captain777
Whats Wrong With This AF 773?
Thu Oct 28, 2010 9:45 pm
Photo © Aurélien Tranchet
how can the paint be peeled like that first time for me to see it on an airliner.....
the sky is the limit.............actually FL410 is the limit
soon7x7
RE: Whats Wrong With This AF 773?
Fri Oct 29, 2010 12:07 am
Possibly one of three answers...topcoat applied without primer or waterborne paints were used. USAirways used waterborne paints a while back and the paint peeled even with primer. Some quick turnaround paintjobs I have seen have been applied over bare aluminum. Thirdly...the wrong primer/expired primer or poorly prepared surface before primer...resulting in primer releasing with the topcoat revealing the bare aluminum. Aerospace paints have shelf lives when manufactured and is very expensive. Typically the paints are a two part mix...the base or color and the catalyst...sometimes other additives added, hardner, flex agent, flattening agent or teflon for non rub areas. Bottom line...many reasons for this...just pick one...g
brons2
Fri Oct 29, 2010 5:12 am
Airfrance has lots of planes that do this, it's sort of a running joke on a.net.
Firings, if well done, are good for employee morale.
Viscount724
Sat Oct 30, 2010 12:24 am
That aircraft has since been repainted in their new livery.
Photo © Olivier Corneloup
Photo © Duan Zhu
Virginblue4
Sun Oct 31, 2010 2:49 pm
Quoting brons2 (Reply 2):
I thought the joke was they they dont keep their aircraft clean, not that the paint peels
Jordan
The amazing tale of flight.
trex8
Sun Oct 31, 2010 5:15 pm
Is this a wear and tear or warranty issue? Seems if paint peels to metal skin, your corrosion warranty goes out the window too!
tdscanuck
Sun Oct 31, 2010 8:11 pm
Quoting trex8 (Reply 5):
If the manufacturer did it, it would be a warranty issue. If it's paint applied by the airline, the OEM is off the hook.
Not really...tell that to American Airlines. Skin panels are usually clad anyway (thin layer of pure aluminum over the alloy) for corrosion resistance, even if it's not a polished skin.
Tom.
Users browsing this forum: edgaren and 33 guests
