travelavnut
Handling Characteristics @ Higher/lower Thrust
Sun Nov 07, 2010 9:10 pm
One for the Pilots!
So I was watching this random take-off video at Youtube containing a lot of turns just after take-off, presumably at climb thrust. And this got me wondering; do the handling characteristics of 2 or 4 engined airliners change with higher/low thrust settings?
I can imagine that having 1 or 2 fixed points per wing where the pulling force of the engine can increase/decrease dramaticly have some effect on the way the airplane flies? Maybe pitch moments or some force on the controls?
Live From Amsterdam!
UAL747
RE: Handling Characteristics @ Higher/lower Thrust
Sun Nov 07, 2010 9:48 pm
I'm not a pilot, but I think there is a pitch forward and back movement with thrust changes. But I think that's during the change only, as the energy changes. When you stabelize the thrust, it should have no bearing. (At least that's what I would assume).
Of course we all know that speed is the major factor in handling characteristics, and at higher speeds, the controls will be more "tight" so to speak.
I think manufacturers probably try to eliminate any type of handling issues that would arise from changes in thrust.
Mir
Sun Nov 07, 2010 10:43 pm
Quoting UAL747 (Reply 1):
There is, depending on the location of the engines. And it's a pitch up or pitch down moment, not forward or back.
It's always there, actually. The only way to get rid of it is to trim off the additional control pressure, which is easy enough. But when you change power settings, you may need to re-trim if the change was significant enough.
-Mir
Pihero
Sun Nov 07, 2010 11:46 pm
Quoting TravelAVNut (Thread starter):
By design, the engine thrust lines are below the airplane CoG. Starting from a stabilised state,this means that an increased thrust will cause a pitch-up moment. and a decreased thrust a nose-down effect.
That is until you fly an FBW 'Bus in which the flight control systems keeps the aircraft in treim at all times.
Contrail designer
DiamondFlyer
Sun Nov 07, 2010 11:57 pm
Quoting Pihero (Reply 3):
On some airplanes. Its not like there aren't airplanes out there that have the thrust line above the CG, which reverses the things you said about pitch changes caused by throttle adjustments.
-DiamondFlyer
From my cold, dead hands
Pihero
Mon Nov 08, 2010 12:19 am
Quoting DiamondFlyer (Reply 4):
Never heard of any airliner builkt that way. Could you provide some examples ?
Contrail designer
DiamondFlyer
Mon Nov 08, 2010 12:56 am
Quoting Pihero (Reply 5):
Wow, so I figured this was obvious, but I'll go ahead and point them out. Any of the Dash 8 series, or the ATR 42/72. Surely you've heard of them.
-DiamondFlyer
Mir
Mon Nov 08, 2010 3:35 am
CRJs. Many business jets.
-Mir
pilotpip
Mon Nov 08, 2010 4:20 am
Handling is effected much more by airspeed than power changes. While it's true that thrust will effect depending on where the engines are placed on the aircraft some FBW aircraft have thrust compensation built into the software. The ERJ-170 has thrust compensation.
DMI
UAL747
Mon Nov 08, 2010 6:36 am
Wouldn't the L-1011, DC-10, and MD-11, MD-80, 717, or anything with tail mounted engines also have a pitch down moment when thrust is applied?
UAL
Mir
Mon Nov 08, 2010 6:47 am
Quoting UAL747 (Reply 9):
In the case of the L1011, DC-10 and MD-11, the two wing-mounted engines provide a counter to the tail engine, so you'd probably still get a nose-up pitch moment with increased thrust in normal operation. If you manipulated the thrust of the tail engine only, however, then you would see the nose-down moment with an increase in thrust.
-Mir
Pihero
Mon Nov 08, 2010 12:21 pm
Quoting DiamondFlyer (Reply 6):
Don't know about the -8 but I do the ATRs : Funny enough, push the throttle and you have a pitch-up movement, mainly due, in this case to the augmented lift caused by the accelerated airflow. I would be very surprised to hear the -8 behaving differently.
Wouldn't the L-1011, DC-10....,
I have some 4,000 hours on the 10-11 and she behaves as I said. The -10, I only know through the simulator. Nothing out of the ordinary here.
...MD-80, 717, or anything with tail mounted engines also have a pitch down moment when thrust is applied?
Tested the MD-80 for a previous airline...Here again, nothing unexpected.
Let's face it, an airliner has to demonstrate *stability* in all axes. I therefore expect that airplane to show - on a short term reaction- a pitching moment to tend to keep the acftual airspeed steady.
Otherwise, the Sioux City DC-10 and the Baghdad A310 wouldn't have been so easy (!!!) to pilot with engines' thrust only.
Contrail designer
travelavnut
Mon Nov 08, 2010 1:30 pm
Thanks everyone for all the replies!!
NW747-400
Mon Nov 08, 2010 2:37 pm
All CRJ models will pitch down when a thrust increase is commanded, and pitch up when the thrust is decreased. Seems like most airplanes with only tail mounted engines would behave in this manner? Anyone have any experience with the DC9/MD80 series? I'm curious to know about that.
To the OP, as long as all engines are operating normally and with equal thrust settings, there is no affect on the aircraft's turning forces. Should an engine fail, the aircraft will yaw about the vertical axis in the direction of the inoperative engine, which will in turn cause the aircraft to bank in said direction should no corrective rudder inputs be made.
tdscanuck
Tue Nov 09, 2010 1:27 am
Not limited to Airbus...anybody who uses a C*-esque pitch control law gets this benefit (F-16, A320 and onwards, 777, etc.). Good overview here: https://dspace.lib.cranfield.ac.uk/bitstream/1826/186/2/coareport9303.pdf
Quoting NW747-400 (Reply 13):
Several FBW aircraft don't do this, or only do it because it's programmed in to provide pilot annunciation of an engine failure. Good yaw control laws will reject the disturbance of an engine failure.
Tom.
Pihero
Wed Nov 10, 2010 11:40 am
Thanks for the link, Tom.
I'd wanted such a document for a very long time without spending 80 quid on a tech book.
Contrail designer
tdscanuck
Thu Nov 11, 2010 4:18 am
Quoting Pihero (Reply 15):
I was very surprised to find that one online without a fee...not sure why I haven't stumbled across it in the past when doing similar searches, but I'm thankful that it's there!
Tom.
Users browsing this forum: Yahoo [Bot] and 1 guest
