smartt1982
Purpose Of Spinner Cone On The Front Of Fan Jet
Tue Oct 19, 2010 9:55 pm
Hello,
Probably most obvious but can someone remind me the exact reason/reasons for the spinner cone at the centre of the fan blade on turbo fan engines?
Many Thanks
474218
RE: Purpose Of Spinner Cone On The Front Of Fan Jet
Tue Oct 19, 2010 10:37 pm
Quoting smartt1982 (Thread starter):
You have to attach the blades to something?
Tue Oct 19, 2010 10:55 pm
Aerodynamic fairing for the shaft?
SEPilot
Tue Oct 19, 2010 11:20 pm
Quoting Starlionblue (Reply 2):
I believe this is the function, much like the spinner on the hub of a prop plane. The blade attachment to the shaft takes a fairly large diameter, and to have just a flat plate would create a lot of drag. Older prop planes used to not have spinners, but they flew much slower and spinners were added to just about all of them that continued in production because it reduces drag. On a jet engine it is far more important.
lightsaber
Crew
Wed Oct 20, 2010 1:33 am
Quoting SEPilot (Reply 3):
It also helps correct the velocity profile into the core. Having no 'spinner' would result in poor air feed to the core which would impact hot/high performance,
The main purpose is aerodynamic as part of the nacelle cowling diffuser into the fan. The ideal is a plug flow velocity into the fan.
It also helps control vibration. A flat plat at the hub would be a Karman pump. It would be inherently unstable for vortex shedding.
Lightsaber
Stitch
Wed Oct 20, 2010 3:31 am
And in the off chance you are referring to the white "blob" on said cone, smartt1982, as I understand it, it is designed to scare birds and keep them out of the fan.
b78710
Wed Oct 20, 2010 9:21 am
aerodynamics, fairs the attatchment of the fan blades to the hub and allows a good no turbulent flow through into the core.
the tip on our trents is a small rubber cone. designed to oscillate and shed any ice that may build up on it.
smartt1982
Wed Oct 20, 2010 9:49 am
Quoting lightsaber (Reply 4):
lighsaber, can you just elaborate on this. I will be the first to admit my knowledge of this is is poor so would be very interested to hear how that works if you would be so kind. What is a Kaman pump and how does the spinner help or what is a plug type flow?
I have read a bit about jet engines, any suggestions on a book that would describe this also?
Quoting Stitch (Reply 5):
I have heard that before aswell, has it ever been confirmed?
26point2
Wed Oct 20, 2010 12:56 pm
I thought the "blob" as well as the "swirl" was a safety design for ramp workers. Easy to see if the fan is rotating on a noisy ramp in low visibility.
I've only ever seen this done on underwing mounted engines.
Stitch
Wed Oct 20, 2010 4:13 pm
Quoting 26point2 (Reply 8):
That makes sense, as well.
doug_or
Thu Oct 21, 2010 2:03 am
yes, makes a running engine much more distinguishable from a non-running engine.
Not sure what it would do for birds. At any thrust setting it will just be a blur. The thing that scares birds will not be the spinning little painted bit. The thing that scares birds will be the 100 ton chunk of metal moving at 150+ mph while emitting 90+ decibels.
When in doubt, one B pump off
Stealthz
Thu Oct 21, 2010 9:51 am
Quoting doug_Or (Reply 10):
Actually it isn't, many birds(if not all) have a far higher flicker fusion rate than humans so the swirly thing may just look like the scary eye of a huge predator!
Faro
Thu Oct 21, 2010 10:10 am
Great idea; why not extend it and paint the blobs on the fan blades themselves too so that the a running engine is even easier to spot for ramp agents?
Faro
The chalice not my son
bikerthai
Thu Oct 21, 2010 6:43 pm
Has the "cone" shape spinner become the preferred configuration over the paraboloid shape?
What is the +/- of each design?
bikerthai
b78710
Thu Oct 21, 2010 10:34 pm
Quoting faro (Reply 12):
i usually find the huge jet blast coming out the back, the high pitched screaming noise and the vibrations running through my chest enough to be honest!
if you have any business out on the ramp and you miss all of that you probably deserve to go through the engine
26point2
Fri Oct 22, 2010 12:17 am
Quoting b78710 (Reply 14):
You would be surprised how disorienting it can be in a very noisy environment. Then imagine it's night or windy or raining or all of that.
Remember, on a ramp there are often several operating aircraft nearby.
Try it. You will see.
b78710
Fri Oct 22, 2010 8:26 am
Quoting 26point2 (Reply 15):
I've been doing it for the last 6 years, in exactly the conditions you've mentioned.
UAL Bagsmasher
Tue Nov 02, 2010 12:04 pm
Painting the fan blades would alter the precision balancing that they require to keep fan vibration low. Since they are also changed in matched sets, you'd have pairing issues to deal with as well.
DocLightning
Wed Nov 03, 2010 12:34 am
Be that as it may, the airline also has an interest in not having your ground-up corpse destroy their multimillion dollar engine. Not to mention lawsuits and payouts from your untimely demise.
-Doc Lightning-
-Carl Sagan
spencer
Wed Nov 03, 2010 11:22 am
I may well be thinking of inlet cones, primarily on supersonic ac, but does the spinner not generate a shock wave favourable to the air entering the engine?
Spencer.
tdscanuck
Wed Nov 03, 2010 1:39 pm
Quoting spencer (Reply 19):
Not on a commercial turbofan...the air entering the inlet is subsonic, so it can't form a shockwave.
Tom.
spencer
Wed Nov 03, 2010 10:10 pm
Thanks Tom, obviously I was half way there thinking of the inlet cone.
Spence.
musang
Wed Nov 03, 2010 11:23 pm
The other reason for the precise contouring of the spinner is to deflect foreign objects past the core intake. Stones, volcanic ash, bird wreckage etc. will do much less damage through the fan/bypass duct than if they go through the core. However I don't know why some are cone shaped and some domed.
I always thought the "blob" or "teardrop" shape painted on a spinner was intended for ground staff, as they'd only ever be near it when the engine was at or near idle speed, when such a design would be visible. The spiral stripe was intended for birds, as its still visible (i.e. not a blur) even when the engine is at take-off rpm.
Quoting 474218 (Reply 1):
Close! That "something" is the hub, behind the spinner.
Regards - musang
bikerthai
Thu Nov 04, 2010 4:55 pm
Quoting musang (Reply 22):
Could it be that the cone is better at deflect object than a dome?
You would think the dome would provide a better flow profile of the air going into the compressor. But in the case of foreign object deflection you don't want that better flow?
As good an argument as any . . . .
bikerthai
lightsaber
Crew
Sun Nov 21, 2010 10:36 pm
Quoting smartt1982 (Reply 7):
Sorry for the late response...
Ok, we've already discussed that the spinner covers where the fan blades attach. Well... for optimum fan performance, it is best to have a 'reasonably high' mach number on the fan blades. There is no thrust (or more precisely pressure) generated at the hub of a fan anyway...
Now if there was no aerodynamic shape over the hub, it would be a flat circle. A spinning flat circle is a very primitive pump called a Karman pump. (Complex fluids). So the shape of the hub cover is based on:
1. aerodynamics (minimum pressure drop into the engine as that would be lost thrust)
2. Minimizing vortex shedding into the fan (noise oscillations that are both annoying to NIMBYS as well as likely to do high cycle fatigue wear on the engine).
"Plug flow" is idealized flow where everything is at the same velocity. In a jet engine 'plug flow' isn't quite the ideal... (I over-simplified.) One wants the bulk of the mass flow about 2/3rds of the radius out from the hub. But the engine has air coming in at the hub that needs to be moved outward to where the fan blades can do work on it, but not too much as the air still needs to flow into the core.
Quoting bikerthai (Reply 13):
The cone is cheaper to make. Since the inlet part of the nacelle is becoming longer, the differences in shapes matters less than many would note. The inlet of the nacelle is shaped with the spinner. Most of the cost/work is on the nacelle... So the hubs have become more of an engine makers trademark than critical. Oh, there needs to be a spinner, but the exact are not as critical as the engineers designing them think they are.
Lightsaber
Users browsing this forum: Bing [Bot] and 2 guests
