Transtar
Why Did Spoilers REmain Deployed During Taxi
Fri May 14, 2010 8:45 pm
When my United 777 landed at Washington IAD, the spoilers remained deployed throughout the taxi and parking. Later, I noticed the plane at the gate and the spoilers remained deployed?
Any explanations?
TranStar
larshjort
RE: Why Did Spoilers REmain Deployed During Taxi
Fri May 14, 2010 8:57 pm
Maybe maintenance needed to check the spoilers and asked the flightcrew to keep them extended.
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
B777LRF
Sun May 16, 2010 10:09 am
Some sort of mechanical problem. Had it happen a couple of times on the 757 - the spoiler lever had been placed in the down position during taxing to stand after landing, but they physically remained up. Wrote it up in the tech log and left it to engineering to deal with.
Most times the spoilers will auto-stow with the application of a bit of throttle, that is if they've auto-deployed having been set in the armed position prior to landing.
From receips and radials over straight pipes to big fans - been there, done that, got the hearing defects to prove
barney captain
Tue May 18, 2010 8:26 am
Quoting TranStar (Thread starter):
Any explanations?
TranStar
5 bucks says they simply forgot to stow them after landing.
Southeast Of Disorder
PGNCS
Wed May 19, 2010 2:24 am
Quoting barney captain (Reply 3):
Any explanations?
TranStar
Ten bucks says barney captain is right.
rockindokken
Wed May 19, 2010 1:03 pm
Well, I know that spoilers will stay deployed up to 30 seconds after landing when set to auto mode on some aircraft. It does this incase the a/c bounces, so that the spoilers don't retract if it goes WOW.
Their main purpose is to dump the lift created by the wing, and having them retract if the plane bounced would make the landing run longer.
jetmatt777
Crew
Wed May 19, 2010 4:40 pm
Quoting RockinDokken (Reply 5):
On some aircraft it is after a certain speed, say 45 knots. (Can't remember if that is IAS or GS)
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
KPDX
Wed May 19, 2010 8:50 pm
Not to jack your thread, but I once saw a United 757-200 at PDX park at the gate with full flaps after landing. Is that normal?
View my aviation videos on Youtube by searching for zildjiandrummr12
donniecs
Thu May 20, 2010 3:20 am
Pilots probably just didn't get around to unarming the ground spoilers during taxi in. You probably saw the spoilers come up and down a few times as power was applied and reduced during taxi. In simple terms, most aircraft have a ground spoiler arm switch. When the ground spoilers are armed, there is weight on the wheels, and throttles are idle, the ground spoilers will deploy. It's is somewhat common for a crew to forget to unarm the ground spoilers during the after landing check, thus causing the boards to go up and down during taxi.
Quoting KPDX (Reply 7):
While not a 757, our Gulfstreams get parked with flaps at 20 degrees (lowered on taxi in with engines running) to save wear and tear on the aux pump and batteries when maintenance has to lower them for postflight, preflight, and any other maintenance.
Charlie - Gulfstream flight mechanic
mcdu
Fri May 21, 2010 12:47 pm
Quoting DonnieCS (Reply 8):
You won't see the spoiler move up and down in the B777 due to thrust changes.
boeing767mech
Fri May 21, 2010 5:25 pm
Twenty bucks says when the power levers are advanced the spoilers will retract. Even during taxi in you advance the power levers another for the spoilers to retract. So my money is on the fact that they had a mechanical issue. The nice thing about the 777 is you can do checks of the systems right there in the cockpit using the MAT.
David
Never under-estimate the predictably of stupidty
Users browsing this forum: Balerit, CrimsonNL, flyingturtle and 4 guests
