt
Wed Apr 21, 2010 7:44 am
MarkC
Wed Apr 21, 2010 1:38 pm
Sand does the same thing. High altitude fine sand. I have seen the internals of a middle east PW4000 operator. They show the long term effects of fine sand damage.
The ash clouds that can shut down an engine have to be much more concentrated.
I just saw the CFM explaination of how ash can shut down the engine in "Flight Global", and I believe that one. Nothing to do with clogged fuel nozzles. Everything to do with deposits on the nozzle guide vanes.
Users browsing this forum: Arniepie, CrimsonNL and 1 guest
