klm672
Why Do Some Planes Divert And Others Don't?
Mon Jun 07, 2010 1:15 am
Hey,
Recently got a job working the ramp and today we had three flights divert. One EMB-170 tried 3 times to land, then diverted yet our next flight, due in a half hour after came right in. The weather was unchanged (to my eye). Meanwhile, another airline's EMB-190 came in 2 minutes after the diverted aircraft. Later our two other flights diverted, one ended up canceling about an hour after it diverted while the other one finally made it in. From what I can see, other airline's were coming and going. What are the factors/rules/regulations regarding diversions due to weather?
BMI727
RE: Why Do Some Planes Divert And Others Don't?
Mon Jun 07, 2010 1:20 am
In quite a few cases, flights will take on extra fuel if they anticipate bad weather so they can hold longer if needed.
CWAFlyer
Mon Jun 07, 2010 1:23 am
What airport do you work at? Are your airplanes and crews certified to land at CAT II or CAT III miniumums? Without knowing what the weather was at the time your airplanes diverted, I can only guess why yours diverted and others landed.
The regulations basicially require landing miniumums (visibility or RVR) prior to going beyond the final approach fix. Whether a plane diverts after missing an approach or several, it depends on how much fuel they had on board to allow holding and trying again.
klm672
Mon Jun 07, 2010 1:39 am
BTV and USAirways Express (Republic)
PWMRamper
Mon Jun 07, 2010 2:35 am
It's also possible the Pilot may have been a high mins guy, and couldn't land where others could.
bahadir
Mon Jun 07, 2010 2:49 am
Republic is CAT I , that might have to do with it. Also, the indifference to your eye doesn't mean anything. It 's what looks like to the eyes of the pilots.
Looks like visibility was pretty poor at some portion of the day today..
KBTV 061554Z 02005KT 1SM R15/6000VP6000FT RA BR BKN004 BKN034 OVC048 13/13 A2942
KBTV 061545Z 01005KT 1SM R15/6000VP6000FT RA BR BKN004 OVC036 13/12 A2943 RMK AO2 VIS 7/8V11/4 P0025
Earthbound misfit I
pnwtraveler
Mon Jun 07, 2010 3:24 am
It is the pilots call on recommendations from ATC and airline operations. ATC can close an airport which takes the decision away from the pilots, unless they declare and emergency. On the day Air France crashed at YYZ, the KLM 747 just before them diverted, while Air France continued and we know the outcome. Other aircraft also continued and landed safely. A lot goes into the decision. Fuel, duty hours, pilot experience, comments from other aircraft, etc.
apodino
Mon Jun 07, 2010 4:13 am
BTV currently has ILS outages to both 15 and 33, making the airport basically a VFR airport, which means you need 1000 feet for a ceiling and 3 miles visibility to land. GPS approaches can lower the minimums if the airlines ops specs allows it. However one of the other diversions you speak of was an Air Wisconsin CRJ, and Air Wisconsin is not certified to fly GPS approaches.
PH-TVH
Mon Jun 07, 2010 11:13 am
I think this is one of the most difficult questions you can ask here on the board....
Every case stands on itsself. I all comes down to decision making in the cockpit
based on a wide variaty of know and unknown factors. Think about weather,
fuel status, aircraft status etc... the obvious things.
But also consider: where does the company wants you to go? If everyone's diverting
to a small regional airfield... is it wise to go there as well? maybe save some feul and
divert to an airfield, maybe not specified on your flightplan but more convienent at that
moment?
And this is just a handfull of countless factors you have to consider when you are even
thinking about diverting....
Being a pilot is not that much exiting most of the time... But these are the moments
pilots have to perform to their limit to end the flight in the best interest of everyone,
flight safety upfront, but also for the company and the passengers.
Just my 2 cents
RiddlePilot215
Mon Jun 07, 2010 12:10 pm
Quoting KLM672 (Thread starter):
Hey,
From what most of my airline pilot buddies tell me it seems to me as though most airlines also have their own set of flight limitations depending on the weather conditions, AND both pilots have to be in agreeance that what both of them are looking at are indeed approach lights/ runway surface for the transition from instrument to visual flight during landing . Also, both the flightcrew and the airplane have to be certified for Cat II/ III operation. Third, weather is a very dynamic thing, what one pilot sees 2 minutes before the other is irrelevant other than for planning purposes. It could have very much been that the E170's pilots either didn't see the approach lights/ runway at all, they BOTH couldn't determine they were looking at the same thing and called TOGA, the tower instructed them to go missed, the pilot flew the ILS wrong (ie. too low/ too high/ too fast/ too slow/ not stabilized for the approach), the plane or the flight crew was not properly certified and current for the type of conditions encountered...etc., etc. Compared to the E190 crew that may have been all those things, or they caught a break in the clouds or visibility that allowed them to complete the approach.
Gotta love aviation.
God is good, all the time. All the time, God is good.
Goldenshield
Mon Jun 07, 2010 12:32 pm
Quoting pnwtraveler (Reply 6):
I can't say for Canada, but in the states, ATC doesn't close airports; airport operations does. As for diversion airports, the only time ATC would offer something is in an emergency; otherwise, the crew has already arranged something with his dispatcher.
As others have stated, it's what the pilot sees as he makes the approach that counts, not what the ASOS is reporting. It could be reported well above minimums; however, as an example, the pilot might have to make an approach through a fog bank and end up never seeing the airport.
isitsafenow
Mon Jun 07, 2010 6:02 pm
I was told its usually WITH EXECEPTIONS, pilot discretion on the diversion.
I was told by.............pilots.
safe
If two people agree on EVERYTHING, then one isn't necessary.
migair54
Mon Jun 07, 2010 6:39 pm
Quoting Goldenshield (Reply 10):
Whan an airport is officially below the minimums for landing with the RVR pilots are not allow to try to land......the airport is not close but is below minimums only planes who at that moment pass the IAF are allow to continue the approach....
Hey,
I´m sure they did the App when they reach the minimums for landing some of them see the runway and some didn´t, banks of fog move and horizontally and vertically, so it could be a big diff in a few minutes....
Last weed I was behind a EK B773 approaching DAR rwy 23 they went around and I landed 3 minutes after, just becuase the cloud move a bit and I was able to see the runway EK plane 10 min later landed as well.....storms develop very fast and in 1 hour weather could be very different.....
As comented before fuel is important some planes have more reserves than other so they can try more times or they can hold for longer.....but when a plane reach the minimum diversion fuel they must divert.......
Goldenshield
Mon Jun 07, 2010 6:57 pm
Quoting migair54 (Reply 12):
While I understand what you are saying---as I deal with it every day---what you quoted from me, and what you mentioned, are not related in any way. The ability to Close an airport has nothing to do with the airport being below minimums, ATC, or regulations (NOTAMs non-withstanding.)
DashTrash
Tue Jun 08, 2010 3:48 am
Quoting RiddlePilot215 (Reply 9):
Both pilots would be in agreement of what they're seeing by default. The non-flying pilot is looking outside the whole time and will call approach lights, or runway in sight. The flying pilot has his eyes in the cockpit until that call. When he hears it, he looks up, sees the runway calls "landing" and lands, or doesn't see it and goes missed.
You'll get a "go around" call, but not a "go missed" call from the tower. ATC isn't going to send you missed for an unstable approach either. When the weather is that low 99% of us will let Capt. Collins (or Honeywell) fly the approach. All we do is control the speed (unless you have an autothrottle) and monitor the autopilot's performance. The autopilot doesn't fly unstable approaches in most conditions.
Quoting Goldenshield (Reply 13):
The only time I've ever heard of ATC "closing" an airport was for an aircraft emergency. Weather won't do it.
To the original question, with everyone flying VOR or RNAV / GPS approaches, I imagine the JetBlue? E-190 is certified to use VNAV on the approach giving them much lower minimums than the E-170s who aren't certified for it. With the VNAV, the FMS will fly a computer / GPS generated glideslope turning a non-precision approach into a precision approach. In some cases the approach minimums are as low as a conventional ILS.
[Edited 2010-06-07 20:53:56]
bri2k1
Tue Jun 08, 2010 11:29 pm
Not exactly, at least, not in the US. While a transmissometer can be used to measure actual RVR, the visibility limit is flight visibility, not ground visibility. There are no flying ATC towers, so only pilots can determine flight visibility. (How they actually do this is another matter.) But when flying under Part 91 (private), it doesn't matter what the ground conditions are reporting; technically, you can legally start the approach, and when you arrive at the MAP or the time expires (non-precision), if you don't have the runway environment in sight, you go missed. Most Part 135 and Part 121 (commercial and air carrier ops) rules do require the reported visibility to be above minimums before the approach can be attempted. Practically, if the report is 0/0, it's not likely to change in the few minutes it takes to fly a glideslope. But the airport isn't closed just because of low 1visibility.
Position and hold
DashTrash
Wed Jun 09, 2010 4:50 am
Quoting bri2k1 (Reply 15):
Mostly, but RVR is controlling. If it's below mins, you can't fly the approach (121/135).
bri2k1
Wed Jun 09, 2010 6:27 am
Quoting DashTrash (Reply 16):
Very true.. The key point I'm making is that just because *you* can't attempt an approach doesn't render the field closed.
Position and hold
Users browsing this forum: Baidu [Spider], Bostrom, rg787 and 8 guests
