mmedford
Maintenance Of Navaids & Comm In The Caribbean
Thu May 20, 2010 7:54 pm
So I'm curious of something; I know the FAA maintains Navaids on Puerto Rico, US V.I. and an island or two in the Bahamas.
Who maintains the Comm Radios and Nav-aids for the other airports in the caribbean? Is it a division of Caricom? ICAO?
ILS = It'll Land Somewhere
Fly2HMO
RE: Maintenance Of Navaids & Comm In The Caribbean
Thu May 20, 2010 9:17 pm
It would be the respective aviation regulatory body of the country said navaid is in. In case of territories then it would be the regulatory agency of the parent country. Also, some countries may contract navaid flight test/certification services from another country or agency.
mmedford
Thu May 20, 2010 9:30 pm
shucks, there goes my retirement plan...lol
I want to be able to certify an ILS, and then hit a beach party...
Fly2HMO
Thu May 20, 2010 10:44 pm
Quoting mmedford (Reply 2):
Are you working for the FAA or a private contractor? I think the FAA has done some flight test missions in Mexico IIRC.
LimaFoxTango
Thu May 20, 2010 11:20 pm
The oversight of NAVAIDs in the OECS namely, Antigua/Barbuda, Anguilla, Montserrat, St. Kitts/Nevis, Dominica, St. Lucia, St. Vincent & the Grenadines and Grenada falls under the ECCAA (Eastern Caribbean Civil Aviation Authority). NAVAID's in Barbados and Trinidad/Tobago fall under their respective CAA's. Flight Checks are probably contracted to another agency or company as none of these Authorities has any Flight Check aircraft. Hope that helps.
You are said to be a good pilot when your take-off's equal your landings.
mmedford
Thu May 20, 2010 11:59 pm
Quoting Fly2HMO (Reply 3):
Check your PM box, but the Flightcheck division is a different unit.
LFT, I will definately look into it...I can cause plenty mischief in ALL those islands..lol
KELPkid
Fri May 21, 2010 1:42 am
Quoting mmedford (Reply 5):
Change all the VOR's so that the 180 radial is on Geographic North instead of Magnetic North
mmedford
Fri May 21, 2010 2:48 am
Quoting KELPkid (Reply 6):
think more social mischief, than professional...
Fly2HMO
Fri May 21, 2010 3:13 am
Or even more fun, rig the damned things to act like a VOT, so you always are on the north radial regardless of your true radial
mmedford
Fri May 21, 2010 3:17 am
Quoting Fly2HMO (Reply 8):
I actually know how to do that, but I refuse to cut cables for that...and before it would even happen the monitors would shut the equipment down once its out of tolerance (shift of +/- 1 degree)
Fly2HMO
Fri May 21, 2010 3:23 am
Quoting mmedford (Reply 9):
Hmmmm, I'm assuming you just get rid of the variable signal?
mmedford
Fri May 21, 2010 3:29 am
Alittle bit goes into the transmission lines than just the variable signals...
Fly2HMO
Fri May 21, 2010 6:02 am
Quoting mmedford (Reply 11):
Ya but that's just getting a wee bit too technical for this dumb pilot
