jetmech
Jet Engine Heat Usage
Tue Jul 20, 2010 7:34 am
G'day Techies,
I found an interesting diagram about the P&W F135 engine, which powers the F-35 aircraft. I find it interesting that the waste heat is supposedly the same wether the lift fan is operating or not. I thought the amount of waste heat may be less with the lift fan operating. What do you think?
http://upload.wikimedia.org/wikipedia/commons/6/68/JetEngineGraph-LiftFan.PNG
http://en.wikipedia.org/wiki/Pratt_&_Whitney_F135
Regards, JetMech
tdscanuck
RE: Jet Engine Heat Usage
Tue Jul 20, 2010 10:03 am
Quoting jetmech (Thread starter):
If the fan is running, it's extracting power from the turbines, which means less energy entering the nozzle, but it also means a bigger pressure drop in the turbines so the nozzle can do less work. At least as far as PW concerns, the energy extracted to the lift fan is exactly balanced by the energy not extracted by the nozzle, so the amount of waste heat holds constant. That makes some sense in my head, although I doubt it works out exactly that well in real life.
Tom.
Faro
Tue Jul 20, 2010 1:36 pm
Quoting tdscanuck (Reply 1):
Is the F135 a pure turbojet or am I seeing things? I can't seem to find a fan stage ahead of the compressors...
Faro
The chalice not my son
rwessel
Wed Jul 21, 2010 12:17 am
Quoting faro (Reply 2):
That looks like a fairly generic jet engine diagram. There are good cutaways on P&W's site:
http://www.pw.utc.com/StaticFiles/Pr.../Images/f135-ctol-cutaway-high.jpg
http://www.pw.utc.com/StaticFiles/Pr...Images/f135-stovl-cutaway-high.jpg
You can clearly see the bypass area (small though it may be, at about .57).
tdscanuck
Thu Jul 22, 2010 1:37 am
I meant the lift fan...the shaft going out the front in the OP's image feeds a RR lift fan ahead of the engine.
Tom.
jetlife2
Thu Jul 22, 2010 1:07 pm
Horribly irrelevant diagram on wikipedia. Single shaft turbojet used to illustrate a turbofan - lift fan combination! LOL. Someone with the time and energy should replace it. JetMech you are just the man for the job.
My views are not necessarily the views of the GE Company
Users browsing this forum: 77west, LY777 and 25 guests
