tomenalle
Jt8d-11 Specification
Wed Dec 29, 2010 1:26 pm
Hi,
I am looking for some detailed information regarding the jt8d-11 engine.
The information I am interested in is this:
Maximum allowable thrust (lb)
Max efficient inlet mach (mach)
Compressor area (square feet)
Minimum n1 (for fuel intro)
Fan RPM at 100% n1
Engine start fuel intro time (sec)
Throttle advance time from idle to maximum (sec)
Thrust-reverser deployment time
Number of transmissions
Low altitude for jet engines (ft)
Low altitude half thrust sfc
Low altitude max thrust sfc
Hi altitude for jet engines (ft)
Hi altitude half thrust sfc
Hi altitude max thrust sfc
Idle fuel flow (ratio to max)
I hope someone have a pdf or something.
Alexander Andersson
tdscanuck
RE: Jt8d-11 Specification
Wed Dec 29, 2010 9:08 pm
Some of this information can be found on the TCDS:
http://rgl.faa.gov/Regulatory_and_Gu...f72862573460049d2e0/$FILE/E2EA.pdf
Sea level static:
Max continuous: 12,600 lbs
Max takeoff: 15,000 lbs
Fan RPM at 100%N1: 8600
A lot of the operability stuff you're asking for should come from the engine shop manual, but I'm not aware of that posted publicly anywhere.
Quoting tomenalle (Thread starter):
These two are airplane properties, not engine properties, so you won't find them attached to any JT8D-11 documentation.
Tom.
wingscrubber
Wed Dec 29, 2010 9:19 pm
Resident TechOps Troll
Viscount724
Thu Dec 30, 2010 3:24 am
The 2nd link in this site may also help.
http://www.jet-engine.net/
tomenalle
Thu Dec 30, 2010 6:05 pm
Thank you all, I think I have more than enough of information.
Users browsing this forum: StereoTechque and 1 guest
