crazyboi
AirNZ Self-Driving Tugs
Wed Jun 30, 2010 12:18 am
Hi All. Apologies if this has been discussed - I did some searching, but couldn't find anything. Perhaps I'm not familiar with the terminology involved.
I was at Auckland recently waiting for a domestic connection and sat in the terminal watching AirNZ 733's being pushed back. I was surprised to see a one-person pushback procedure that I'm not familiar with...
There was a small tug connected to left gear and facing *away* from the terminal. The pushback engineer connected his headset to the nose of the 737, as usual, and walked the aircraft away from the gate, but there was *no driver* on the tug. In fact, after pushback, the tug appeared to disconnect itself from the landing gear, drive itself back a safe distance, at which point the engineer walked over, got on, and drove back to the terminal.
Is this new technology? Is it widely implemented or unique to narrow-body operations at AKL? Is the tug control wired to the engineer (ie, does he/she 'drive' the tug remotely?), or is it guided wirelessly? Pretty interesting stuff.
This is the time. And this is the record of the time.
contrails15
RE: AirNZ Self-Driving Tugs
Wed Jun 30, 2010 12:22 am
As someone who has been pushing aircraft for almost 8 years now I've never heard of such of thing and for sure never heard of it in the states. I'm not doubting what you saw but a driver less pushback is way out in left field for me. I can't imagine how they would work. We're supposed to have a headset and a driver during push but in some cases the driver will where the headset and drive. Thats pretty standard at a lot of other airlines.
Giants football!!!!!!!!!!!!!!!!!!!!!!!!
Kent350787
Wed Jun 30, 2010 12:23 am
DJ uses them at Sydney domestic as well (Jet* too maybe?) - not sure about your other questions
contrails15
Wed Jun 30, 2010 12:28 am
What would we do with out youtube.
http://www.youtube.com/watch?v=48hGwauUbsQ
Wow, looks like I'm out of a job.
aerorobnz
Wed Jun 30, 2010 12:32 am
It's suited to 737 ops in tight gate spaces. if I recall the Engineer has a hand held controller in his hand. If that's not what it's for not I'm guessing it is preprogrammed by the engineer to a particular gate pushback so that it drives to the correct position and the controller is just an emergency stop button.
To my knowledge it has been in place for an extended period of time. I'm thinking 5-6 years if not longer.
Flown to 128 Airports in 48 Countries on 81 Operators. Visited 56 Countries and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
ikramerica
Wed Jun 30, 2010 12:42 am
Quoting contrails15 (Reply 3):
One of the worst jobs of filming I've seen in a while. He misses everything important, but talks a lot...
crazyboi
Wed Jun 30, 2010 12:51 am
Brilliant, thank you.
This seems like a great use of existing technology. I wonder whether it works with other types, like the A320.
BoeingVista
Wed Jun 30, 2010 1:00 am
Quoting crazyboi (Reply 6):
Used to watch them do this at Wellington all the time on the 733 but never on the A320 on neighbouring gates so assuming that for some reason its not possible (wheel sizes, weights?).
[Edited 2010-06-29 18:11:03]
BV
dinker225
Wed Jun 30, 2010 1:09 am
I seem to recall seeing this done in Australia on a few of my visits. I believe with Virgin Blue on their 737's. It's very neat to watch. Kind of suprising we havnt seen it in the US yet.
Dinker
[Edited 2010-06-29 18:10:55]
Two rules in aviation, don't hit anything and don't run out of gas, cause if you run out of gas yer gonna hit something.
ZKOJH
Wed Jun 30, 2010 1:12 am
Well it was being used at AKL back in 2006/7 when I worked their, its a great job and looks so cool, I think I only recall seeing it used at the NZ domistic terminal - when I had to nip accross there. I hope it works well with the A320's as ANZ have ordered them to replac all 733's ops inc domistic services.
Vietnam time..
Boof
Wed Jun 30, 2010 1:26 am
Quoting BoeingVista (Reply 7):
Used to watch them do this in Wellington all the time on the 733 but never on the A320 on neighbouring gates so assuming that for some reason its not possible (wheel sizes, weights?).
JQ use them here in Australia. I've seen them in photo in the database connected but if you take a peek at the large version of this photo:
Photo © Nathan Bartlett
You can see the remote tug sitting under the wing box of this JQ A321 @ MEL. Once the rear stairs are removed the ground crew will manually drive it forward (you can see the seat and the steering wheel at the back of the unit) and connect it to the left main gear. It will then be operated remotely for the pushback.
During the use of these things the Skipper actually steers the aircraft with the nosewheel tiller in the cockpit taking directions from the ground crew member. Once the disconnect point is reached the ramper simply remotely disconnects and drives it like a remoter control car backwards until the aircraft is clear then he/she drives it back to the gate. It's pretty clever really!
Boof
Edit: I found the picture I was looking for and it is a beauty for this topic:
Photo © George Canciani
[Edited 2010-06-29 18:49:08]
If only B6 flew in Australia...
crazyboi
Wed Jun 30, 2010 2:22 am
Boof - that's fantastic, thanks. I wonder whether the liability issues associated with using a remotely-operated vehicle are one of the reasons that we don't see these in the US. I can imagine that narrowbody operators like Southwest would find them very useful.
BoeingVista
Wed Jun 30, 2010 2:25 am
Quoting Boof (Reply 10):
Cool, where can I get one?
BV
Boof
Wed Jun 30, 2010 5:08 am
Quoting crazyboi (Reply 11):
Your welcome. I always thought that looking at every photo in the database would come in handy someday!
As for the liability I'm not too sure, certainly in Australia we are as prone to the joys of public liability etc as much as in North America so I doubt it's that reason.
Maybe it's got something to do with unions and jobs?? These machines only require one person to operate so I'm guessing that might be a reason. Funny thing in Australia and NZ we don't use wing walkers, come to think of it they don't in Europe either, yet in the North American region they are commonplace even when pushing a smaller jet like a 320 or 73G. Is that a union job saving things as well?
airportugal310
Wed Jun 30, 2010 5:14 am
Quoting Boof (Reply 13):
You took the words out of my mouth. I would almost bet some money thats part of the reason.
But then again I have trouble seeing this work in some tight spaced airports like JFK, BOS, LGA etc...too many planes too close to one another in tight alley ways etc.
And on the flip side of that, its not worth the money probably to put such equipment at out-stations or low-traffic airports.
I sell airplanes and airplane accessories
antoniemey
Wed Jun 30, 2010 5:49 am
The number of wing-walkers required varies between airlines and equipment types... I have, in fact, pushed RJs out with just the tug driver and me, and I was walking next to the tug to maintain eye contact with the pilot. At the same company we wouldn't push an MD or Boeing or Airbus aircraft out without wing walkers on each wing.
Basically, in this case, it's more the companies trying to avoid having their insurance rates due to ramp rash rather than unions, because where I worked was non-union and any time we heard of a case of equipment hitting an aircraft or two aircraft colliding on the ramp that type of thing would be a focus for the supervisors for the next few weeks.
Of course, if we weren't busy we'd have the full 3-person push crew plus driver on even the smallest aircraft... except at the gate where the RJs could turn directly out... that one was fun.
Make something Idiot-proof, and the Universe will make a more inept idiot.
Wed Jun 30, 2010 6:21 am
Some other a.net discussion on the same topic
Strange Pushback Pic (by TheGregster Mar 31 2006 in Tech Ops)
Main Gear Pushback (by Speedbrds Jun 20 2009 in Tech Ops)
Pushback Using MLG -- B737 (by Brenintw Dec 4 2006 in Tech Ops)
I think it would be that tugs are already in place, the airlines that are using them had the choice of getting normal tugs, or these towbar less machines. And no towbar to shear.
I remember a case in Australia where someone picked up the wrong remote control, and started to push the aircraft from the adjacent gate.
Quoting Airportugal310 (Reply 14):
Yes, 1-2 less people require to turn an aircraft around.
If they have gates, it would be worth it, less people to employ.
Usair1
Thu Jul 01, 2010 3:33 am
Doubt that. The company I work for (US) is the reason we have two wing walkers and a push tug driver for EVERY push back. It is a safety issue. With the amount of congestion, ramp clutter and ever changing ramp tower instructions, it would significantly increase the number of aircraft damages on the ground. We used to only require one wing walker and there were too many aircraft damages. It wasn't any union who mandated two wing walkers it was the company because it was costing them much more money in damages. Aircraft damage is a serious thing and very costly.
crownvic
Mon Jul 05, 2010 10:52 pm
Saw this today at Sydney Kingsford airport for the first time...In a million years I would have never believed it if I hadn't seen it with my own eyes! What a strange sight watching the Virgin Blue planes push away from the gate with a remote...I doubt this will ever come to the states..Huge liability I'm sure....
Users browsing this forum: MSJYOP28Apilot and 2 guests
