a380900
Is The A380-900 A "push-button" Project
Fri Jan 07, 2011 9:07 pm
How much of the A380-900 is designed already? Is there anything left to do?
We know the factories have been built with the longer stretch in mind (people in the know should by the way know the longest possible stretch that has been envisioned for the A380 as the factories are the limitating factor). Some say the wing is meant for a bigger plane. Just how much R&D effort is necessary to start building the A380-900? The same as any other stretch or relatively less?
Stitch
RE: Is The A380-900 A "push-button" Project
Fri Jan 07, 2011 11:21 pm
Realistically all they need to do is engineer the fuselage stretch. Assuming they keep the MTOW around 600 tons, there is no additional changes to any systems that need to be made since they can leverage the systems from the 590t MTOW freighter variant.
Klaus
Sat Jan 08, 2011 2:55 am
The engines would need to be pushed that much further to make the bigger version economical. That is probably the bigger issue, particularly right now with at least RR heavily preoccupied with its current models already.
Stitch
Sat Jan 08, 2011 3:53 am
Well the engines were designed with the 590t MTOW A380-800F in mind, so I imagine they can scale.
Though many believe the A380-900 will come exclusively with Trent XWB power.
Klaus
Sat Jan 08, 2011 4:10 am
Quoting Stitch (Reply 3):
The -800F would have traded a substantial portion of its range for some additional payload, which would not have been much of a problem for cargo, but certainly for a passenger version.
For a -900 passenger version there would need to be substantially more powerful engine variants to make it economically feasible (much higher weight at the same or comparable range).
Stitch
Sat Jan 08, 2011 5:59 am
Quoting Klaus (Reply 4):
I would expect a 590-600t MTOW A380-900 with Trent 900 or GP7000 engines should be able to perform most of the missions an A380-800 can today. Airbus will have worked out some of the MEW by then and both engine OEMs will have improvements to their powerplants to lower SFC.
747400sp
Sat Jan 08, 2011 6:24 am
RR design Trent 984 for the A380 900, so it can use the same systems as the A380 800. The A380 900 is going to be a true giant. With a length of at least 261 ft and a take of weight of 1300000+ lb, the only jet that would be larger than it, would be the AN 250. I hope it will be built, and I hope to fly on one on my honeymoon.
Klaus
Sat Jan 08, 2011 7:45 am
Quoting Stitch (Reply 5):
Yes, but quite a few hub-to-hub connections would still remain out of reach, and when considering a huge investment like that this would give many airlines headaches, not just Qantas...!
From a purely aesthetic point of view I really hope they'll build the "real" version sooner rather than later – the -800 really looks a bit like an A318 after a massive steroid overdose...
astuteman
Sat Jan 08, 2011 6:18 pm
The Trent 900 and GP7000 were designed to power the 590 tonne/599 tonne A380F
Quoting Klaus (Reply 7):
An A380-900 with 30 tonnes MTOW on top of the current A380-800 would have roughly the same range capability, As Stitch pointed out
Quoting A380900 (Thread starter):
Tim Clark of EK once said an A389 would cost between $2Bn and $5Bn to engineer depending upon "what it was"- not that I'd take his numbers as gospel. But I'd guess the lower number would relate to the bog-standard +6m and +30 tonne A389, whilst the larger one would relate to one of his (and Steve U-H's) more exotic ambitions (like + 12m+ stretch   )
I suspect "scope creep" would be the biggest variable in R+D costs...
Klaus
Sat Jan 08, 2011 8:04 pm
Quoting astuteman (Reply 8):
As I said: With substantially improved engines. They are the crucial resource in this.
With the current ratings the -800F would have had substantially reduced range (several thousands of miles).
When looking at RR's issues getting the present engine ratings to function reliably, this may not be a piece of cake. Of course they will make it, but I doubt it's something that can be rushed.
Of course airports will have to make some additional accomodations for the even longer version, but it's not as if the -900 variant had been a real secret; They would have been stupid expanding exclusively for the -800 without at least planning ahead to the -900 where feasible.
[Edited 2011-01-08 12:22:54]
Stitch
Sun Jan 09, 2011 4:59 am
Quoting Klaus (Reply 9):
True. but the A380-800F's maximum structural payload was over 50% higher (150t vs 90t) than the A380-800. It also had a higher MZFW so the plane, even with the 30 tons of extra MTOW, could still end up fuel weight limited. But this is okay, because freighter missions in general are based around shorter stage-lengths.
An A380-900 would have a maximum structural payload perhaps 10t more than an A380-800, leaving 20t of TOW left to both absorb the extra MEW and to tank additional fuel (assuming the A380-900 would have a center fuel tank).
astuteman
Sun Jan 09, 2011 8:39 am
No!
Not with substantially improved engines.
The Trent 900 and GP7000 were designed from the outset to power A380's up to 599 tonnes.
The "standard" A380-900 stretch - i.e. +6m to 79 m long, and 590 tonnes, would have pretty much the same range capability as the current A380-800 at 560 tonnes, butwith a c 14% greater passsenger capacity/payload
(and about a 5% increase in drag)
The A380F?
Maybe.
This thread is about an A380-900 - presumably a passenger aircraft.
And in its basic form, it wouldn't need "substantially improved" engines
Sure, if you want your aircraft to carry the 150t of the A380F, plus 15% (what, 172t?) for 6700Nm , which is the MZFW range of the A380-800, you would need SERIOUSLY improved engines.
That's some aircraft
But not the A380-900
As it is, the A380-900 as I've defined it above, would suffer about a 1 000Nm range reduction over the A380-800 at an MTOW of 560 tonnes.
A "nominal" range of say 7 200Nm with about 575 pax
Klaus
Sun Jan 09, 2011 11:55 am
Quoting astuteman (Reply 11):
The present versions of these engines are not available with their maximum designed specifications.
astuteman
Sun Jan 09, 2011 12:15 pm
Quoting Klaus (Reply 12):
Aren't they?
What hardware changes do you think are necessary to the T900 and GP7000 in order to provide engines for a 599 tonne A380?
Aside from the obvious one of RR fixing the design glitch on the T900 IPT lubrication, that is (which they've already done, I would guess)
Klaus
Sun Jan 09, 2011 1:03 pm
Quoting astuteman (Reply 13):
Aren't they?
No, they aren't, as far as I'm aware.
Take Qantas: They are using the highest currently available rating and just make their transpacific runs with that. Obviously an A380-900 with these same engines (assuming they worked reliably and economically) would not be an option.
As far as I'm aware RR (and probably EA as well) have not maxed out the planned thrust headroom for their A380 engines yet.
In view of fuel capacity and trip fuel consumption per available seat further efficiency gains would also be welcome to make the -900 really attractive.
If it had a substantially lower range or didn't improve margins over the -800, what would be the point? Slot-constrained operations could still benefit, but would that alone justify the added variant?
I don't pretend to intimately know the calculations done by the airline acquisition departments, but I doubt that a -900 with effectively reduced payload capacity and range would have that much of an appeal, particularly in view of further rising fuel prices.
The engines have been designed with some additional thrust headroom, I would expect that realizing at least some of that headroom while further optimizing their efficiency in due time would be the sensible path to take, particularly in the current economical environment.
But of course any of that is idle speculation anyway.
astuteman
Sun Jan 09, 2011 2:13 pm
Quoting Klaus (Reply 14):
But they are
That didn't answer my question.
As it happens there is NO hardware change required to either the Trent 900 or the GP7000 to allow it to power a 599 tonne A380. None.
Some links below....
http://www.rolls-royce.com/civil/products/largeaircraft/trent_900/
The Trent 900 is certified at 70k, 72k, 76k and 80k pounds of thrust. It is the only engine certified at both 70k and 72k on the Airbus A380. The higher two ratings demonstrate the growth capability embeded in the engine should further aircraft development require
http://en.wikipedia.org/wiki/Rolls-Royce_Trent_900
Variants
Trent 970 with 70,000 lbf (310 kN) of thrust. In use by A380-841 of Lufthansa.[citation needed]
Trent 972 with 72,000 lbf (320 kN) of thrust. Higher thrust variant of the 970, in use by A380-842 of Qantas and Singapore Airlines.[citation needed]
Trent 977 with 77,000 lbf (340 kN) of thrust. Variant for A380-843F.
Trent 980 with 80,000 lbf (360 kN) of thrust. Higher thrust variant for A380-843F.
http://www.geae.com/engines/commercial/gp7000/index.html
[quote]The GP7200 will initially certify at 76,500 lb. (340 kN) of thrust and subsequently at 81,500 lb. (363 kN) of thrust. The engine will be offered with two ratings appropriate for the various A380 configurations and take-off weights: GP7270 for the 560 tonne variant, and GP7277 for the 590 tonne A380-800 freighter.
http://en.wikipedia.org/wiki/Engine_Alliance_GP7000
The GP7200 is rated at 81,500 lbf (363,000 N) of thrust. The engine is offered with two ratings appropriate for the various A380 configurations and take-off weights: GP7270 for the 560 tonne variant, and GP7277 for the 590 tonne A380-800 freighter.
The parts I've bolded clearly show both engines were explicitly designed with the heavier 590 tonne A380F in mind.
In fact, when the A380-800's MTOW went up from 560t to 569t, the engine capability to grow up to 599t (instead of 590t) was also incorporated.
I think the key point is for me to reiterate that a 6m stretch A380-900 that is 30 tonnes heavier than the equivalent A380-800 will have at least the same nominal range as that equivalent A380-800.
In other words the weight of the A380F gives an A380-900 the same range capability as the A380-800.
So in fact the engines to power this variant unquestionably exist. Today.
The up-rating is just a software exercise
It is in fact, fact  .
And in both cases even further growth has been built in.
The 84 000lb thrust that both engines are capable of is good for about 625 tonnes MTOW on the wing of an A380
EPA001
Sun Jan 09, 2011 2:39 pm
Quoting astuteman (Reply 15):
No doubt you are correct. But if Airbus "push the button" and go ahead with the A380-900, would they upgrade the engines with technologies coming of from newer engines (B787-A350) or will they go for installing these newer engines from the B787/A350 under the mighty wings of that A380-900. In any case it would be some plane to see and what a CASM advantage that plane could have. I can not wait to see it and fly on it.    Even though there might be a (small?) chance it will be not be launched at all and even though that if it is launched it will not be in the air with customers before 2018 (my expectation  ).
trex8
Sun Jan 09, 2011 2:55 pm
OT but IF Airbus relaunched the A380-800F what timeframe do folks think it will be to EIS. IIRC a fair amount of work was already done on it before it was canceled 4 years ago.
Klaus
Sun Jan 09, 2011 2:57 pm
And the 72k rating is the maximum actually available yet. And RR has trouble making even that one perform reliably at this point.
Which is my whole point: Although planned, the necessary engine variants are not available now.
So no "push-button" project but some serious development still to be done there.
Same wing, same fuel capacity, same engines, but 30 tons more weight: No chance in hell can that variant have the same range in real life. Just not possible.
There just is no free lunch.
EPA001
Sun Jan 09, 2011 3:27 pm
Quoting Klaus (Reply 18):
I thought that the A380-900 was supposed to have extra fuel capacity through a center fuel tank which is part of the 30 tons weight increase.  .
garynor
Sun Jan 09, 2011 3:36 pm
Isn't that rather the maximum actually in use at the moment? Like Astuteman said: up-rating is just a software excercise, all the hardware is in place (as per certification documents).
Same wing, higher fuel capacity, more powerful engines and 30 tons more weight = same range.
Stitch
Sun Jan 09, 2011 5:50 pm
The engines were designed from the start to scale to those thrusts. Note that no A380-800 weight variant needs anything like those thrust ratings so, if anything, current engines are running "de-tuned".
This is most definitely not a GE90-9xb to GE90-11xb situation where the entire guts of the engine needs to be torn out and replaced to make the higher thrusts. Instead, it's a GE90-7xB to GE90-9xB situation where some components have higher strengths to support the heavier loads.
We're talking 30 tons more Take-Off Weight here, not 30 tons more Empty Weight. Actual Empty Weight increase will probably be in the neighborhood of 10 tons. That leaves 10 tons for payload weight increase and 10 tons for fuel weight increase.
Quoting EPA001 (Reply 19):
It's expected that it will offer the 56,000 liter capacity center tank developed as an optional install on the A380-800F.
astuteman
Sun Jan 09, 2011 6:05 pm
Er, excuse me, the T900 has one specific problem which is in the process of being resolved. Apart from that specific issue, as far as I'm aware the T900 is performing extremely well in service.
That is clearly not the same as having to develop the engine in order to meet a higher thrust requirement   .
There is of course also another engine option for the A380 - an engine equally capable of being upgraded by software, that is also performing excellenty, with the luxury of also not having one high profile event counting against it in the publicity stakes.
And for what its worth, a closer look at the links I posted will show that 80k + variants have bee certified
The necessary engine variants ARE available
Unless the same engines are programmed for the higher thrust they are already capable of
Quoting garynor (Reply 20):
Correct.
Not sure why we're having this debate, to be honest.
Quoting EPA001 (Reply 16):
We can always hope of course. I can't see any major physical constraints - some contractual ones maybe.
But a goodly proportion of A-netters tend to underestimate the T900 and GP7000 for no better reason than they are installed on the "dinosaur" A380.
Have a look at the Geae link I posted earlier to see the pedigree of the GP7000
(I know you already know, my friend)
I wonder if the c. 5% better SFC of the TXWB is worth the engineering trip at this point?
Re your comment about fuel capacity - it's not really an issue for a 6m stretch IMO.
The 569t A380-800 is fuel limited at about 8 800Nm.
With a c. 5% higher fuel burn a 6m stretch 599t A380-900 would be fuel limited at 8 400Nm, but at a considerably higher payload (about 105k lb instead of 80k lb)
Any SFC gains in the meantime would only add to this of course
EPA001
Sun Jan 09, 2011 11:44 pm
Quoting astuteman (Reply 22):
Part of the answer to this question is in my opinion the development of the average price of oil. Now that the world economy seems to be recovering pretty well, the oil prices are up again to almost record values. At the gas station we are almost paying as much for per liter (or per gallon) as in 2008, just before the GFC hit us.
So the 5% difference in SFC will more or less remain these 5%, but it could vary a bit when further improvements are introduced (which could happen on all engine types, and the margin could be increased as well as decreased as a result of that). But the value of that 5% over the life of the airframe could vary quite a bit due to the price of oil. That fact still does not answer your question, but to be honest, I do not have the one and only correct answer here. . Time will tell in which direction the developments will go and which decisions will be made by Airbus and her engine suppliers if the A380-900 sees the light of day. I am convinced we will see it one day .
Klaus
Mon Jan 10, 2011 1:16 am
Quoting Stitch (Reply 21):
Sure, but at this point the 70k version appears to be the only one that's reliably operational, at least at RR. So some of the work to still be done is under way as we speak.
Okay. But the question remains whether the advantage the -900 really provides under these circumstances is attractive enough for Airbus and their customers to launch the new model or if there's still some work to do to advance it somewhat further.
Stitch
Mon Jan 10, 2011 2:46 am
Quoting Klaus (Reply 24):
Again, it's one part on the Trent 900 that is causing the problem and Rolls has already addressed it with the Mod C engine that is being installed on QF's birds at XFW as well as being shipped to SYD for installation on the existing birds that service LAX (which is the only route where QF needs maximum TOGA thrust).
prebennorholm
Mon Jan 10, 2011 3:25 am
Two months ago a QF A388 suffered a serious mechanical issue on a T900. If that issue isn't corrected years before any A389 can take to the air, then we can consider the whole T900 program is dead.
But three airlines, which are operating the T900, have not changed their mind, and are looking forward to more T900 equipped planes. Six more airlines have T900 equipped A388s on order, and haven't changed engine selection. That indicates confidense in the T900 - that RR will have the issue corrected. What more confidense can we expect?
The present day T900 issue isn't just derating, but also very frequent inspections. That's a temporary precautionary measure until RR has proved to the certifying authorities that they have solved the problem and the originally certified performance data can be reactivated. 70, 72, 76 and 80k versions.
We don't even know if the T972 has been derated to 70k, or something lower. We only know that QF needs 72k for their LAX routes, and that they don't have those 72k today.
And then we know that QF told us that their "derated" A388 can do the LAX routes with 80 pax only (instead of 470). That indicates a roughly 8% reduction of TOW, while a derate from 72 to 70k is less than 3%. Those numbers don't fit. They fit a lot better if the T900 is presently derated to something like 65k. If that is the case, then it would be an (almost) non-issue for all A388-T900 operators with their present routes (except of course QF and their LAX routes). And if LH and SQ are "suffering" such a derate from 70 to 65k these days, then it would be hard to make them brag about that instead of staying quiet. We don't know. We only know that LH and SQ didn't cancel any A388 routes.
But the main issue, if RR cannot fix their T900 issue in months rather than years - both the derating and the extra frequent MX - then they had better close the T900 shop today rather than tomorrow. There is no way the present day T900 situation can go on for years with the RR T900 customer base intact.
And since the customer base is indeed intact, then we can conclude that the engines for a 599t A380 are there years before any A389 or A388F can be built.
Klaus
Mon Jan 10, 2011 3:57 am
Quoting prebennorholm (Reply 26):
I would say there are a few too many indirections in that conclusion chain to really build anything solid on...
rheinwaldner
Mon Jan 10, 2011 7:25 am
Yes, for Airbus to design the A389. But RR fixing their engine will only cost a fraction of that. Even if the A389 indead almost could be considered as "push-button" project. The relation between an engine fix and a "push-button" aircraft project is still gigantic.
At this point there is also no A389. Not even a unreliable one.
And I bet long before Airbus just mentions the A389 the next time in public RR will have fixed their engine. And the time Airbus finally will need to design the "push-button" A389 would still be long enough for RR to merge the T900 into any desired and realisticly needed thrust category.
Making a 90k or even 100k engine of the T900 would take less time than designing the A389. If I see how long Airbus needs for the A320NEO. In that time new Trent engine versions are designed from scratch, aren't they?
Klaus
Mon Jan 10, 2011 5:07 pm
Quoting rheinwaldner (Reply 28):
If everything went halfway smoothly on the engine front, at least...
speedygonzales
Mon Jan 10, 2011 10:06 pm
I a bit confused about the fuel volumes. From Airbus' doc:
Passenger: 323 546 l
Freighter: 310 000 l standard, 355 850 l option
The standard on the freighter it 'too round', so it may be an artificial limitation. But 32 m^3 seems way too small, since the A330 has 41,5 m^3 (delta between -200 and -300).
Ignorance kills. :tombstone:
WingedMigrator
Tue Jan 11, 2011 5:25 am
Data from the A388 pilot briefing:
Outer tanks (each) 10520 l
Feed tanks 1 & 4 (each) 27960 l
Mid tanks (each) 36460 l
Inner tanks (each) 46140 l
Feed tanks 2 & 3 (each) 29340 l
Trim tank (in the horizontal stabilizer) 23700 l
TOTAL: 324540 l
I think Stitch was off by 10,000 l... the center wingbox tank (not installed on the A388) is ~46,000 l
That would put the A389 at ~370000 l
astuteman
Tue Jan 11, 2011 5:35 am
[quote=Klaus,reply=18]And the 72k rating is the maximum actually available yet. And RR has trouble making even that one perform reliably at this point.
http://www.flightglobal.com/articles...ghts-to-los-angeles-on-16-jan.html
Looks like the fix is delivered, as of this week
Klaus
Tue Jan 11, 2011 9:26 am
Quoting astuteman (Reply 32):
Excellent! I hope that's the end of that!
Tue Jan 11, 2011 9:36 am
Quoting WingedMigrator (Reply 31):
TOTAL: 324540 l
Maximum fuel volume is not really the most valid metric for range in the real world since if you fill to the brim you are severely payload limited.
Stitch
Tue Jan 11, 2011 3:21 pm
That I was. Forgot the A380's base capacity is 310kL, not 300.
EPA001
Tue Jan 11, 2011 9:40 pm
Quoting Stitch (Reply 35):
Well, nobody will hold this against you. The very high average level of quality in your posts made and makes sure of that.  .
Anyway, it still does not make the A380-900 a "push-button" project. If it is launched, and I am personally convinced that it will be launched in this decade, Airbus will squeeze out as much performance as they can. So the latest in weight savings, aerodynamic tweaks, systems update and engine updates will most likely be installed. Which will require development wok and no doubt also some new certification procedures. But the prospect of this bird is so much promising.  .
CHRISBA777ER
Thu Jan 13, 2011 1:22 pm
I see the A389 as the natural progression for the project - its a gimme.
I think Airbus has a choice - go for it now, once they've cleared up the production issues, or wait until 2018-ish by which time the market for it will have grown and the first A388s will be about 10 years old.
If they go for it now there is a chance that existing A388 orders will be converted. It will be a massive success regardless.
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
Charlienoble
Thu Jan 13, 2011 5:16 pm
Quoting Starlionblue (Reply 34):
Exactly. Weight is King.
Quoting CHRISBA777ER (Reply 37):
Given the lack of competition in its class, I'd say that there's not much risk in waiting (as compared to Boeing waiting so long to stretch the 757).
That is until Boeing comes out with the 7107, which to take advantage of sunk development costs will probably be a 748i with a 787 mounted on top of it...
"When I get sad, I stop being sad and be awesome instead. True Story."- Barney Stinson
Flighty
Fri Jan 14, 2011 8:02 am
I feel that the A380 will benefit from not only a stretch, but a cost-cutting production redesign. The A380 will someday be old, and a ripe candidate for modernization.
Aircraft manufacturers (and car manufacturers) do well when they have a chance to really sweat the details. The A380 and 787 will take years to become really mature products.
Quoting CharlieNoble (Reply 38):
6 engines? Cool.
Users browsing this forum: AT72, n757kw, ro1960 and 3 guests
