cvg2lga
777/767 Pax Doors
Tue Oct 19, 2010 6:37 am
Why did Boeing revert back to outward opening doors on the 777 instead of keeping doors that slide upwards like the 767s' doors do? Are all 777/767 frames designed with outward/upward opening doors?
Tchau
DA-
They don't call em' emergencies anymore. They call em' Patronies.
BMI727
RE: 777/767 Pax Doors
Tue Oct 19, 2010 6:43 am
Quoting cvg2lga (Thread starter):
I don't know for sure, but one potential reason is that on the 767, not all of the doors had power opening/closing leaving a lot of manual labor to open or close the other doors (I think that the number of doors with power was up to the airline). I don't know how it works on the 777 exactly, but I'd wager that manually opening one of those doors is a good bit easier.
http://www.youtube.com/watch?v=dijpw...B7F7280353C2CC&playnext=1&index=85
JBirdAV8r
Tue Oct 19, 2010 6:59 am
The short answer is that outward-opening doors are a lot less maintenance intensive. Fewer moving parts and easier repairs if something does go wrong...plus you eliminate having to service an alternative or quick-release mechanism for the door.
Markhkg
Tue Oct 19, 2010 7:13 am
Also, the B767 exit was somewhat notorious for inadvertent slide deployments by cabin crew. The arming lever was hard to visualize from a distance if the door was armed/disarmed amongst other difficulties noted.
PGNCS
Tue Oct 19, 2010 11:27 pm
Quoting MarkHKG (Reply 3):
That's true; it's not an intuitive design at all.
Ironically the L-1011 had a nearly bulletproof, simple, and effective system for door opening and closing in every mode, so the problem with the inadvertant deployments on the 767 are not due to any specific factor making undesired deployments intrinsically more likely with inward sliding doors, but with the horrible control configuration Boeing designed into that particular aircraft.
MattRB
Wed Oct 20, 2010 1:25 am
Quoting BMI727 (Reply 1):
It is. The door is equipped with a pull out handle, located on the door, that you rotate to open the door and then manually pull the door open. It's much easier than the 767 (imo).
Aviation is proof that, given the will, we have the capacity to achieve the impossible.
BoeEngr
Thu Oct 21, 2010 11:23 pm
Quoting JBirdAV8r (Reply 2):
Absolutely correct. I'd have to check, but it wouldn't surprise me if the 767 door and mechanism are heavier than the 777. Also, if I'm not mistaken, using a 767 style door on a 777 would cut into the overhead crew rest space.
Mender
Fri Oct 22, 2010 12:12 am
I disagree. From my experience the 767 door require very little maintenance compared to the 757 or 737. You might occasionally have to change a bearing in the handle mechanism but I can't remember the last time we had to remove the actual door from a 767, unlike the 757's which have at least two doors overhauled per C check.
Viscount724
Fri Oct 22, 2010 12:45 am
But they avoid expensive incidents like the following:
http://www.nbcdfw.com/news/local-bea...Fuselage-at-DFW-Gate-96490959.html
http://www.denverpost.com/news/ci_9929086
SQ 777 Has Door Ripped Off By Catering Truck (by Zkpilot Jan 18 2009 in Civil Aviation)
Many earlier types, both jet and prop, had inward-opening doors. Some slid upward and some slid sideways inside the fuselage. A few that come to mind: Caravelle, Trident, Britannia, L-188 Electra, Constellation. and several Russian types.
FlyingColours
Sat Oct 23, 2010 8:04 am
Yup
Quoting PGNCS (Reply 4):
Exactly, I'm not going to get out my Doors 101 guide again but the design of the door controls is beyond laughable, Yes it is good that they are all there together and easy to operate in an emergency (say the door was disarmed at the gate and something goes wrong, the other doors which are not at the gate can be instantly re-armed and opened saving precious seconds). However the flaw is that the handles can be confused, there are differences between them one being red and only moving a few inches either outboard or inboard and the other being a huge silver one... The thing is after an 11 hour flight concentration starts to wander and the wrong handle can be used (ironically it is usually more senior crew who do this because they have become complacent, rather than rookies who are petrified of doors just in case...)
It depends upon the airline as to what doors have power assisted opening, the forward left door would have it on the 762 and 763, depending upon the configuration of the 763 the second left door may have power assist too (as this would commonly be the boarding door). All of the other doors are a bit of a git to open manually but they are still better than 757 doors in my opinion, at least as far as opening and closing go.
Phil
FlyingColours
Lifes a train racing towards you, now you can either run away or grab a chair & a beer and watch it come - Phil
Viscount724
Sat Oct 23, 2010 11:54 pm
At least one business jet, the Lockheed Jetstar, also had an inward-opening door. It slid sideways inside the fuselage.
Photo © Andrew Newton
Photo © Roel Van Der Velpen - MST-Aviation
Users browsing this forum: aarbee, Baidu [Spider], CarlosSi, Egerton, qcpilotxf and 19 guests
