Soxfan
What Makes The "Echoey" Humming Sound?
Thu Oct 21, 2010 1:59 am
Sometimes when listening to ATC, I hear a high-pitched, echoey "humming" sound when a pilot speaks to the tower. I've heard this in the passenger cabin from time-to-time as well. It's like a middle "G" on the piano scale. Does anyone know what I'm talking about, and what causes that sound?
Pilot: "Request push, which way should we face?" JFK Ground: "You better face the front, sir, or you'll scare the pax!"
flybaurlax
RE: What Makes The "Echoey" Humming Sound?
Thu Oct 21, 2010 2:56 am
Yeah I know what you're talking about. I noticed it's always with UA transmissions, and not always with others. I can even hear it while listening to channel 9, when the crew of the plane I'm on transmits. I, however, have no idea what causes it. I've always wondered, too. Thanks for asking. I'm sure we'll get some cool responses.
Boilerup! Go Purdue!
tdscanuck
Thu Oct 21, 2010 4:45 am
Quoting Soxfan (Thread starter):
A on most pianos is 440 Hz. Aircraft AC power is 400 Hz. What you're most likely hearing is electro-magnetic interference from the aircraft power system being picked up somewhere in the VHF system.
Tom.
HAL
Thu Oct 21, 2010 5:25 am
Quoting tdscanuck (Reply 2):
Yes, that's it. Almost all current aircraft use both AC and DC for various purposes onboard. The AC is normally set at 400 Hertz, vs. the much slower 60 Hertz current we get in our homes. If there's poor insulation in the radios (or some of the wiring) you'll hear that 400 cycle hum in the radio transmissions.
HAL
One smooth landing is skill. Two in a row is luck. Three in a row and someone is lying.
DocLightning
Thu Oct 21, 2010 5:34 am
Not to digress too much OT, but why do AC use such a high oscillation in their electrical systems?
-Doc Lightning-
-Carl Sagan
Go3Team
Thu Oct 21, 2010 5:45 am
Quoting DocLightning (Reply 4):
If I remember right (from what I read here) it has to do with weight. 400 Hz Generators, Transformers weigh less.
Yay Pudding!
KELPkid
Thu Oct 21, 2010 6:22 am
Used to be a familiar sound in aviation, but you don't hear the 400 Hz hum much anymore (better avionics, noise filtration, etc.).
Quoting Go3Team (Reply 5):
flybaurlax
Fri Oct 22, 2010 5:18 am
Cool thanks for answering it. It definitely makes sense. Would the fact that I always hear it on UA equipment is because they're older? Although this wouldn't necessarily make sense for the Airbus they fly. I could be wrong though.
Mir
Fri Oct 22, 2010 5:30 am
Quoting flybaurlax (Reply 7):
FWIW, I notice it far more on 757/767 equipment than I do on Airbus equipment.
I've heard older Learjets that sound like they've got sirens going off in the background - that's kind of freaky at first.
-Mir
Soxfan
Fri Oct 22, 2010 5:03 pm
Thanks for the responses! It's not necessarily an annoying sound, in a sense almost pleasant unless it's loud or blocks out a voice/announcement.
Quoting KELPkid (Reply 6):
I'm assuming, though, that it's still present on newer aircraft because of the power systems, but just not as noticeable? I feel like I've heard it sometimes when the FA or pilot makes an in-cabin announcement, but I could be wrong...
shamrock137
Sat Oct 23, 2010 12:41 am
Quoting Mir (Reply 8):
Sometimes this can be caused by improper grounding of the strobe lights. As the capacitors charge, it can become audible in the comm system. DC-9's are also famous for having this type of sound at start up as the engines ignite.
Time to spare? Go by air!
tdscanuck
Sat Oct 23, 2010 1:11 am
Quoting Soxfan (Reply 9):
EMI shielding requirements have gone up a lot since the early days. Digital systems are also much less succeptable to this type of interference so there's a lot less systems capable of picking up the hum in an audible way in the first place.
Tom.
Users browsing this forum: Branzino, flight152, oOfredOo, VC10DC10 and 2 guests
