aerdingus
TU 204/TU-154 Landing Gear
Tue Apr 20, 2010 11:57 am
Hi, just a quick question, I woke up in the middle of the night wondering about this. Why was the TU-204 not built with the same type gear as the -154? Was the -154 heavier, with the third engine? I looked at the Tuploev website and the max t/o weight for both families is roughly around the same-104-110t. Is it maybe because the rough runways which Soviet aircraft had to work with are being upgraded and modernised?
I think both aircraft are beautiful, and it's sad to see the TU-154 kind of disappearing.
2016: BHX GLA KIR LCY LGW MUC VIE BA EI FR LH OS A320 A321 ATR 42 ATR 72 B738 E190 E195
Jetlagged
RE: TU 204/TU-154 Landing Gear
Tue Apr 20, 2010 2:50 pm
The Tu-154 was designed to operate from poorly prepared runways, hence the six wheel bogies to spread the load. I doubt that was a design requirement for the Tu-204. The pylon mounted engines of the Tu-204 would have made the pod mounted main gear arrangement of the Tu-154 awkward to use, so it would have been harder to find space to stow a six wheel main gear.
It will be sad to see the Tu-154 disappear from the skies, though it wasn't an aircraft I enjoyed being a passenger in.
aerdingus
Tue Apr 20, 2010 3:53 pm
Quoting jetlagged (Reply 1):
Cheers. I had a feeling it might be that. The TU-204 sure would have looked cool with that gear though.....totally for got the fact that the -154's gear retracts into a pod on the wing...which is completely different from the -204!  blush
Definitely a good one to have crossed off the list though!
[Edited 2010-04-20 08:55:55]
Jetlagged
Tue Apr 20, 2010 7:49 pm
Quoting aerdingus (Reply 2):
Absolutely.
Fabo
Wed Apr 21, 2010 12:30 pm
I see you are a true Tupolevist, waking up in the middle oof the night with such questions
Truth is, in 20 years between Tu-154 and 204, much has been done, and the need for ability to work in rough enviroment has lessened.
The light at the end of tunnel turn out to be a lighted sing saying NO EXIT
aerdingus
Wed Apr 21, 2010 1:56 pm
Quoting Fabo (Reply 4):
Ha, yeah, my mind was full of Tushkas after reading Airways this month, and in a sadder way, becasue of the Polish crash.
