c5load
Weights On This Tanker DC-10
Wed Jun 09, 2010 1:30 am
Noticing the photo of this DC-10 tanker, I saw that the center bogie has been removed to provide for the tanks. DC-10s needed that bogie for support, so did they strengthen the main gear? Does it ever takeoff at MTOW, b/c if it doesn't would be a need for that center bogie to begine with?
Photo © Nicholas Vollaro
"But this airplane has 4 engines, it's an entirely different kind of flying! Altogether"
zanl188
RE: Weights On This Tanker DC-10
Wed Jun 09, 2010 1:45 am
I'd suggest that the tanks are removable and that the center gear has been retracted & disabled vs removed.
474218
There is no need for the center line gear as the takeoff weights are much lower than a standard DC-10-30.
Remember, the interior has been removed, its carrying no cargo and it would have a very light fuel load.
c5load
Wed Jun 09, 2010 2:13 am
Quoting 474218 (Reply 2):
Will it ever carry cargo? I only ask b/c it's seems like kind of a waste of a large airplane just for the water tanks. Or, as ZANL188 said, can the tanks be removed and operate as a normal cargo plane?
kl671
Wed Jun 09, 2010 2:17 am
Quoting c5load (Thread starter):
The tanker that you referenced is a modified DC10 -!0 and as delivered did not have the centre bogie. Only the -30 and -40 series DC10s were equipped with the extra gear.
http://www.air-and-space.com/DC-10%20Tanker%20Air%20Carrier.htm
Probably every time. Fire tankers are based as close to the fire as they can reasonably get. Thus they are fuellled with the minimum load required to complete the mission. The water/fire retardant tanks are then filled till the aircraft MTOW is reached.
Swapping range for load.
dtw9
Wed Jun 09, 2010 2:57 am
Quoting kl671 (Reply 4):
910 is a series 10. The above photo shows 911, which is a series 30
TZTriStar500
Wed Jun 09, 2010 3:00 am
Quoting c5load (Reply 3):
Its not a cargo configured aircraft and does not have a main deck cargo door. The aircraft's payload capability is simply being used to carry an external load via retardant tanks rather than internally which is enhanced with the interior removed and any other non-essential items. This is a permanent conversion and the center gear has most-likely been removed to save weight, not just locked up. The aircraft have been modified by STC ST01870LA.
http://www.air-and-space.com/DC-10%2...r.htm
You are talking about the original aircraft Tanker 910 which is a DC-10-10. Tanker 911 is a -30 with the center gear removed. The -30 is capable of being operated without the center gear, but at reduced weights. However, even with the center gear removed, the -30 has greater payload capability than the -10.
In the case of Tanker 911, the MTOW of a standard DC-10-30 is never reached as the center gear is removed, but the reduced MTOW may be. This aircraft S/N 57957 is eligible for a 572K MTOW, but according to page 10 of the TCDS A22WE http://www.airweb.faa.gov/Regulatory...0a862575d1006f7449/$FILE/A22WE.pdf the MTOW is reduced to 475K with the center gear retracted.
[Edited 2010-06-08 20:06:46]
[Edited 2010-06-08 20:20:00]
35 years of American Trans Air/ATA Airlines, 1973-2008. A great little airline that will not be soon forgotten.
Fly2HMO
Wed Jun 09, 2010 4:15 am
Don't think so, unless its stuff related to the fire mission, because with this barren interior I don't see any provisions for carrying pallets and such.
Photo © Matthew C. Lyons
Viscount724
Wed Jun 09, 2010 11:16 pm
Quoting dtw9 (Reply 5):
The DC-10-30 in the photo was originally delivered to Finnair in 1975. After about 20 years with Finnair, it then spent a couple of years with defunct French carrier Air Liberte, then about 5 years with Continental, followed by another 5 years or so with Omni.
Photo © Juhani Sipilä
Photo © Joe Pries - ATR Team
Photo © Jonathan Derden - Jetwash Images
ex52tech
Wed Jun 09, 2010 11:46 pm
I can't imagine that they takeoff even close to MTOW due to the proximity to the fire and you would not want to fly that airplane low and slow that heavy.
"Saddest thing I ever witnessed....an airplane being scrapped"
kl671
Thu Jun 10, 2010 12:58 am
Quoting TZTriStar500 (Reply 6):
oops. I don't know how I managed to confuse the two aircraft. It is certainly not because the tail numbers are difficult to read.
Users browsing this forum: BartSimpson and 21 guests
