a380900
Hi Bypass Engine - What's The Limit In Diameter?
Sun Jan 09, 2011 5:41 pm
It looks like when it comes to hi bypass engine, the larger the diameter, the better. Yet some airplanes do not seem to use the full diameter that would be possible once the ground clearance is taken into account. (A380, A330 do not max out diameter as much as the 737 for instance). Also, the 777 has engines of different diameter depending on their power. Why not use the larger fan size for all powers if bigger is always better?
I understand also that the tip of the blades cannot go faster than the speed of sound (or can they?). Is there an absolute limit of the hi-bypass engine diameter or could we see larger diameters than the GE115 or the Trent 900?
Revelation
RE: Hi Bypass Engine - What's The Limit In Diameter?
Sun Jan 09, 2011 8:30 pm
Quoting A380900 (Thread starter):
Bigger is not always better.
Some factors that come to mind:
Bigger diameter means larger and thus heavier case, heaver fan blades, more frontal drag, and their knock-on effects.
Bigger diameter means more fan blade flex, so tip clearance has to be increased, decreasing efficiency.
Inspiration, move me brightly! Light the song with sense and color.
Hold away despair, more than this I will not ask.
Faced with mysteries dark and vast, statements just seem vain at last.
Some rise, some fall, some climb, to get to Terrapin!
nomadd22
Sun Jan 09, 2011 8:36 pm
Mostly because the engines weren't available when they bought the plane. Adding a new engine type to an airliner is a huge undertaking.
And bigger is not always better. The bigger the fan is the slower it spins. And the fan speed is tied to the core speed, which generally is more efficient the faster it goes. Pratt is working on geared fans that can go slower and be bigger without compromising core efficiency, but they don't have any big ones on the market yet.
Also, bigger fans mean more weight and drag. There are a lot of considerations besides fan efficiency to consider.
Anon
Sun Jan 09, 2011 11:43 pm
Quoting nomadd22 (Reply 2):
The core and the fan are on different spools so they can and do spin at very different speeds. Not saying there is no relation between the speeds but a slow fan need not mean a slow core.
prebennorholm
Mon Jan 10, 2011 1:45 am
Quoting Starlionblue (Reply 3):
Dear Stallion, I think that nomadd22 means the LP turbine, when he mentions "the core". The LP turbine is considered part of the core since it never touches the bypass air.
On all non-geared tubofan engines the LP turbine and the fan are locked to the same rpm. And in practically all cases the LP turbine would gain efficiency if allowed to spin faster. Consequently fan diameter is a compromise which is involving the LP turbine.
Fan tips always operate at supersonic speed. With the plane going at 0.8 Mach the fan tips would also be at M=0.8 even if the engine wasn't spinning at all, so it doesn't take much spinning to make the tips supersonic at cruise speed. Fan tip speed on a cruising airliner is typically between 1.5 and 2.0 Mach. The new P&W geared turbofans will be a little slower, but still supersonic, typically between 1.3 and 1.5 Mach. Most of the efficiency gain will be due to a faster spinning LP turbine.
Turboprop planes, however, they keep the propeller tips just below Mach one.
Klaus
Mon Jan 10, 2011 2:26 am
Quoting prebennorholm (Reply 4):
Isn't that modified by the different pressures before and aft of the fan?
Mon Jan 10, 2011 3:10 am
Fair enough.
prebennorholm
Mon Jan 10, 2011 4:09 am
Quoting Klaus (Reply 5):
It is the Mach number with which the leading edge of the fan blade tip hits the still air at cruise conditions.
The front of the fan blades are like the upper surface on a lifting wing, where the air flow is in fact acellerated. That's at least how it works at subsonic speed. Supersonic aerodynamics is a lot more complicated, and I will leave it to others to explain that - or write books about it. Optimizing the profile of supersonic fan blades is an extremely complicated science.
In any case, for single stage fan tips we are talking "Concorde-speeds" rather than transonic speeds. It's not like a multi stage axial compressor, where pressure is built up to several times ambient pressure, and the local airspeed is reduced by the same factor. The air flow in the combustion chambre is in fact much slower than the bypass air in the fan.
The turbines - both HP and LP - take advantage of that, so they in fact operate in subsonic mode. Here it also helps that sonic speed is temperature dependent - in the hot exhaust gasses sonic speed is quite a bit faster in mph than what we are used to.
Klaus
Mon Jan 10, 2011 4:44 am
Quoting prebennorholm (Reply 7):
But it's actually not really still air, isn't it? That was why I asked.
In a subsonic high-bypass engine the air should already be accelerating towards the fan within the inlet due to the lowered pressure in front of the fan ("above" the blades). And correspondingly the air should be slowing down again behind the fan, the differential effectively producing bypass thrust (minus the air going into the core compressor).
So unless I've missed something here, the fan blades should actually be operating in a mixed environment with partially below and above ambient pressures and correspondingly different mach speeds, wouldn't they?
Isn't that a factor here?
tdscanuck
Mon Jan 10, 2011 5:11 am
The larger the *bypass ratio* the better...there is no inherent advantage (for fans) to large diameter other than tip clearance issues, which isn't nearly as big a deal for the fan as the core.
Because bigger isn't always better. More bypass ratio always provides better propulsive efficiency, but there's no value in having a fan bigger than you need for whatever thrust you require. What you really want is the smallest fan you can get the thrust you need, and then the largest bypass ratio you can get with that fan (smallest possible core).
There's no technical reason you can't go to a larger diameter than those engines, but there may never be an economic case. Right now, there's no reason to build an engine with more thrust than that, and the efficiency gains will come by shrinking the core.
Quoting Klaus (Reply 8):
No. Mach number has no dependence on pressure, only on temperature. The air starts out at freestream Mach (~0.85), and may or may not accelerate into the inlet depending on the particular design...done properly on most designs, it should actually slow down going through the inlet to lower the Mach number at the fan face. At that point, this high-subsonic air encounters a fan blade whizzing around tremendously fast...the local mach number on the fan blade is the vector product of the fan blade speed and the airspeed...that can be well above Mach 1. The air pressure goes up through the fan (not a tremendous amount of velocity change within the fan itself), causing a temperature rise. Higher temperature means higher sonic speed, so you get a Mach number drop through the fan. The rest of the fan duct converts that pressure rise to velocity, and you get the air coming out the back of the nozzle just below Mach 1.
Tom.
prebennorholm
Tue Jan 11, 2011 2:04 am
Let's look at an example: CFM56-3 (22k lbs engine on B737-300), fan diameter 60 inches, 100% N1 = 5175 rpm.
Simple math (diameter multiplied by pi multiplied by rpm) gives a fan tip rotational speed of 923 mph = 1486 km/h.
Then vector in the airplane cruise speed (0.8 Mach or whatever) and we are well on the way to Mach 2.
Then there are - as tdscanuck explains in reply #9 - some pressure and temperature variations which are complicating exact calculations of local Mach numbers.
The latter may give or take low double digit percentages here and there and everywhere, but no more than that. At the end of the day, the fan tips local airspeed on a typical high bypass turbofan engine is in the 1.5 to 2.0 Mach frame.
For curiosity, Volkswagen Golf 1.4 TSI, turbocharger compressor wheel diameter = 40 mm, rpm at max power (122 HP output) = 220,000 rpm. Compressor tip speed = 1,658 km/h or 1,031 mph. (Well, that's a centrifugal compressor, and aerodynamics is therefore an entirely different animal compared to a fan. But interesting data anyway. Just accelerate a little fast away from a green traffic light, and a tiny CFRP component on your car goes supersonic in a split second).
Klaus
Tue Jan 11, 2011 9:51 am
Quoting prebennorholm (Reply 10):
Okay, I was just wondering whether the effect was in fact present there, and apparently it is. (Actual numbers would still be interesting, but are probably manufacturer-proprietary.)
Thanks.
Cool!
But CFRP? Are you sure?
Tue Jan 11, 2011 11:45 am
Quoting Klaus (Reply 11):
Cool!
Modern turbos typically have rather exotic materials for the turbines. They need to be very light in order to spool up quickly, and they need to handle very high rotational speeds. Ceramics are not unusual due to their lightness.
Klaus
Tue Jan 11, 2011 11:58 am
Quoting Starlionblue (Reply 12):
Yes, ceramics are pretty much the only way to go for high-performance turbines as far as I know.
The fan side could theoretically use less temperature-resistant materials, but CFRP? That sounds extremely hard to manufacture in the shapes required for a car turbo.
[Edited 2011-01-11 03:59:31]
jetlife2
Wed Jan 12, 2011 2:48 am
Good questions, and a lot of good points raised already.
There are a couple of factors not mentioned so far that are of interest also.
The GE90-115B fan case external diameter was sized to fit in the cargo door of a 747F (and by extension others) for transportability. The propulsor architecture means that the fan stator does not need to be transported (or even purchased) all that often, so this is a good system. Go higher than that diameter, and you have to either accept the transportation restrictions (which might lead customers to want more fan stators on hand, and defeat that advantage somewhat); or split the fan case. The latter is possible but unfriendly to aero and containment. Very large fan cases are really not easy to make when you want to hold them round in operation....Such a system has to be studied very carefully and designed nearly completely before the real trades are apparent.
As you go up in bypass ratio and demand more from the fan, the LPT has to get bigger also...usually longer (more stages). So the system weight trade has to be worked through carefully.
Another factor is the length of the landing gear. Those are already some very large forgings, and have to be stowed in the aircraft, so going longer propagates some other design and manufacturing challenges.
The attractions of bypass ratio (sfc) and acoustics sure make it interesting and enticing, so large (really large) fans keep reappearing in the studies.....will they win - or is it not worth it in the end? We will see...
My views are not necessarily the views of the GE Company
cobra27
Wed Jan 12, 2011 1:33 pm
Where is lightsaber?
Anyway, GE90-94 seems to have better SFC than GE90-115. I don't think this is the upper limit. I would be nice to see A380 with 2 engines.
tdscanuck
Wed Jan 12, 2011 2:12 pm
Quoting cobra27 (Reply 15):
It would be nice to see A380 with 2 engines.
From a technical standpoint, absolutely. But, right now, there's zero business case to develop such an engine. You'd need them to be very nearly twice the size of the GE90-115B, and figure out some way to pay for such an awesome project based on lifetime sales that, right now, look like they'd be in the neighborhood of 2000-3000...that is an extremely tall order.
Tom.
BMI727
Wed Jan 12, 2011 3:12 pm
Then what causes the loud obnoxious buzzing we hear (notably from RB211s) at high thrust settings?
DocLightning
Thu Jan 13, 2011 5:44 am
Quoting tdscanuck (Reply 16):
Also, can you imagine the transport headaches if you have to replace one of those at an outstation? Either you'd have to deliver it by ship and then maybe by some rail-based contrivance, or you'd have to make the casing disassemblable/reassamblable which would present its own spectrum of heartburn.
On the upside, if such an engine were developed, you might have a business case to build more An-225s!
-Doc Lightning-
-Carl Sagan
speedygonzales
Thu Jan 13, 2011 12:35 pm
Could a twin fan be feasible to achieve very high BPR? One fan driven directly, and the other through a drive shaft like the lift fan on F-35B.
Ignorance kills. :tombstone:
tdscanuck
Thu Jan 13, 2011 1:09 pm
Quoting speedygonzales (Reply 19):
It's technically possible, but the certification challenges would be huge (something like what the LearFan went through). If you want to go to remote driven, I think you'd be better off just going to ducted turboprops (which is very nearly what the GTF is) rather than running driveshafts around.
Tom.
rwessel
Fri Jan 14, 2011 12:19 am
Quoting DocLightning (Reply 18):
Twice the thrust would require a 41% bigger diameter fan. You'd need a bigger cargo door, but it would fit inside a 747, or even a 777. And the fan assembly should fit handily through the standard nose door of an An-124. It might even fit in a stock C-17.
DocLightning
Sat Jan 15, 2011 12:48 am
Quoting rwessel (Reply 21):
And do you think any airline wants to deal with a logistical nightmare that requires an An-124 every time something goes wrong? I don't.
Could you even fit such a thing on a train?
-Doc Lightning-
-Carl Sagan
rwessel
Sat Jan 15, 2011 11:03 am
Quoting DocLightning (Reply 22):
Errr.. You suggested that delivery would require a ship. Clearly a number of aircraft available could transport a fan assembly of the required size without modifications, and while they might not be as convenient to use as some other methods, chartering an An-124 is not that hard, and would delivery anywhere your down aircraft might be in a few days (unlike a seagoing vessel). And there are other aircraft that could take that role (C-17, probably C-5, 747-LCF, the various Belugas), although arranging to have some of those like that available would take some doing. Or a bigger side door mod to a handful of 747s. Point is, this would probably be a relatively minor concerns in building an engine of this class. If GE built such a thing, they could *buy* a couple of An-124s for well under 10% of the likely development costs of such an engine, just to have the transports available at a moments notice (although that sounds like the most expensive option).
As to trains, well cars regularly transport stacked (two high) shipping containers, although those are route restricted because of overhead clearance issues (in the US you'd need all Plate H compatible routes). But that 17ft total height (two 8.5 ft high containers) would accommodate the fan stood on its side, so long as the length of the fan assembly wasn't more than a bit wider than the rail car (about 10 ft - again with route restrictions wider loads are possible).
OTOH, overland transport could also be done with a heavy lift helicopter with an external sling (the fan assembly is probably only about half the ~35klbs such an engine would weigh). Sure the range isn't great, but it would probably be faster and easier than trying to do it by train (although certainly not cheaper!), even if you had to stop for gas every couple of hundred miles. Of course if you got a Mi-26*, you could transport the fully assembled engine, but I'm guessing you're going to object to that again.    Of course the Russians would be more than happy to sell you a couple (cheap at $15m/ea!). A CH-53K might be able to do that too, but you'd be right on the edge of its (projected) capabilities (although just the fan should be no problem).
*That is one heck of a big helicopter.
Sat Jan 15, 2011 11:11 am
Quoting rwessel (Reply 23):
AFAIK only in North America. In any case as you say I think train is impractical.
rwessel
Sat Jan 15, 2011 11:17 am
Quoting Starlionblue (Reply 24):
There's some of that in at least Australia, China and India.
DocLightning
Sat Jan 15, 2011 4:11 pm
747-LCF,
I think it's only certified to fly with Dreamliner parts aboard, for some reason.
-Doc Lightning-
-Carl Sagan
tdscanuck
Sat Jan 15, 2011 6:28 pm
Quoting DocLightning (Reply 26):
Dreamlifter parts + related tooling. It's actually written into the Type Certificate Data Sheet for the -LCF. There's no particular reason that can't be changed, it would just take the extra paperwork.
Tom.
nomadd22
Sat Jan 15, 2011 7:51 pm
Quoting tdscanuck (Reply 27):
Tom.
For some reason I was thinking that the LCF wasn't couldn't carry anything but Boeing owned cargo. That certifying it for general cargo would be a major thing, if you're talking about engines for non Boeing planes.
Anon
Sun Jan 16, 2011 5:29 am
Quoting nomadd22 (Reply 28):
Well, Belugas carry non-Airbus stuff from time to time. As Tom says, paperwork.
tdscanuck
Sun Jan 16, 2011 5:35 am
Technically, it's 787 cargo...some of those parts probably don't belong to Boeing at the time they're transported. But yes, the types of cargo the Dreamlifter can carry are extremely restricted, currently.
General cargo certification would be a huge undertaking because the Dreamlifter hold is unpressurized, un-temperature controlled, and has no fire suppression (and maybe even no detection). If you just wanted to add engines to the certification, that shouldn't be too bad (engines don't care about pressure or temperature in those ranges, and they're not flammable as long as you've purged the fuel system).
Tom.
Pihero
Sun Jan 16, 2011 9:19 am
That's an aspect that people don' really see :
Three years ago, a 777 ETOPS-diverted back to Northern Brazil : an engine change was required.
Then problems hit the fan (!) :
- runway too short for anything but a military transport plane ( C-130 or Transall) and none was available, all of them engaged in various missions and exercises...
- No railway close by.
- Only way was road transport, with a proviso : the truck MUST have hydropneumatic suspension as the vibrations and the bumps could damage the engine assembly and we discovered with surprise that very few of these trucks existed in Brazil.
- When we managed to get one, we'd lost ten days.
...and an ungodly amount of money . Tha's probably why the 74LCF is a *Transporter* and not a *cargo plane*
Contrail designer
speedygonzales
Sun Jan 16, 2011 2:45 pm
The LCF also has the problem that it can't open the crago door on its own. It needs a specialized vehicle (modified forklift, IIRC) to support the weight of the tail, so it's unable to operate outside of the regular bases.
BrouAviation
Mon Jan 17, 2011 9:11 pm
Quoting Klaus (Reply 13):
Ceramics are not used in aviation, because of their brittleness. All turbine parts and the combustion chamber of practically any jet engine fitted on an airliner today, is made of a nickel-based alloy.
Composite and ceramics layered together (CMC) are however used. The temperature resistance of the ceramics combined with the high strength of the composite structure make it one of the best possible materials for jet engine turbines. Biggest disadvantage is that the prices of those turbines are sky-high.
Because of that, CMC's aren't used yet in commercial aviation, since jet engines of today still don't meet the high TIT's where they are actually needed, but as far as I know the new jet engine for the Joint Strike Fighter will feature CMC turbines.
GTF's like P&W is now developing will make higher TIT's possible in the future, so may be CMC's will become a standard then.
Never ask somebody if he's a pilot. If he is, he will let you know soon enough!
Klaus
Mon Jan 17, 2011 9:35 pm
Quoting BrouAviation (Reply 33):
I had been referring to car turbos there, but apparently the earlier development targets to that effect I had remembered have actually not been realized either. Too bad, but there have still been some interesting developments in ceramics through the years. Maybe they'll still get there.
Users browsing this forum: Adispatcher, BravoOne, Starlionblue and 3 guests
