propilot83
Fasteners, Screws, & Bolts
Thu Apr 22, 2010 7:19 am
My question is for the engineer who designs and/or builds airliners. This is a complex and sophisticated question. When you see a myriad of phillips screws bolted on wings of airliners or any other location of an aircraft, are those screws tightly installed until its tight like you would screw something around your house? Or are the screws different from the ones we use around the house? And also are those screws secured by snapping into a lock position, where you cant tighten it anymore to prevent metal fatigue around the aircraft? So basically, the question is when you screw something on an aircraft, does it snap lock into something where you cant tighten it anymore? Are there any charts/diagrams to better show a visual explanation?
fr8mech
RE: Fasteners, Screws, & Bolts
Thu Apr 22, 2010 1:10 pm
Any threaded fastener used on an aircraft is torqued to a specified value. That's the book answer.
In reality, threaded fasteners that hold panels in place, assemble secondary structure, etc. are tightened until they are tight. They are not supposed to be hogged down by a gorilla.
In many applications, the AMM will specify a torque. Big things that come to mind are engine mount bolts, flight controls, bolted structural members, fuel tank access panels, among others.
For everything else, the AMM has generic charts that wll give you a torque based on size of fastener and application.
474218
Thu Apr 22, 2010 1:57 pm
One thing that should be pointed out you will find very few screws on a aircraft. Those flush phillips head fasteners you see holding the wing panels on are "bolts".
Under the panel, attached to the structure, you will find a plate nut (nutplate) which is permanently attached. The bolt is threaded into plate nut and tightened.
xero9
Thu Apr 22, 2010 2:47 pm
Just out of curiosity.. It's kind of on topic with this subject, but how many bolts hold things on such as an engine, a wing? Vital things like that. On say an A320, or 737?
I wanted to say a high number, but I'm actually thinking somewhere around 2-4? Would that be correct?
fr8mech
Thu Apr 22, 2010 3:16 pm
Quoting xero9 (Reply 3):
Not quite that low, anymore. Higher thrust ratings require more fasteners. As an example, the JT8 equipped B727 has bolts/nuts. The JT9 (B747) has 5. I believe the CF6 equipped B767 has 8.
Quoting 474218 (Reply 2):
I'm going to disagree, just a little, though it's just a point of symantics. There are plenty of places on the aircraft (and in the IPC) where a fastener is called a screw, not a bolt. But the same part number in a different application may be called a bolt.
[Edited 2010-04-22 08:18:52]
GST
Thu Apr 22, 2010 3:30 pm
In most of the cases I have come across servicing aircraft (admittedly all of them are gliders), the bolts are almost invariably locked in place with a wire.
dl757md
Thu Apr 22, 2010 3:59 pm
Much information on fasteners can be found in Chapter 7 of the AC 43,13-1b . It can be downloaded in pdf from the FAA website at http://rgl.faa.gov/REGULATORY_AND_GU...ac81b86256b4500596c4e?OpenDocument
DL757Md
fr8mech
Thu Apr 22, 2010 4:38 pm
Quoting GST (Reply 5):
What 474218 is describing are nutplates. They are typically used under panels as part of the fastener system for the panel. No need for safety wire here. The nuts are self locking.
474218
Thu Apr 22, 2010 7:24 pm
Quoting fr8mech (Reply 4):
Bolts differ from screw in that bolts have a "head-shank-threads". Screws have a "head-threads".
When installing a bolt you never want to end up with "threads in bearing" or threads that are below the surface, so bolts have a shank.
But it does get confusing when you have a long screw, which my have a shank. However, when a screw has a shank it has almost twice the number of threads a bolt will have.
Big version: Width: 900 Height: 900 File size: 180kb
[Edited 2010-04-22 13:15:22]
larshjort
Thu Apr 22, 2010 7:47 pm
A screw commonly used to install access plates on aircraft such as a Learjet 60 and Cessna Citation is a MS24693 which looks like this
Another screw commonly used is the MS27039
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
Thu Apr 22, 2010 8:10 pm
The Panel screws of the exterior most normally screw into Nutplates held below.At most Check C,damaged or unserviceable plate nuts need replacement.
The AMM Specifies a torque with tolerance needed by the faster to be secured.
regds
MEL.
474218
Thu Apr 22, 2010 8:30 pm
Quoting Larshjort (Reply 9):
All the fasteners shown are "screws" and can only be used in non-structural installations, like interior trim, etc.
See the following:
http://www.airpartsinc.com/products/ms24693-machine-screw-p15.htm
propilot83
Thu Apr 22, 2010 9:33 pm
I knew the answer to this question was going to be a little complicated, so what is an AMM? So basically concluding the answer to my question, when you install a flush phillip head screw on a surface of an airplane (i.e. spoilers, wing area, etc.) to attach to another component, does that specific screw lock into something else to prevent metal fatigue? Like for example, you know how if you tighten a screw too tightly....too much pressure will crack the surroundings like a wall, metal, etc, can this example be applied to an aircraft or no?
474218
Thu Apr 22, 2010 9:48 pm
Quoting propilot83 (Reply 12):
AMM is the Aircraft Maintenance Manual.
A flush head bolt is installed in a plain countersunk hole. Simple as that.
Aircraft mechanics are expected to know how to install bolts correctly without damaging the attaching parts.
AirframeAS
Thu Apr 22, 2010 10:13 pm
On our A318's, A319's and A320's at F9, all of the CFM's have 8 HUGE bolts attaching the engine to the pylon each. I am pretty sure that is standard for all the A320 family aircraft regardless of engine.
Chese
Fri Apr 23, 2010 3:31 am
This absolutely does happen although the first thing I thought of was screws in acrylic windows. They can cause small cracks that won't appear initially. There really isn't anything to prevent metal fatigue like say with a washer under the head of a nut, as screws are used primarily in panels that are removed fairly often.
Note to airliners.net admins, I will not like you on Facebook.
propilot83
Fri Apr 23, 2010 6:32 am
Quoting Chese (Reply 15):
So I guess this answers my question then, when you install a screw into any part of an aircraft, it does not lock into something else, you have to tighten it until it gets real tight???? This is no different than using screws around your house then, like causing cracks around a screw while tightening it too much around walls, and other metals??? If this is true, then its surprising, because an airplane expands and contracts like a balloon every time it takes-off and lands, the airplane goes through metal fatigue.
fr8mech
Fri Apr 23, 2010 12:07 pm
Quoting propilot83 (Reply 16):
No, you do not tighten until it gets real tight. There is a torque value. Now, most folks don't use a torque wrench on a simple panel, but, as 474218 stated, aircraft mechanics are expected to know how to install a panel screw, or bolt, without damaging the panel. There is no fail safe. If you have a gorilla installing fasteners, you may have an issue, as we have all seen.
Now, to be sure you understand, the fastener does not go into the metal below the panel (like a stud in a wall), it has a receptacle, commonly a nutplate, that accepts the fastener. This is what the fastener is torqued against, along with the panel.
Tristarsteve
Fri Apr 23, 2010 3:41 pm
I think that installing scres and bolts is about the most important thing you learn when you are an apprentice. Anyone can tighten a bolt 'real tight', it takes skill to tighten it correctly. And there are many that overtorque panel screws. If you have a wing access panel with 50 bolts in it, it is unusual to remove all of them without difficulty. There is always one or two that are too tight, or have damaged heads, then you need to drill them out. I'm lucky. I work on the ramp nowadays, and don't do it often, but when I have to remove a big panel I know there will always be a problem.
Too many mechanics use power tools to fasten screws, which gives the next guy a problem.
I always use a torque wrench for engine mount bolts, and wheel nuts. But not much else.
I find it amazing nowadays how few bolts have secondary locking. You still see split pins used in some flying controls, and occasionally have to wirelock a bolt, but not often, except on engines, and bolts on wheel cover plates.(The B737 is a pain.)
I am British. To me a screw has a point on the end, and is usually used in wood. A bolt has a flat end and normally goes into a nut.
474218
Fri Apr 23, 2010 4:54 pm
Quoting fr8mech (Reply 17):
Addtionally, every nutplate I have ever seen are self locking. The nut portion is crimped making it slightly oval or triangular which adds in bolt retention.
And just as bolts have a specific torque. The nutplate has a running torque or a point where it should be replaced if the bolts can be installed to freely. As an example a 3/16" diameter bolt with 32 threads per inch (10/32) should be torqued to 30 to 35 inch pounds. The running torque for a 10/32 nutplate should be 10 to 12 inch pounds.
propilot83
Fri Apr 23, 2010 7:22 pm
Okay, so basically its like this then, when you install a screw into a wing panel, etc., inside that area where you install the screw, there is another bolt or something like an "anchor" to install the screw into to prevent damage like metal fatigue or cracks?? Just like for example, when you install an anchor into a wall and then install a screw into it?
Fri Apr 23, 2010 7:58 pm
Quoting Tristarsteve (Reply 18):
Its Important to think of the Removal when Attaching screws to a panel.The Bloke could be yourself.Do not use damaged head screws & if possible use a light spot of grease especially if installation is done during rain.It helps in preventing corrosion & getting tight.
regds
MEL.
tdscanuck
Fri Apr 23, 2010 8:00 pm
It locks into a threaded receiver...usually a nutplate, occasionally an embedded nut.
Correct. If you overtighten an aircraft screw you can damage the structure, just like in other applications. However, aviation metals are very tough and fracture resistant...the most likely result of overtorquing is a stripped head and great difficulty removing the fastener later.
Screws and bolts don't really contribute to metal fatigue because the clamped material is in compression. You can only get fatigue cracks when you go into tension. The *holes* you make for screws and bolts can be huge fatigue sources (stress concentration around the holes), but that's designed for in both how you handle hole spacing and size, and how you prepare the hole (e.g. cold working).
Quoting propilot83 (Reply 20):
There is an "anchor" (the nutplate or embedded nut). It's not there to prevent damage like metal fatigue or cracks, it's there to provide the screw something to thread into. Fatigue/crack resistance is built into the design of the thing you're screwing through.
Basically, yes.
Tom.
474218
Fri Apr 23, 2010 9:06 pm
No. There is a hole through all the parts with a nutpate on the bottom side of the lowest part. The bolt passes through all the parts into the nutplate. The bolt is turned until the proper torque is reached.
Simple as that. Nothing but panel, sub-structure, nutplate and bolt.
Below is how flush rivets can be installed. A bolt would be the same, with the rivet the rivet's manufactured head and its shank being the bolt and the rivet shop head being the nutplate.
propilot83
Fri Apr 23, 2010 11:11 pm
Thanks guys for answering my question, mostly to you tdscanuck. I know this question was very sophisticated and complex, however the answers were as well, but I believe I've figured it out now.
soon7x7
Sun Apr 25, 2010 12:53 am
Get ready for a picture storm on fasteners, I just happened to have a bunch sitting on my desk...The first overview shot will help you to scale the large bolts. Image "A" represents an assortment of rivets, many types exists but are really intended for permanent installation.
assorted rivets
image "B" represents nutplates, hi-loks, monel stamped nuts and 12 point nuts. All are crimped so they grip the threads on the fastener and are generally installed in areas that require access at some point. The red and blue hi-lok or shear lock will self torque and the actual hex head will shear off at the designed torque value.
self locking
Group "C" represents general airframe bolts that come in all sizes, pan heads, flush heads are applied in areas that require great strength and access. Typically they incorporate self locking nut systems.
"D" is a typical example of a castelated nut using a bolt with a hole in the threads by which a cotter pin is installed. These nuts usually fit loosely on the bolt. (cotter pin not included)
bolt requiring castlated nut and cotter pin
This next image is an actual 747 gear door hinge with the castelated nut/cotter pin installation. (think I spelled castelated wrong)...you get the idea...
747 gear door hinge with castlated nut and pin
Next shot is of three large bolts. Actually two are considered "bottle pins" as they are hollow. The one marked 767 is a landing gear knuckle pin. The center bolt is one several that hold the 737 horizontal stab onto the fuselage (self locking 12 point nut). The one on the right attaches the massive horizontal trim tab from a 747 to the rear spar at the position of the PCU (from EI-BED).
767bottlepin,737 hzntl stab pin, 747 trim tab pin BIG!
Finally, this image is the attach end of a 747 landing gear door torque tube with a self locking 12 point nut.
747 gear door torque tube end
OOOPS...not done yet...this image represents an actual nut plate installation and hi-lok installation in the leading edge of TWA's 747, N3108.
nutplates and hi loks
hope you enjoyed the show...I really did have this stuff on my desk!...g
soon7x7
Sun Apr 25, 2010 12:57 am
Crap...the overview image didn't load...here you go...
assorted Boeing fasteners
Image "E" are stainless steel washers that usually find their way onto countersunk phillips screws (bolts) that are used on composite panels...sometimes the primary screwhead pulls through so these are an easy remedy...g
Web500sjc
Sun Apr 25, 2010 2:31 am
How many bolts hold on a 777 engine
Boiler Up!
soon7x7
Sun Apr 25, 2010 4:10 am
Quoting web500sjc (Reply 27):
Can't find the answer...It's sort of a trick question as the engine has anti sway yokes which technically add to the number of mounting hardware but the actual breakaway pins must number in the 4-5 range. I can't imagine anymore. The powerplants weigh in at 15,000 lbs each.
Tristarsteve
Sun Apr 25, 2010 11:06 am
Sorry don't know either, but a RR RB211 has eight bolts. There are four on the fwd mount, and four on the aft mount. They are critical because they are in tension. They are about one inch diameter, and 10 ins long. On evry engine change they are replaced, and the set of bolts sent to the workshop for inspection. (then used again).
soon7x7
Sun Apr 25, 2010 11:48 am
Quoting Tristarsteve (Reply 29):
Wasn't the RB211 an exceptionally heavy engine for its size, something to do with three shaft configuration?
474218
Sun Apr 25, 2010 3:00 pm
Quoting soon7x7 (Reply 30):
The RB-211 QEC depending on the model weighs between 12,900 and 13,700 lbs. This weight includes all cowlings, ducting and thrust reverser.
The CF-6 core engines weigh 9,000 lbs. This is without any cowlings, ducting and thrust reveresers.
Users browsing this forum: flipdewaf, rmilstre and 2 guests
