kparke777
Runway Heading At LAX
Mon May 03, 2010 7:11 am
At LAX, why are the 24's N of the 25's? I thought that 25 should be N of 24 but at LAX the opposite is true with 24 being N of 25. At PHX, our home, 26 is N of 25 which aligns with the headings.
swiftski
RE: Runway Heading At LAX
Mon May 03, 2010 7:57 am
All the 24' and 25' runways have the same heading (249).
You can have 25L, 25C, 25R but you can't have four, i.e. 25L, 25LC, 25RC, 25R. This is why they are given another runway number.
At PHX they are all 257, so same applies.
In both cases it doesn't really matter which is more North as the numbering will be innacurate for one pair.
ANITIX87
Mon May 03, 2010 3:31 pm
Quoting kparke777 (Thread starter):
Why are the 24s and 25s the primary runways? Because they're used more often? I think it makes perfect sense, because 06L/R is north of 07L/R, and those are "closer" to North.
TIS
vikkyvik
Mon May 03, 2010 3:48 pm
Quoting swiftski (Reply 1):
It always sort of puzzled me why PHX didn't give their runways L/C/R designations, given that they only have 3 runways. I just figured they wanted to avoid confusion as to which side (north or south) an airplane was using. That or they had plans to build a 4th which never got done.
I believe that the 25s were also built well before the 24s. So when they added the two northern runways, they gave them the next closest designation.
mrskyguy
Mon May 03, 2010 5:36 pm
I also think there's a rule of thumb depending on where the terminal is located. At Midway for example, the terminal doesn't "split" the runways.. it's to the right completely, giving room for "C" designators on the middle runway. LAX on the other hand splits the runways neatly with 2 on each side.
General flow is typically landing traffic on the outboard runways, departing on the inboards.
"The strength of the turbulence is directly proportional to the temperature of your coffee." -- Gunter's 2nd Law of Air
Viscount724
Tue May 04, 2010 10:25 pm
When the 3rd parallel runway opened at MIA in 2003 (the one at far left in diagram below, now 8L/26R) it was numbered 8/26.
http://204.108.4.16/d-tpp/1004/00257AD.PDF
The other two were 9L/27R and 9R/27L. Apparently there was confusion that sometimes resulted in aircraft mis-identifying the runways and thinking the new runway was 9L/27R.
About a year later they renumbered the new runway to become 8L/26R. Runway 9L/27R was changed to 8R/26L, and 9R/27L was changed to 9/27. I guess they considered it less confusing to have the 2 runways close together to have the same numbers and L/R designations,and the more distant runway to have the unique numbers.
StarAC17
Tue May 04, 2010 11:07 pm
Quoting vikkyvik (Reply 3):
YYZ has 3 parallel runways as well and doesn't use a "C" designation either and I would think for the same reason as 24L/R and 6L/R are southern runways and has 5/23 on the north side.
A center runway has to be a true central runway where they are spaced reasonably evenly.
Engineers Rule The World!!!!!
vikkyvik
Wed May 05, 2010 8:21 am
Quoting StarAC17 (Reply 6):
Well, it doesn't have to be, far as I know. I'm sure it's significantly more prudent to do it that way, though.
DFW has 17-35L/C/R I believe, with two of them fairly close, and one a significantly farther distance away. Of course, they all are on the same side of the terminal. They're the parallels on the left side of the photo:
Photo © James Richard Covington
StarAC17
Sat May 08, 2010 1:10 am
Quoting vikkyvik (Reply 7):
Fair enough but it has the same idea as airports like LAX and YYZ + many more as those ones have one heading for one side of the terminal and one for the other side.
I presume the ones on the right are 18-36L/R
Also ATL is laid out similar to DFW and has 9-27L/R and 10/28 on the same side and IMO I think it would make sense to have a 9-27C in there instead.
vikkyvik
Sat May 08, 2010 9:13 am
Quoting StarAC17 (Reply 8):
Yeah that's certainly true.
Yup!
I almost mentioned ATL in my previous post. That one has always confused me - they have 3 different runway designations for 5 parallel runways (8-26L/R, 9-27L/R, and 10-28). But I assume it was another confusion-elimination strategy.
Users browsing this forum: Baidu [Spider], cvgComair, flyDTW1992, ucdtim17 and 2 guests
