f35
Runway Numbers And GPS Approaches
Mon Jul 12, 2010 11:22 pm
I am coming up on my checkride(tomorrow) for my instrument rating. Any help with these two questions would be amazing. Thank You in advance.
First Question: What does U mean if it follows a runway number. For example at X21(Arthur Dunn Arpk) there is a runway titled 22U.
Second Question: Because X21 is my alternate and it only has 2 GPS approaches, do I need an alternate. I know that if your primary airport only has GPS approaches you must file an alternate to another airport with an approach other than GPS. Does this apply all the time or just when weather is outside of the 1-2-3 rule/alternate requirements?
DiamondFlyer
RE: Runway Numbers And GPS Approaches
Mon Jul 12, 2010 11:31 pm
Quoting F35 (Thread starter):
Its an ultralight runway. After looking in the A/FD, it says ultralight/STOL aircraft only, which is logical considering its surface and length.
I'd use the 1-2-3 rule to decide if I need an alternate. If it turns out you need one, you've got to pick another airport. Depending on the GPS setup you've got (TSO 129 vs 146) you might need an airport with something other than a GPS approach, or you may not. You'd also need to make sure the approach/airport you want to use as an alternate is approved as an alternate.
-DiamondFlyer
From my cold, dead hands
adipasqu
Mon Jul 12, 2010 11:33 pm
Quoting DiamondFlyer (Reply 1):
It's also unpaved (turf).
707 722 732 733 734 735 73G 738 739 741 742 752 753 762 763 764 D9S D10 319 320 321 M80 M82 M83 M87 M88 M90 SF3 ERJ CRJ
Mir
Tue Jul 13, 2010 12:07 am
If X21 has only GPS approaches, it cannot be your alternate. Take a look at AIM 1-1-19-g (the note at the bottom). That's true whether your primary airport has only GPS approaches or not.
You'll also note that both approaches to X21 are not authorized as alternates. So you can't file that airport as an alternate (if a filed alternate is required - use the 1-2-3 rule for that). Were you instructed to use that airport as an alternate?
-Mir
DiamondFlyer
Tue Jul 13, 2010 12:37 am
Quoting Mir (Reply 3):
Not always. If your equipped with a TSO 146 GPS, it is possible to use a field with GPS only as an alternate, as it is possible to operate in the IFR environment with nothing more than a GPS receiver for navigation.
-DiamondFlyer
f35
Tue Jul 13, 2010 1:58 am
Sorry for the confusion. I meant to ask "Because X21 is my destination, and it only has GPS approaches and the aircraft i am flying does not have WAAS, do i need an alternate?" I believe no is the answer but am not confident in my answer.
N353SK
Tue Jul 13, 2010 2:20 am
You've been studying too much lately and all the rules are blending together.
If your destination has an IAP you don't need to file an alternate unless the destination's weather doesn't satisfy the 1-2-3 rule.
IAHFLYR
Tue Jul 13, 2010 2:48 am
Just stop!!!!!!!!!!!!! Rely on your training and what you have studied.
Get your flight plan, check the weather and NOTAM issues, file the flight plan that you know how to file, and pre-flight the aircraft......AND BE COMFORTABLE.
Be confident in your knowledge and training.
DONE!
highflyer9790
Sat Jul 17, 2010 8:27 pm
Quoting F35 (Reply 5):
IF the 1-2-3 rule indicates you need an alternate, and you have looked at whether or not there are alternate minimums, (found on the approach plates with an "A" in a black triangle) then YES, you NEED an alternate with an approach other than GPS. the alternate can have a GPS approach, however it must have another type of approach as well such as a VOR or ILS. You answered the first half of your question when you said you are not WAAS capable, otherwise your alternate could have a WAAS approach and youd be fine.
If you weather is above the 1-2-3 rule, you technically only need an alternate if the airport has no published IAP.
121
Users browsing this forum: GalaxyFlyer, STLflyer and 14 guests
