B-787
DL 757 Winglets With New Type Of Tip Strobe
Mon May 10, 2010 7:00 am
I was out at LAX and spotted a DL 757 with winglets and a new type of tip strobe that blinks 3 times each cycle like a Cessna. Is this a one off installation or is this going to be more common?
717,722,732,73G,738,739,739ER,752,753,762,763,764,744,772,788,D10,M80,300,332,333,320,319,CR7,CR9,ER4,AT4,E70,E75
Fly2HMO
RE: DL 757 Winglets With New Type Of Tip Strobe
Mon May 10, 2010 4:03 pm
Quoting B-787 (Thread starter):
It's actually 4 times per cycle for Cessnas, in the newer 172s at least.
LASoctoberB6
Mon May 10, 2010 10:19 pm
I saw a DL 757 about two months ago with different beacons. They flashed like the 787's strobes.
[NOT IN SERVICE] {WEStJet}
Fly2HMO
Mon May 10, 2010 11:31 pm
Quoting LASoctoberB6 (Reply 2):
Most likely LEDs then.
71Zulu
Mon May 10, 2010 11:39 pm
Are the LEDs as bright as strobes?
Clickable links only please!
KELPkid
Tue May 11, 2010 12:03 am
Quoting 71Zulu (Reply 4):
When brand new. I'd love to see how bright they are after about 10 years in service   (LED's do lose considerable brightness over their lifetimes...).
shamrock137
Tue May 11, 2010 3:46 am
Quoting KELPkid (Reply 5):
This is true of strobes as well. They slowly get dim until they burn out completely. I work for an ambulance and one of our trucks has a combination of LED's and strobes. The LED's are gen 1 as the truck is from 2003 however they are still extremely bright. We recently had to replace one of the strobe units on the rear, and the new one is much brighter than the old one, however the LED's which are the original from 2003 are just as bright as the new strobe.
Whelen which makes aircraft lighting products along with emergency vehicle lighting systems has been using LED's for over 10 years. The newest systems are extremely bright and use much less energy than strobes. The only think I dont like about the new LED aircraft lights is the flash pattern. Instead of having a rapid on and off flash like the strobes, they stay on for a second before turning off, making more of a blinking pattern than a quick strobe like pattern. I dont think it as as eye catching and I'm curious to know of any other pilots have noticed this.
Time to spare? Go by air!
tpa36r
Tue May 11, 2010 11:11 am
Delta has been testing LED beacons for about a year or so. First I have heard about the strobes. Overall it is more cost effective to use LED's then strobes.
Fly2HMO
Tue May 11, 2010 5:05 pm
Quoting Shamrock137 (Reply 6):
I find them much more eye catching IMO, specially at night. They are much more obvious in the air than from the ground. The red LED beacons stick out like a sore thumb, and so do the green/red nav lights. The ones that look great are the LED landing pulselights. If you don't see a plane with those, you're probably blind.
shamrock137
Tue May 11, 2010 5:26 pm
Quoting Fly2HMO (Reply 8):
Sorry should have been more clear, I was referring to the white strobe lights. I have seen an Eclipse 500 with this system and it just did not seem as noticeable. I would agree however the landing lights and red beacons are very visible.
highflyer9790
Sat May 15, 2010 10:19 pm
i have to say i dont think the LED strobes are as noticabledue to the delay it has when it pulsates. unlike a traditional strobe, the LED one illuminates for a fraction of a second and stays on- taking away the "lightning" like effect of the traditional strobes.
121
Users browsing this forum: ACDC8, gtae07, Nicoeddf, TOGA10 and 1 guest
