NoWorries
Boeing 787 Withstands First Lightning Strike
Thu Jun 17, 2010 1:23 pm
It shouldn't come as any surprise, but the 787 survived its first strike ...
http://www.businessweek.com/news/201...tning-strike-as-tests-advance.html
bikerthai
RE: Boeing 787 Withstands First Lightning Strike
Thu Jun 17, 2010 1:47 pm
It really depends on where the lighting hit. I mean, if it hit the engine naccelle, the empenage, the radome, trailing surfaces, then the reaction wouldn't be any different than it would if the lightning hit a 777 because the construction of those items are the same (or almost the same).
It will be interesting to follow this development. I'm just tagging this to better track this discussion.
bikerthai
BlatantEcho
Fri Jun 18, 2010 3:29 am
It's going to get struck by lightning all the time in service, of course it's going to do fine.
Sure, it's super top secret carbon-fiber....but you think this didn't get planned for?
They're not handing trophies out today
NoWorries
Fri Jun 18, 2010 11:16 am
I am a little curious -- the article mentions that there were no signs of any damage. When an inspection is performed after a strike, how often are there no signs of damage vs. signs of some damage vs. serious damage. Would it be safe to say that most of the time there is little or no damage? Many modern planes have at least some parts made of composite -- is the incidence of damage for those parts comparable to more traditional material?
[Edited 2010-06-18 04:20:37]
SEPilot
Fri Jun 18, 2010 7:09 pm
I certainly find this encouraging-this was the biggest worry I had about the 787, even though I had confidence that the Boeing engineers had adequately provided for it. I had no fear that lightning would actually bring the plane down, but I was concerned that it might burn out some of the wire mesh embedded in the composite, which would be a very expensive thing to repair. But it is very good news to me that it actually encountered lightning and survived unscathed.
Fri Jun 18, 2010 8:49 pm
Quoting NoWorries (Reply 3):
Thats odd,shouldn't there be an Entry & Exit point post lightening strike.
regds
MEL.
planenutok
Fri Jun 18, 2010 11:21 pm
Quoting HAWK21M (Reply 5):
regds
MEL.
Every lightening strike that I have worked has had damage to some extend if it was actually hit. The damage varies from discolored paint at entry or exit, to holes in the airframe and blown off static wicks. Now a suspected lightening strike on the other hand may or may not have actually hit the airframe but the crews will still write up a strike if they see a bright flash close by. That's my 2 cents.
Sun Jun 20, 2010 3:09 pm
Quoting Planenutok (Reply 6):
Flash visible closeby in Flight would mean a high chance that the Aircraft in question has encountered lightening strike.So there would have to be an Entry & exit point.
regds
MEL.
mrskyguy
Mon Jun 21, 2010 12:20 am
One would imagine this is tested extensively on the ground in controlled lightning generation facilities, no? I'd imagine the effects of a lightning discharge on these materials would be well known and documented, leaving the airborne proving runs for the FAA's requirements.
"The strength of the turbulence is directly proportional to the temperature of your coffee." -- Gunter's 2nd Law of Air
tdscanuck
Mon Jun 21, 2010 2:26 am
Quoting MrSkyGuy (Reply 8):
They are. Which is why it's so hilarious to watch so many people think this is some kind of huge unknown risk.
They are. Have been for more than 25 years.
You don't have to prove lightning strike capability by flight test (that would be a stupid way to "prove" it anyway)...you never intentionally get the plane hit by lightning for commercial certification.
Tom.
Users browsing this forum: Google [Bot] and 10 guests
