Part147
747-8 'Active' Control Laws
Sat Oct 30, 2010 7:22 am
I've decided not to mess up the 747-8 Flight Tracking and Production thread by posting this new thread...
I'm intrigued by this comment ...
Quoting 747classic (Reply 8):
The outboard wing oscillation problem will be solved by new software, counteracting the impending oscillation with new control laws for the outboard ailerons. Further tests of the new software are proceeding.
As I understand it, we now have a new aircraft with an inherent flight control issue that now requires a software 'fix'.
Will Boeing actually fix the problem in the future or will they just rely on the 'fix' to give the illusion that it HAS been fixed??? Especially since the issue occurs at certain speeds with the flaps and gear extended - possibly making emergency operations/landings that bit more challenging???
In my mind, I see the 747-8's control system falling into the realm of military-type fly-by-wire systems which are necessary to maintain control of an 'inherently' - 'slightly' - unstable civil aircraft.
It's better to ask a stupid question during training, rather than make a REALLY stupid mistake later on!
747classic
RE: 747-8 'Active' Control Laws
Sat Oct 30, 2010 8:39 am
IMO this intriguing question could be better transferred to the Tech/Oper forum, but here we go :
Quoting Part147 (Thread starter):
We have an aircraft that has an oscillation issue at a certain part in the flight envelope (mid weight near cruise speed).
We don't know what Boeing is planning. Boeing can decide that the software fix is temporarily and only used to get the first aircraft certified and delivered. But It could also be the final fix.
That's not correct. This issue is only valid at a certain (cruise) speed, weight and altitude combination, with flaps up and gear up.
The other "full flap flutter issue" is solved by modification of the wing gear doors.
On earlier 747 variants the outboard ailerons are locked in the neutral position above certain air speeds (747-400) or with flaps selected up (747 classic). On the 747-8 the outboard ailerons (and spoilers) are "fly by wire" only to obtain equal low speed handling qualities as the 747-400 (common type rating). Also this system is used to give the outboard ailerons a "flap function" to augment the lift with flaps selected (shifting out of the neutral position).
Boeing now used this "fly by wire" system to a give a little bit outboard aileron deflection to eliminate the impending oscillation. on certain speed and weight combinations, calculated by the new added software. The only draw back could be a very slight increase in drag while flying in the affected part of the flight envelope.
IMO you can see it as a kind of yaw damper, available on several aircraft since the 707 and not as an 'inherently' - 'slightly' - unstable civil aircraft.
[Edited 2010-10-30 02:01:16]
Operating a twin over the ocean, you're always one engine failure from a total emergency.
AA737-823
Sat Oct 30, 2010 9:47 am
The same could be said for Mach Trim, which eliminates the effect of Mach Tuck, in many commercial airliners (737, 757, etc).
Granted, it isn't done with fancy electronics, but it's still an automated system which preserves safety in the face of the laws of physics.
And, Mach Tuck happens EVERY TIME you exceed a certain speed, whereas this 747-8 issue only happens a certain weight+speed+altitude combinations.
tdscanuck
Sun Oct 31, 2010 8:28 pm
If the problem goes away it has been fixed...you may not like the particular method Boeing used to fix it, but fixed is fixed. It's like calling a yaw damper the "illusion that it HAS been fixed" for aircraft which Dutch roll tendencies (which is basically all swept wing jets).
In addition to the above (this particular issues doesn't seem to be the landing config issue), as long as the aileron system is working you don't have a problem, and even if it quits working you have an oscillation. That has long-term fatigue implications, but isn't a reason you couldn't land the airplane (or would even really notice).
It's still stable...oscillation puts too many cycles on the structure, so you've got a fatigue issue, but it's not like the aircraft handling is changing by addition of modal suppression.
This is no more military-type control than load alleviation in the flight controls (which both Airbus and Boeing use).
Tom.
411A
Mon Nov 01, 2010 3:01 pm
Quoting tdscanuck (Reply 3):
And, which Lockheed developed and used first, on civil jet transport aircraft.
Specifically...the L1011-500 model.
Tue Nov 02, 2010 12:12 am
Part147, I think you're overestimating the seriousness of the "situation". These "fixes" are not a new thing. They've been used for decades. Yaw dampers have been around for at least fifty years (right?). As mentioned by 411A, dynamic load alleviation was used on the L1011 back in the 80s. The 340NG models use the elevators to relieve bending loads on the fuselage.
Here's the crucial point:
It's not like the aircraft will crash or be harder to control. You're alleviating fatigue.
Perhaps an imperfect comparison would be balance rods in automotive engines. Will the engine work without them? Yes, but you'll get more vibration, meaning less passenger comfort and more fatigue. But it won't be dangerous.
tdscanuck
Tue Nov 02, 2010 12:15 am
Quoting 411A (Reply 4):
I'm becoming convinced that the answer to any question of the form "When was X first used on commercial aircraft?" is either the Lockheed L1011 or Concorde.
Tom.
411A
Tue Nov 02, 2010 1:59 am
Quoting tdscanuck (Reply 6):
I'm becoming convinced that the answer to any question of the form "When was X first used on commercial aircraft?" is either the Lockheed...
Don't know anything about the Concorde, however...I was having a discussion with two now retired Boeing design engineers about a year ago, and when the subject of the Lockheed L1011 came up, their comments were the following...
"When we got a first careful look at the L1011 design, and especially the autoflight systems used therein, it was a HUGE wake-up call to those of us at Boeing at the time, because...Lockheed was waaay ahead in that department."
Lockeed developed two distinct items that were only used on their L1011 design...Direct Lift Control and...the all-flying stabilizer for pitch control.
In addition, Lockheed was the first to use hydraulic system fusing directly from the factory, not added later.
PGNCS
Sat Nov 06, 2010 3:46 am
Tom.
  That's not far off, Tom! I know nothing of Concorde, but can say that the L-1011 was the most amazing leap of technology over it's peers I ever saw, and is still my all-time favorite aircraft to fly; it still has some absolutely fantastic things otherwise unavailable. What a great machine!
Quoting 411A (Reply 7):
Boy were they right!
Max Q
Sat Nov 06, 2010 3:56 am
I have always been a big L1011 fan and rate it as one of the finest widebodies ever made.
But Lockeed did not make it simple. The all flying tail is an example, magnificant engineering to be sure and a safety bonus undoubtedly to have that exceptional pitch authority.
You don't see it incorporated on any other modern jet transports though. It's all about economics and the extra weight and complexity involved just don't pay.
I think there are limited examples of DLC out there if i'm not mistaken though. I believe this is the mod for some Aircraft operating out of LCY to allow them to fly a steeper glideslope ?
tdscanuck
Sat Nov 06, 2010 5:37 am
Quoting Max Q (Reply 9):
C-17 definitely has it...hardly commercial jet transport territory, but at least the technology lives on.
I think the LCY-type version is sort of a bastard step-child of DLC...not nearly as elegant, but the same aerodynamics at work in a cruder fashion.
Tom.
XaraB
Sun Nov 07, 2010 3:12 pm
And the occasional VC10...
An open mind is not an empty one
Users browsing this forum: Synapse and 24 guests
