Max777geek
How Is Any Doubled Nose Landing Gear Towed?
Sun Jan 09, 2011 6:33 pm
I mean like Mriya that's first coming to my mind, but Im sure there are other models
Photo © Sven De Bevere
There's just a special towbar and that is all ? I wonder how it works then.
wingscrubber
RE: How Is Any Doubled Nose Landing Gear Towed?
Sun Jan 09, 2011 8:00 pm
Resident TechOps Troll
WrenchBender
Wed Jan 12, 2011 2:24 pm
The Tow Bar hooks up to the Upper (non rotating) section of both NLG oleos. The power steering is placed in bypass so the oleos will caster and you tow/push back as required. The bar is a y shaped unit 2 hook up points for the a/c and single hook up for the tug. The AN124 crews I've worked with are pretty efficient at getting the bar offloaded and hooked up when needed and re stowed once tow complete. I've had to do a few tows and pushbacks due to lost pilots going the wrong way down taxiways.
WrenchBender
Silly Pilot, Tricks are for kids.......
BMI727
Wed Jan 12, 2011 2:56 pm
Would I be correct in assuming that one can't make as sharp a turn with the double nose gear?
WrenchBender
Wed Jan 12, 2011 3:52 pm
I've taken the bar to 25 degrees or so, you can probably go further. With the wingspan and length of the Ruslan you run out of space in a hurry so small turns and slow driving is pretty standard.
WrenchBender
747400sp
Thu Jan 13, 2011 3:37 pm
Max777geek, thank you for posting this topic, I been wondering the same thing.
Max777geek
Thu Jan 13, 2011 10:47 pm
BMI727, If I got WrenchBender speech correctly the 2 (apologize) "legs" of the steering nose landing gear aren't turning either way. the wheels only are, "in axis" with their sustaining leg, sorry for improper use of terms but I think you got my point.
One or two that they are you can almost have the aircraft turning on a needle pin, assuming there are no locks for a 180' turn.
747400sp you're welcome, always nice reading somebody say thanks.
Users browsing this forum: jarheadk5 and 1 guest
