c5load
The Panel On The Side Of This 767-What Is It?
Sat Jun 05, 2010 3:54 pm
There is a square panel about halfway between the DL logo and the American flag, on the upper side of the fuselage, just behind the window exits. Is this some sort of antenna?
Photo © V. Javier del Olmo Gomez
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
zanl188
RE: The Panel On The Side Of This 767-What Is It?
Sat Jun 05, 2010 3:58 pm
Sat antenna. Mounted on the side to provide a fair view of the sky in turns.
tdscanuck
Sat Jun 05, 2010 6:09 pm
Quoting ZANL188 (Reply 1):
Is there a matching one on the other side? Seems an interesting sat antenna implementation compared to the steerable ones in the blister fairings on top.
Tom.
c5load
Sat Jun 05, 2010 6:12 pm
Quoting tdscanuck (Reply 2):
You mean there is something even Tom doesn't know? Just kidding. But it does seem weird that it would be mounted on the side and not the top.
It would only provide a view during left turns. Right turns it would be pointed toward the ground.
nomadd22
Sat Jun 05, 2010 6:15 pm
It would be kind of strange. The little turntable type S-band antennas work at 30 degree banks, and a single one of those on top has much better coverage and gain than two flat panels. Unless they're phased array panels, which seems unlikely on a civilian plane.
Anon
zanl188
Sat Jun 05, 2010 6:40 pm
Quoting c5load (Reply 3):
Hmm... well I guess that would explain the second antenna on the left side....
Photo © Aurélien TRANCHET
HAL
Mon Jun 07, 2010 3:02 am
Same aircraft as the original post, different side:
Photo © Helmut Bierbaum
Yep, it's got the sat antenna on that side too!
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
Tristarsteve
Mon Jun 07, 2010 8:48 am
Just to add its pretty common nowadays to have the pair of flat panel sat antennae.
My question is, why do some airlines have big humps instead?
Is this for more bandwidth?, for live TV?
Or is it just old stuff? Must cost a lot in fuel consumption to carry a big hump around.
Mon Jun 07, 2010 9:28 am
Quoting Tristarsteve (Reply 7):
I heard mentioned in some ancient thread (so the following is either true or complete bullcrap) that the bump wasn't that draggy. It did some lifting too or something.
bikerthai
Mon Jun 07, 2010 1:59 pm
From what I remember, the humps usually involves a rotating "dish" antenna. The flats are phase array.
Quoting nomadd22 (Reply 4):
(edited for better example)
I think phase array for Satcom is in civilian use. BoeingConnexion (now defunct) antena were to be phased array.
bikerthai
[Edited 2010-06-07 07:32:47]
BigSaabowski
Wed Jun 09, 2010 2:01 pm
I always thought that was the HF antenna. 767ERs at Delta don't have satellite TV, and only a few of their ERs have SatCom.
[Edited 2010-06-09 07:03:47]
maddogjt8d
Wed Jun 09, 2010 2:34 pm
I thought the entire DL 763ER fleet was getting the Satcom mod, is that not correct?
Dalmd88
Wed Jun 09, 2010 3:31 pm
Quoting MadDogJT8D (Reply 11):
Correct, I believe it is becoming the norm for TATL comm. I think it may be required for the most desirable tracks due to reduced seperation rules.
Tristarsteve
Wed Jun 09, 2010 7:20 pm
Quoting BigSaabowski (Reply 10):
The HF antenna is half way up the leading edge of the fin. You can just make it out on the above pictures.
Thu Jun 10, 2010 11:17 am
Any Alternative closer view of this Antenna.
regds
MEL.
Users browsing this forum: Yahoo [Bot] and 13 guests
