airbusb0y
M11 Empennage Questions
Sun Jan 02, 2011 7:43 pm
Hello a few questions about the MD11,
1. Where is the yaw damper on the MD11 exactly located?
2. What and how does the dual rudder work?
3. Does the MD11 have trim tabs on the rudder?
Does any one have a detailed empennage drawing of the MD11. I've checked Boeing's technical section, but it was just general schematics. If any one could kindly send me a picture if they have access to it.
Any info appreciated!
CosmicCruiser
RE: M11 Empennage Questions
Mon Jan 03, 2011 5:46 pm
1. ask a mechanic
2. The upper rudder is powered by hyd sys 1 and the lower rudder hyd sys 2. each rudder consists of a forward and aft section. The aft section of the upper & lower rudders are bused to move as the forward sections.
3. yes the rudder has trim
wingscrubber
Wed Jan 05, 2011 3:57 am
Clarification on trim - there are no trim TABS on the MD-11, they would be useless on a hydraulically powered rudder, the trim is probably mechanical-electric input and likely works either with bias on the rudder PCU control cables or a separate screwjack input directly at the rudder at a guess. Maybe an MD-11 mech will come enlighten us shortly.
Here's an old thread on yaw dampers:
Yaw Damper... What Exactly Is It? (by GulfstreamGuy Mar 7 2004 in Tech Ops)
Here's an explanation of the 727 yaw damper:
http://www.boeing-727.com/Data/systems/infoyawdampers.html
Commercially available yaw damper, though probably not the same used on MD-11:
http://vonesh.com/pdf_files/YawDamp.pdf
Hooks up to the rudder trim to prevent dutch roll as far as I can tell...
Resident TechOps Troll
fr8mech
Wed Jan 05, 2011 5:23 am
Quoting airbusb0y (Thread starter):
The MD11 does not have any dedicated yaw damp components as found in other aircraft. The yaw damp system resides, basically, in the FCC's.
Not sure what you're asking. The rudder is split into an upper and lower rudder. Several aircraft have this design. It provides for redundancy in the case of a single, or in some cases, a dual hydraulic failure. I'm sure there are some aerodynamic considerations, but they are beyond my level of caring.
No, rudder trim is achieved by changing the neutral on the rudder load and feel mechanism via an electric actuator.
CosmicCruiser
Wed Jan 05, 2011 2:47 pm
Quoting fr8mech (Reply 3):
I KNEW THAT!!    Just doing some studyng and went over FCC stuff but it is a little complex.
I also must apologize at my quick abbreviated answers about the trim. I just wrote yes meaning yes we have a rudder trim knob. sorry
Users browsing this forum: heavymetal, kcrwflyer and 2 guests
