Aaron747
PW407x/409x Sound Differences
Wed Dec 29, 2010 7:10 pm
This absolutely drives me nuts - what accounts for the difference in sound between these two 777 powerplants? I'm increasingly becoming more and more obsessed with the incredible noise these things make.
PW407X
http://www.youtube.com/watch?v=cXStqK4vDaE
PW4090
http://www.youtube.com/watch?v=Jro_fncM1o8
An additional curiosity...
http://www.youtube.com/watch?v=P5wl3PjoMXs
What accounts for the ‘burble’ heard 1:04 - 1:08 when the throttles are initially moved forward?
rjsampson
RE: PW407x/409x Sound Differences
Thu Dec 30, 2010 8:26 pm
I don't think the engines sound different in reality.
If I had to take a stab at explaining why they sound so different in the two videos, I'd say it has to do with the distance and angle from which the video is being shot when the engines spool up.
As you know, the sound of an engine varies dramatically relative to the position from which it's being heard. In the second video, the videographer appears much further away and, as the aircraft comes accelerates closer, it seems like it sounds very similar to the first video when the aircraft is in the same position.
"..your eyes will be forever turned skyward, for there.." yeah we know the DaVinci quote. But GA is so dang expensive these days! :(
Aaron747
Thu Dec 30, 2010 9:20 pm
Quoting RJSampson (Reply 1):
I have to disagree, as I've sat in seats in the same position on both 777-200 and 777-200ER powered by PW4077 and PW4090 respectively, and there are differences in the sounds they generate in the first half of the spoolup phase. From there on at higher power setting they are relatively similar.
MarkC
Fri Dec 31, 2010 3:55 am
The majority of the parts in a 77k engine are comparable and interchangeable with the 90k engine. However, there is a big difference in the fan case design. The older engines had composite fan exit guide vanes, and the 90k's had aluminium ones. The sound liners were also different.
I can see how this could produce a different sound.
Aaron747
Fri Dec 31, 2010 6:42 pm
Quoting MarkC (Reply 3):
It certainly stands to reason that different materials in the same location could account for the differences I hear. Thanks for the information
Users browsing this forum: Flow2706, Scinfaxi and 1 guest
