ShrimpBurrito
Where To Charter Or Wet Lease RJ Aircraft?
Mon Nov 01, 2010 11:45 pm
I am studying the concept of forming a small transcontinental startup airline serving a niche market. Most likely, we would do a wet lease/charter for two ERJ140's, or maybe CRJ200's. My guess is the acquisition arrangement would be for at least 1 year of operations with an option to extend to 1-3 additional years. Each aircraft would run roughly 1000 cycles and 4000 hours per year, basically flying transcon every day with a refueling stop. We'd be flying them pretty hard.
Am I likely to find an operator for such a provision? If so, any suggestions? Most of the operators I have identified offer only larger jets, like the A319, as their smallest aircraft for long term charter/wet lease.
Dave
abnormal
RE: Where To Charter Or Wet Lease RJ Aircraft?
Tue Nov 02, 2010 1:11 am
Shouldn't you have asked this on the Commercial forum instead of the Tech Ops forum.
Fly2HMO
Tue Nov 02, 2010 1:17 am
Quoting abnormal (Reply 1):
No, it's more appropriate here, but he should've used google first.
http://www.controller.com/drilldown/...d=2A1C98953D6E4D1881FE646B54FB9FE1
http://www.aso.com/listings/AircraftListings.aspx?act_id=10&act_id=11
KevinL1011
Tue Nov 02, 2010 1:34 am
Express Jet provides ERJ-145 charter for group travel services. I've flown their charter flights twice and the service was great. Here's a link for more info.
http://charter.expressjet.com/
474218, Carl, You will be missed.
ShrimpBurrito
Tue Nov 02, 2010 4:46 am
Many thanks for the replies thus far.
Quoting Fly2HMO (Reply 2):
http://www.aso.com/listings/Aircraft...id=11
From what I can tell, both of these sites list aircraft for sale, not lease. I've called some sellers of ERJ135s, and they either don't lease or the lease is a dry lease to own, and thus, requires greater cash flow and lacks the amenities of the wet lease.
Quoting KevinL1011 (Reply 3):
Thanks for the suggestion. I'll give them a call, but it looks like they only charter ERJ145's, which I believe are considerably more costly to operate than the ERJ135's and 140's. Not necessarily a big deal for one charter flight, but when we're talking a thousand flights per year, obviously the premium is magnified.
Dave
Fly2HMO
Tue Nov 02, 2010 6:21 am
Quoting ShrimpBurrito (Reply 4):
I posted them because planes for lease are posted frequently there, so keep checking those sites.
Alias1024
Wed Nov 03, 2010 7:13 am
The ERJ145 is the same size as the CRJ200 you mentioned in your opening post. With the 135 and 140 you'd be giving up seats to get the cost savings.
JRadier
Wed Nov 03, 2010 6:39 pm
Keep in mind that if you want to wetlease (or ACMI-lease) you will need your own AOC. It might be easier to initially start off as a full charter.
For once you have tasted flight you will walk the earth with your eyes turned skywards, for there you have been and ther
ShrimpBurrito
Wed Nov 03, 2010 6:58 pm
Quoting JRadier (Reply 7):
Yes, I just learned that, and I agree. I'm going to explore that route, too. I presume the primary disadvantage of running it as a full charter is that the initial recurring costs would be higher than a wet or ACMI lease.
JRadier
Wed Nov 03, 2010 8:47 pm
Quoting ShrimpBurrito (Reply 8):
With a full charter your variable costs (the flying) will be higher, but your fixed costs (the AOC and everything that comes with it) will be lower. The question is, what equilibrium makes sense for you?
chieft
Thu Nov 04, 2010 5:36 pm
Quoting ShrimpBurrito (Thread starter):
Well, give us a chance. We can answer all your questions and realize your plan:
www.aircharter24.net
Aircraft are marginal costs with wings.
Users browsing this forum: 77west, alexrg and 1 guest
