alwaysontherun
Question About The MD-11 Empennage
Tue Sep 14, 2010 3:50 pm
For those in the know:
Looking at the pic below today I noticed that the MD-11 vertical stabilizer consists of many "patches"……I put some green dots on the pic to indicate what I mean:
The sting is in the tail
Why is that??
The 747 tail looks so "clean" compared to the MD-11.
2nd question, where I painted my red dot--> what´s the purpose of that fin please?
Has it something to do with guiding the thrust from #2 engine??
Cheers!
###"I´m always on the Run"###
"Failure is not an option, it comes standard in any Windows product" - an anonymous MAC owner.
474218
RE: Question About The MD-11 Empennage
Tue Sep 14, 2010 4:20 pm
Those are access panels, not patches. There are components inside that require being accessed periodically.
Nicoeddf
Wed Sep 15, 2010 2:48 pm
...and actually I think, the paint job of the 747 is just way newer. So the perceived "patching" is just more visibile through already faded paint and dirt accumulation.
tdscanuck
Wed Sep 15, 2010 4:27 pm
Quoting nicoeddf (Reply 2):
Indeed. Here's the access panel diagram for a 747-400 fin:
http://img695.imageshack.us/img695/2885/747400fin.jpg
Tom.
tsugambler
Wed Sep 15, 2010 5:03 pm
Quoting alwaysontherun (Thread starter):
That "fin" is actually the engine pylon... it's part of the one-piece "banjo" structure that supports the vertical stabilizer. The #2 engine is actually "hanging" from that pylon, just like the #1 and #3 engine are hanging from the wing-mounted pylons. As to why it has to be that particular length, I have no idea--perhaps it's something to do with airflow and drag.
Wed Sep 15, 2010 5:45 pm
Those "patches" are actually Access panels used to access areas during routine Inspection/servicing.Once opened they tend to leave a visible borderline over time if a new paint job is not carried out or aircraft not cleaned.
regds
MEL.
etherealsky
Thu Sep 16, 2010 12:35 am
I've been trying to find a good photo of it or a link to more info (no luck so far), but on the King Air 200 I believe the tail section is life-limited as an assembly, however there is an STC out there that removes this limitation with the installation of inspection panels that run vertically along the tail spar.
"And that's why you always leave a note..."
alwaysontherun
Sun Sep 19, 2010 1:59 pm
Quoting tdscanuck (Reply 3):
A picture tells a 1000 words………..
I´m amazed by the amount of access panels!!
Entrance is normally only required during the heavier checks, I imagine.
I have never seen anybody accessing a plane´s fin at a gate for instance.
Quoting tsugambler (Reply 4):
Now if you look right under the Dutch and the European flag of the 2nd plane (B744) in the pic, like right below it; there´s a horizontal recess in the MD11´s pylon--> like a horizontal hole of about a meter--> does anybody know what´s that for?
tdscanuck
Sun Sep 19, 2010 2:10 pm
Quoting alwaysontherun (Reply 7):
The big panels between the leading edge of the rudder and trailing edge of the fin might come off at a gate if doing hydraulic work on the rudder (replacing a PCU, etc.), but that's about it. Most of the others are for accessing the internal structure (heavy check).
Tom.
alwaysontherun
Thu Sep 23, 2010 2:57 am
Quoting tdscanuck (Reply 8):
Interesting that KLM did not patch up the paint work after a heavy check........it takes 1 man, 1 brush, and a ladder! No?
Thanks anyway!!
###"I'm always on the Run"###
SchorschNG
Sat Sep 25, 2010 11:18 am
As the engine is much cleaner than the rest, it is pretty easy to see where the engine is located. Thanks for that info.
The rear extension is maybe required to keep commonality to the usual underwing engine ... or not.
From a structural standpoint, passengers are the worst possible payload. [Michael Chun-Yung Niu]
travelavnut
Sat Sep 25, 2010 3:27 pm
These are the pieces of information that make this forum great   I learn something everyday, thanks tsugambler!
Live From Amsterdam!
wn700driver
Sun Sep 26, 2010 3:03 am
Quoting HAWK21M (Reply 5):
regds
Damned PRC Sealants!
I've done just that myself on a few occasions. Usually to inspect or R&R a leaky actuator/actuator seal for example
Quoting alwaysontherun (Reply 9):
Erm, no. Often the mfr just has the seals & screws just painted over (In fact I've never seen livery color coordinated screws now that I think of it...) So, after popping the cherry on that panel, it will be visible until the AC is painted again...
As for "brushing" the surface... Not really practical. It looks a bit smaller in a photograph, but those tails get pretty big when you're up close. Of course you always clean up after your own work, but cleaning an entire stabilizer so that everything matches would easily take more than your entire shift (or two!), if it's just one person doing it. That's a lot of metal up there!
Base not your happiness on the deeds of others, for what is given can be taken away. No Hope = No Fear
fr8mech
Sun Sep 26, 2010 4:36 am
If I understand your location, you're asking about the pre-cooler exhaust for the number 2 pnuematic system.
aerdingus
Sun Sep 26, 2010 9:56 am
The reverser actually looks really clean in this pic. I wonder if it had recently been worked on/replaced.
2016: BHX GLA KIR LCY LGW MUC VIE BA EI FR LH OS A320 A321 ATR 42 ATR 72 B738 E190 E195
Sun Sep 26, 2010 11:44 am
Quoting wn700driver (Reply 12):
True.Especially if theres a lack of time for the PRC to dry up.
regds
MEL.
alwaysontherun
Mon Sep 27, 2010 3:07 am
Quoting fr8mech (Reply 13):
I guess I did----> thank you for pointing that out. Now I know..........
Well, you never did when I was around............just so you know!!
Fair enough!
I guess I'd love your job, you need anyone with 2 left hands, perhaps?
Users browsing this forum: osanco, trent900 and 1 guest
