747classic
GEnx Modification Status
Thu Jun 17, 2010 11:06 am
After the long awaited first flight of the fifth test 787-8 aircraft, ZA005, powered with GEnX-1B engines,
the following questions regarding the GEnX-1B and -2B come up :
- What is the current status of the GEnx-1B engine ? What has been changed (modified) since the certification in March 31, 2008 !!!!
- According the latest articles a final upgrade is planned for the -1B, to overcome approx 2% shortfall in TSFC. What will be changed or modified by this upgrade?
- Are both engines on this moment comparable in modification status or is the -2B further modified (improved) ?
- Has the GEnx-2B passed the icing certification testing?
- Is there also a final upgrade for the -2B engine ?
- Will both engines receive certification at the latest possible moment, together with the 788 and the 747-8F, to include the latest modification standard ?
Operating a twin over the ocean, you're always one engine failure from a total emergency.
tdscanuck
RE: GEnx Modification Status
Fri Jun 18, 2010 6:04 am
Quoting 747classic (Thread starter):
Both engines are already certified.
As they do modifications, those are certified "in-line", just like service bulletins on an aircraft. You don't re-issue a type certificate every time you modify the design.
Tom.
747classic
Fri Jun 18, 2010 9:04 am
Quoting tdscanuck (Reply 2):
According the Type Certificate of the GEnx ( E00078NE ) only the -1B variants are certified in March 31, 2008.
see : http://www.airweb.faa.gov/Regulatory...E2ACB862574250061F9CB?OpenDocument and download PDF file.
The --2B variant is not mentioned and must be added in the next revision. Up to now this variant is NOT certified.
With major changes (as performed on the -1B during the last two years ,since certification) the Type Certificate will probably be amended by issuing a new revision, with updated modification (SB) status, mostly done via added remarks.
747classic
Tue Jun 22, 2010 4:44 pm
The GEnx-1B will be re-certified and the -2B certified in July 2010.
"We will re-certify all improvements [to the -1B] in July," says GEnx programme manager Tom Brisken. "Meanwhile, testing is complete on -2B and certification reports have been submitted." GE had initially gained US Federal Aviation Administration certification for the -1B engine in March 2008, but durability and operability issues with the fuel nozzles in the lean-burn combustors and the advent of delays in the 787 programme gave GE time for a redesign that must now be recertificated.
Full article see : http://www.flightglobal.com/articles...id-july-nod-for-genx-siblings.html
Users browsing this forum: A380MSN004, bohica, hongming and 1 guest
