Aircellist
To And Landing In Opposite Directions - Practical?
Wed Sep 08, 2010 12:26 am
This very nice picture was among the most viewed ones, recently:
Photo © Jan Heistermann
I often wondered whether something like that could be done here, in YUL. There are parallel runways as well, and I suppose that doing so could shave a few minutes from the transatlantic flights, on low wind days.
So, is it practical? When is it done? And why is it not done more often?
Thanks in advance.
"When I find out I was wrong, I change my mind. What do you do?" -attributed to John Maynard Keynes
DashTrash
RE: To And Landing In Opposite Directions - Practical?
Wed Sep 08, 2010 2:10 am
Aspen and Sun Valley do it all the time. It's interesting watching the TCAS going into those places. Coming out it's odd to see an aircraft on final while you're on the takeoff roll.
flybaurlax
Wed Sep 08, 2010 2:36 am
It happens at LAX nightly for the noise abatement procedures. It's pretty cool. They take off on the 25s and land on the 06s, so everything is out over the ocean. I was jumpseating on a flight where we were the first to switch to land eastbound, and there were still some a/c lining up in the opposite direction as we were lining up. Of course we were much further out to give them room to vacate the runway, but it was really cool looking out at aircraft directly opposing you for the same runway.
Boilerup! Go Purdue!
etherealsky
Wed Sep 08, 2010 2:56 am
Quoting aircellist (Thread starter):
I suppose airlines would probably enjoy it if it reduced flight times a bit, but:
Aside from the most obvious reason (wind), I believe all ATC facilities operate in accordance with pre-established procedures and traffic "flows" which are developed with safety taking the top priority, and convenience coming in second.
For example at my airport, controllers use a "North flow" or "South flow" depending on the wind (conditions are rarely completely calm) and even though we have intersecting runways, I'm sure that larger airports with parallel runways operate on the same principles. The idea (as I understand it) is to keep everyone moving in the same general direction; this helps controllers organize & coordinate everyone much easier, especially when traffic picks up. Let's say that you are using opposing runway directions for arrivals and departures, and all of the sudden a storm front moves in and the wind starts gusting; if you are using opposing runway directions for arrivals and departures it might add quite a bit to your workload to re-arrange everyone to use the same runway directions.
Another safety concern would relate to missed approaches & go-arounds; by having arrivals approaching in the opposite direction of departures, you decrease the margin of safety if (for example) a pilot mistakenly turns the wrong direction on a go-around or missed approach (and into the path of an aircraft on climbout). The same could be true for a departure that encounters an emergency on takeoff/climbout. These dangers would only be magnified during operations in poor visibility/low ceilings.
There is also the issue of many airports which have only certain approaches on certain runways (ILS is a common example)... that would complicate things as well.
Finally, the whole idea of using opposing runways for arrivals & departures is pretty 'nonstandard.' As time has proven again and again, standardization (especially when it comes to procedures) is the way to go as far as aviation is concerned.
"And that's why you always leave a note..."
KELPkid
Wed Sep 08, 2010 5:02 am
Well, when the winds shift, something's gotta give...   I'm sure ATC lets someone already lined up for takeoff at a runway continue even when they switch directions on the field.
At ELP, WN usually tries to depart on the runway that will result in the shortest ground time (wind permitting, of course). I have seen WN depart 8R plenty of times when the ATIS said "Landing and departing Runway 26L". If the controller says yes, and they can space it, they will allow someone to go against the flow.
As an instrument student and pilot, I have shot the ILS (always to a missed approach, though) several times where we are going against the traffic flow. If an airfield only has an ILS on one runway, and traffic is departing and landing the other way, the only other choice is not to shoot the ILS. Controllers are usually pretty accomidating, although they may insist on extra vigilance or sidestepping the centerline on the missed approach... If you have to do it to a full stop, they will probably ask you to circle to land (if it's allowed on the approach).
thegeek
Wed Sep 08, 2010 6:40 am
My understanding is that its permitted in Australia if the separation between the runways is large. SYD does not have such separation.
swiftski
Wed Sep 08, 2010 12:03 pm
Quoting thegeek (Reply 5):
But SYD does permit SODPROPS
flyboysp
Wed Sep 08, 2010 1:45 pm
Quoting swiftski (Reply 6):
Indeed. Here is the link to the modes of operation for SYD
http://www.sacf.infrastructure.gov.a...general_information_fact_sheet.pdf
#proudtobeabulldog
Aircellist
Wed Sep 08, 2010 3:29 pm
Thanks for all those informations. It mostly goes along the lines I had figured, or the bits I knew. Yet, I somehow regret that our airport never seems to be on the quick side, when there is innovation around. Or, if it is, I never hear about it. I feel that Dorval, being a moderately busy airport, could be a very interesting field of experimentation... RNP, continuous descent (which is probably more or less a given here, because there is not much waiting), ecoflights...
... Except, maybe, for that procedure (of which I read about in A.net) requiring planes taking-off eastward to turn over the motorway giong north, instead of overflying populated areas... A procedure AC pilots could generally do easily, but which was less obvious for foreigners.
Back to my own topic: when I see European-bound airplanes taking-off over the west-island, in the opposite direction of their flight for relatively so long, I always wonder why they do not turn any earlier, over the lake... Or take-off in opposite direction.
Ah, well, it's not my business...
Stealthz
Wed Sep 08, 2010 4:10 pm
There is something lke 1km separation between the runways at SYD, much greater than the separation at places like SFO & DFW, combined with a threshold displacement of approx 2.4km from North dir and about half that from the South, safety margins are just fine.
Indeed given those threshold displacements one could almost run SODPROPS* from a single (longer) runway... but wouldn't!
* would it then be SODSROPS?
71Zulu
Wed Sep 08, 2010 8:23 pm
Quoting KELPkid (Reply 4):
WN does this at MSY all the time too, they will ask for 28 departures when traffic is landing on 10 (same runway). If the controller can fit them in between arrivals, they will let them do it.
Clickable links only please!
rduoodl
Thu Sep 09, 2010 2:22 am
Pretty common at night in RDU when the cargo heavies leave. If the wind is calm they request 23R departures, very close to the cargo ramps. I have seen this done with GA aircraft on approach to 5R. Kind of funny to hear a pilot's reply when their traffic is a heavy MD-11, opposite direction, off the parallel.
Previous: RDU-DTW-LAS-LAX-SYD Up Next: RDU-ATL-MEX
thegeek
Thu Sep 09, 2010 7:30 am
Not completely sure what SODROPS stands for, but looking at the map I would presume that an aircraft can't be leaving the ground if another is approaching the other runway. But once one of the aircraft turns away and has an adequate separation, then there are no further restrictions.
Stealthz
Thu Sep 09, 2010 12:28 pm
Quoting thegeek (Reply 12):
SODROPS
Simultaneous Opposite Direction Runway Operations or something very close
My understanding is the separation and displacement of the two runways provides the required clearances, Jan's photo seems to illustrate a take off whilst the BA is approaching.
thegeek
Fri Sep 10, 2010 3:38 am
Quoting stealthz (Reply 13):
Didn't notice that was taken at SYD!
Seems the rules have changed, or I was misinformed! That's interesting.
AJ
Sat Sep 11, 2010 7:25 am
It is being used at Sydney Airport as I type, mainly for noise abatement.
ATIS YSSY E 110709
RWY: 34L FOR ARRS, RWY 34L AVBL FOR DEP IF OPERATIONALLY
REQD OR AS DIRECTED BY ATC.
RWY 16L FOR ALL OTHER DEPS
OPR INFO: SIMULTANEOUS OPPOSITE DIRECTION PARL RWY OPS IN PROG
+ WIND: 040/10
XW 9 KTS,
DW 5 KTS, RWY 16L
WX: CAVOK
+ TMP: 16
QNH: 1017
Users browsing this forum: 26point2, Florianopolis and 23 guests
