BALandorLivery
Aircraft Painting Mismatches
Thu May 20, 2010 8:29 am
We sometimes see photo's where aircraft have had panels or radomes swapped with other aircraft for whatever reason.
One of the few ways we can tell is that there is a mismatch with the paintwork even though they have the same livery.
Does anybody know how/what templates are used to align up the stickers/paint?
Is there a start pont/datum on the aircraft to which it's referenced and all paint applied from that point.
Are lasers used to line things up?
Any painters out there?
Here's what I'm talking about.
Photo © Jeff Miller
Photo © Ryan C. Umphrey
Photo © Ben Wang
Photo © Sergio Domingos
474218
RE: Aircraft Painting Mismatches
Thu May 20, 2010 2:41 pm
The randoms and cowling are interchangeable. So they have been removed from one aircraft and installed on another. There will always be slight verations in the paint between aircraft.
BMI727
Thu May 20, 2010 3:07 pm
Quoting 474218 (Reply 1):
I think that in at least some cases the radomes are detached and painted separately, which is how one got turned upside down and ended up on a UA plane. Also, it isn't uncommon to see radomes in completely different schemes on regional planes which of course keep a common spares inventory.
Rj111
Thu May 20, 2010 3:14 pm
That UA 767 photo will have a radome from a 777 - they're interchangable.
kanban
Thu May 20, 2010 4:25 pm
initially all painting is indexed to water line zero.
roseflyer
Thu May 20, 2010 4:42 pm
Quoting kanban (Reply 4):
To add some explanation to that, there is a three dimensional grid to which airplanes are built with waterline and stationline being used to index paint. While they are not labeled on the outside of the aircraft, each of the points are identifiable and can be used for reference.
B727LVR
Thu May 20, 2010 4:43 pm
Quoting BMI727 (Reply 2):
Can you explain this one a litle bit more. Most if not all radomes I have worked on only go on one way, or did you mean the paint scheme was applied upside down?
I'm like a kid in a candy store when it comes to planes!
BALandorLivery
Thu May 20, 2010 4:54 pm
Waterline & Stationline.....now we're getting somewhere.
Can someone explain how painting/preparation begins at these points. Where are these points usually located?
How are radomes painted seperately if, like on some liveries, you have to line up the stripes exactly?
BMI727
Thu May 20, 2010 7:51 pm
Quoting B727LVR (Reply 6):
Right. The radome was on the plane the right (and only) way. It was just that it was painted upside down, so the top of the radome was dark blue and the bottom was grey.
474218
Thu May 20, 2010 8:14 pm
Quoting BALandorLivery (Reply 7):
The following may help in understanding "Water lines/Butt lines/Fuselage Station lines:
Water lines, start below the surface and extend up. Example: the ground is waterline 19 (19 inches above WL 0), the cabin floor is WL 200 (181 inches above the ground).
Butt lines start at the center of the fuselage and extend out left and right. Example BL 0 is the middle of the fuselage the outer fuselage skin is BL 115 left or right (or 115 inches from the middle of the fuselage).
Fuselage Stations start forward of the nose run to the end of the fuselage. Example FS 83 is the tip of the radome, FS 2215 (or 2132 inches from the radome) is the end of the fuselage.
As you can see by the lists of abbreviations there are may other parts that have their own station lines.
rolypolyman
Fri May 21, 2010 1:50 am
I'm actually wondering how they get the logos, shapes, and polygons painted so precisely... do they spray against plastic stencils? I can't even picture how a painter decides exactly where to hold the stencil and at what angle. If I was given a 777 to paint, I'd take an LCD projector and cast a template against the fuselage to use as a guide and use that with stencils. Funny how the whole process is so mysterious.
474218
Fri May 21, 2010 2:07 am
Quoting rolypolyman (Reply 10):
Not mysterious at all. A base coat is applied then the areas that are going to get details are masked off and painted.
These pictures are of a BWIA TriStar having the new scheme in 1999.
Removing old scheme.
Base coat and masking.
Final result.
tdscanuck
Fri May 21, 2010 4:51 am
A lot of them are decals, not painted, in which case it's just a matter of positioning, rather than precise painting. However, for the painted stuff, you use big stencils.
Lasers.
Replace the LCD projector with a laser and you've got an OEM paint system.
Tom.
BALandorLivery
Fri May 21, 2010 12:10 pm
And why do we see rudders being painted seperately on new a/c?
boeing767mech
Fri May 21, 2010 12:51 pm
Quoting BALandorLivery (Reply 13):
Because the rudder is balanced. So it is painted and balanced before being fitted to the airframe. Then it is masked and then the rest of the airframe is painted. Most of the time the ailerons and elevators get the same treatment.
David
Never under-estimate the predictably of stupidty
kanban
Sun May 23, 2010 5:23 am
If you can find it on Utube there was a good vid of the last Southwest state special being painted...
Braniff747SP
Sun May 23, 2010 10:53 pm
Quoting kanban (Reply 15):
http://www.youtube.com/watch?v=zKnsyYbfC60
The 747 will always be the TRUE queen of the skies!
sccutler
Mon May 24, 2010 5:01 am
I once saw an amusing picture, taken by a NWA Flight Attendant friend; it was an NWA DC-10 with a UAL radome on it. The radome had been damaged in a birdstrike, and a parts loan was organized.
Funny-looking, but it got the job done.
...three miles from BRONS, clear for the ILS one five approach...
BALandorLivery
Mon May 24, 2010 10:28 am
So it's safe to say that mis-matches occur due to different paint shops not quite starting the job at exactly the correct datum?
What do the painting instruction documents look like?
I assume they need to be carefully studied before applying a paint job?
474218
Mon May 24, 2010 3:24 pm
Quoting BALandorLivery (Reply 18):
Yes.
They are just standard blueprints (CAD drawings). I have several L-1011 customer liveries blueprints, I know one is BA, but not Landor.
No more or less than any other job.
Mender
Mon May 24, 2010 7:43 pm
How far away from the aircraft would you have to place you LCD projector? Would it be bright enough to be visible when it's that far back? Think about this as well. If you have a 1" mis-match on a 100" surface you only have an error of 1%. Whilst a radome may not be 100" high I bet it's at least 50" and 1" in 50 is only 2%
I'm not trying to ridicule you, I'm trying to point out it's not as easy as it first seems.
Even if you were to use a laser you'd have to ensure the first aircraft was exactly as high as the second aircraft or have a trick laser. In a manufacturing environment you could do this but it would be a lot harder painting an Airbus then a Boeing back to back.
tdscanuck
Tue May 25, 2010 5:34 am
Quoting Mender (Reply 20):
No need for constant height, just need known reference points on the aircraft so the laser knows where it is in relation to the aircraft. Then it can project any shape on to any surface with very high accuracy, assuming it's got line-of-sight. Fortunately, aircraft are full of known reference points already (jack pads, major structure points, tooling references, etc.), so it's just a matter of choosing which one(s) you want to stick the laser marker on.
Why? As long as your laser system knows the geometry or each aircraft (which was a prerequisite to using the laser in the first place), it doesn't care.
Tom.
AirframeAS
Tue May 25, 2010 6:56 am
Quoting boeing767mech (Reply 14):
I want to clarify boeing767mech's explanation.... This is done on the Boeing aircraft. Airbus does not balance their rudders, hence why you see a full tail painted on a brand new airplane vs. only rudder is painted on a Boeing aircraft.
474218
Tue May 25, 2010 2:02 pm
Quoting AirframeAS (Reply 22):
How does Airbus prevent flutter in the case of multiple hydraulic system failure?
AirframeAS
Tue May 25, 2010 6:06 pm
Quoting 474218 (Reply 23):
What does that have to do with painting rudders??    Stay on topic.
boeing767mech
Tue May 25, 2010 6:52 pm
To quote the D & O of the flight controls, in AMM 27-00-00-0 on the A300-600 " All surfaces are actuated by irreversible hydraulically powered actuators. No surface is mass balanced."
And to quote 51-60-00-0 of the SRM of the same airframe. "Balancing of the primary and secondary contorl surfaces after minor or major repairs in accordance with the SRM is not required."
David
AirframeAS
Tue May 25, 2010 7:03 pm
Since we are now talking about the semantics of how rudders work (which is off-topic)....
Quoting boeing767mech (Reply 25):
IIRC, on the A320, there are back-up actuators on the rudder and they are electric actuators as I understand it. Keep in mind, my time at F9 never did I once did rudder work, so I really don't know.
It says the same in the A320 AMM as well.
tdscanuck
Tue May 25, 2010 11:05 pm
Quoting AirframeAS (Reply 24):
It is on topic...it's why Airbus paints their rudders along with the rest of the plane and Boeing doesn't. This has obvious implications for paint mismatch, since Boeing paints the rudders far in advance, in a different location, and it's supposed to line up nicely with the rest of the fin livery once they paint that.
Tom.
AirframeAS
Wed May 26, 2010 12:35 am
Quoting tdscanuck (Reply 27):
Alright, fair enough.... Thanks for the explaination.
474218
Wed May 26, 2010 1:33 am
Your the one that brought up that Airbus rudders were not balanced (off topic?), all I did was ask about question how they can get away without balancing them?
kanban
Wed May 26, 2010 3:17 am
OK we got pictures of radome mis-matches... anyone have some of tail feather mis-matches or airline swaps..
The closed I ever saw was a flap wrapped with duct tape... and steaming behind
boeing767mech
Wed May 26, 2010 11:39 am
Quoting kanban (Reply 30):
There are pictures of a NWA 757-200 with a UPS rudder that was taken here in Boston when the highly skilled replacement workers the NWA hired ran the hanger doors into the rudder of one of the airplanes, Because they could follow the lines on the floor.
David
AirframeAS
Wed May 26, 2010 4:18 pm
Quoting 474218 (Reply 29):
I brought it up for a reason, so that people here don't get confused that all rudders are balanced regardless of aircraft type. I know Boeings have their rudders balanced (hence why you see a new airplane with a painted rudder only) while the Airbus aircraft does not (whole tail painted).
I do not know how Douglas did their rudders, I assume it is the same as the way Boeing does it?
474218
Wed May 26, 2010 6:08 pm
Quoting AirframeAS (Reply 32):
I take it you don't know why Airbus doesn't balance their rudders, so I looked it up. Now I am sorry I did.
Braniff747SP
Wed May 26, 2010 8:53 pm
Quoting 474218 (Reply 33):
I must be missing something blatantly obvious here.... Please explain.
474218
Wed May 26, 2010 9:58 pm
Quoting Braniff747SP (Reply 34):
And get in trouble for going "off topic" again. I don't think so. I suggest you start a thread asking why Airbus does not "mass balance" their control surfaces!
AirframeAS
Thu May 27, 2010 10:14 pm
No worries. Its my fault. I thought you were challenging me to see if I knew what I was talking about. I share the blame. My bad, sir.
alwaysontherun
Fri May 28, 2010 1:00 am
To go back to paint:
are there many aircraft paint manufacturers like you have in the Marine Industry?--> Sigma, Jotun, International for instance.
Or do airlines / manufacturers mix it up in house?
### "I am always on the Run"###
"Failure is not an option, it comes standard in any Windows product" - an anonymous MAC owner.
JT8DJET
Fri May 28, 2010 1:04 am
Quoting boeing767mech (Reply 31):
Mind if I add a picture to your quote?
Photo © Paul Kanagie
Photo © LHR Photos
kanban
Fri May 28, 2010 4:32 am
Quoting alwaysontherun (Reply 37):
Boeing buys to a BMS specification from several suppliers for basic standard paint schemes.... I just don't remember who (of course with mergers and buyouts, that changes weekly) I recall supplying paint as part of initial provisioning packages to small airlines in the 70's however now I think they all buy direct.
B727LVR
Fri May 28, 2010 8:48 am
Quoting JT8DJET (Reply 38):
I wonder if UPS leased the rudder to them?
474218
Fri May 28, 2010 11:25 am
The OEM's have there own specifications for things like paint. They then will approve the suppliers that are authorized to produce to that specification.
tdscanuck
Mon May 31, 2010 10:49 pm
Really duct tape, or speed tape?
Quoting kanban (Reply 39):
PPG Aerospace coatings is one...I'm pretty sure DeSoto was another, although they've been bought so many times I can't figure out who they are now.
Tom.
Okie
Tue Jun 01, 2010 3:32 am
Quoting B727LVR (Reply 40):
Or off a leased or retired plane sitting in the desert to be parted out.
Okie
tdscanuck
Wed Jun 02, 2010 5:23 am
Quoting BALandorLivery (Thread starter):
There's an excellent video available on Youtube that shows how this is done (and, judging by the number of views, it's gone viral).
The painting starts at about 1:20. This is, as you can tell, an absurdly complex livery.
Tom.
kanban
Wed Jun 02, 2010 6:04 am
Quoting tdscanuck (Reply 42):
duct tape.... had two engineers on board that confirmed it was not speed tape ... Those things happen on a 6am flight from Seatac to DC... for the leg to Cincinnati 80% of the passengers are Boeing
BALandorLivery
Thu Jun 03, 2010 2:02 pm
What about painting the window blinds?
Is it standard to paint them or just to pick a neutral colour for them all?
If they are painted to match the livery then how do they go about doing this?
Matching window blind:
Photo © Jan Bialas
Not matching:
Photo © Fengxiaoxi
Photo © Roberto Bianchi
kanban
Thu Jun 03, 2010 5:59 pm
Quoting BALandorLivery (Reply 46):
the blinds are in the interior side walls and one would have to strip the interiors, disassembly each blind, and for those that roll up, figure out how to hold it flat for painting.. the other problem is not many paints stick to that material so the would be prone to flaking.
Alternative there are exterior decals that are perforated so one can see through yet appear t be a solid surface from a distance.. this is used in advertising, you see them on buses, trams, trucks and cars.. the problem would be removing them from the window when designs change, or they become damaged...
TZTriStar500
Thu Jun 03, 2010 8:54 pm
You actually named too that are actually now one. PRC-Desoto is now part of PPG. Akzo-Nobel is another large paint supplier as well.
Window blinds are not painted. Most are formed plastic in the color of the particular material.
Quoting kanban (Reply 47):
Aircraft do not use the type of perforated decals you mention as used on buses, cars, etc. that are installed over windows. No aircraft decal is purposely installed over a window or view port nor would it most likely be allowed as windows need to be inspected like all else and this would inhibit that. If desired, the stretched acrylic window would be replaced with an aluminum window plug.
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
C5202QMX
Tue Jun 08, 2010 1:18 pm
Its not always just a radome that can be mismatched. There will always be slight variations from paint job to job. A lot of the time MX will rob a part/panel/cowl etc from one AC down for an extended time to place onto a serviceable AC with minor damage. It saves time in that you do not have to paint the part or panel that comes new to match. Most of the time the variations are so minute that pax will never notice. When we replace a radome we do not paint it, we will leave it white to send the AC out for revenue and match it to the paint scheme at a later date when MX is scheduled.
Users browsing this forum: SAAFNAV, speedbored and 1 guest
